Old 05-07-2011, 07:07 PM   #4126
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 167
Originally Posted by TheRadBaron View Post
I think that the slight interference fit on some master link side plates is engineered that way for some added security. That way the flimsy clip isn't the only thing holding the master link together. I have a Motion Pro tool that has a press plate for master links like that. Before I had the tool, I had luck using vise-grips to press the plate on.
You probably won't have any trouble with the loose-fitting plate, but it would be a more secure solution if you could find a way to press the correct plate on.
I tried vice grips with no luck. Was to hard to compress. Anyway, It's on and seems ok. I'll keep an eye on it for a while.
BTW: When I replaced the original chain a few years ago, it had to be cut apart. "No master link" I was standing there when the shop guy did the install. He used a dremel grinder to cut original chain off.
Thanks everyone for your input. Great forum for info.
larry31 is offline   Reply With Quote
Old 05-08-2011, 09:06 AM   #4127
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 2,747
SaDow
good to know they are the same, they sure look the same to me.
I would not worry too much about the scar, now that you have changed heads, just make sure the new head's valves are in good order and properly shimmed.
Seeing how your engine is already apart i would consider puting a new piston and rings in it. Not too much work (at this point) but worth the trouble and money considering you already have the head off.
Otherwise just clean it and re assemble
just my thoughts
my nx250 project pics
my mini ride reports
"parts made of unobtanium"
+ momento mori +
ArthDuro is offline   Reply With Quote
Old 05-08-2011, 03:10 PM   #4128
SaDoW
Oddometer: 76
Originally Posted by ArthDuro View Post
SaDow
just my thoughts
now you are scaring me...
why do you suggest a piston change i only have 23000 klm
Is something wrong with my piston ?
SaDoW is offline   Reply With Quote
Old 05-09-2011, 12:36 AM   #4129
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 543
Well, your head failed because a valve obviously hit that piston and you are fitting a new head.
It's probably fine - but a piston kit is not expensive and, while the head is off, it is easier to fit one now rather than have to strip the engine down again.
It's a wise precaution to at least have somebody pull the piston and make sure it and the cylinder have no damage.
Saves you doing the work two times.
CambodiaYeah!
Jacl-Kampuchea is online now   Reply With Quote
Old 05-09-2011, 01:37 AM   #4130
Local Machine
Oddometer: 24
Hi everyone, first post here!
@SaDow
"And another question for u this is my piston ....
there is a small hit just a scar... will i have problems like oil burning or something? or i am good to go.?"
The AX1 NX250 is a Nikasil coated bore so if you are planning on replacing the piston it will be a good idea to use a factory made replacement only if your nikasil sleeve coating is in a good condition.
Note that cylinders from several Japanese manufacturers have thinner coatings, sometimes as thin as 0.05 mm (0.002"), making the honing procedure a very risky business.
If your bike's coating is in a bad condition and you leave the bore scored then you will get blow by, low compression, burnt piston/bore as the combustion gases rush by. It wont last for long.
Personally I'd go for a cylinder/piston replacement if so. If everything is in good condition I'd keep using the original one.
*(Sorry for the long answer)
Local Machine is offline   Reply With Quote
Old 05-15-2011, 10:54 AM   #4131
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 167
Harbor Freight High Position Motorcycle Lift
Does any one have/use one of these? http://www.harborfreight.com/automotive-motorcycle/lifts-stands/high-position-motorcycle-lift-99887.html
Will it lift a Honda GL1800?
How stable is it if removing wheels?
Does it mate to bottom of an 1800?
Old 05-16-2011, 03:16 AM   #4132
az2002
az2002's Avatar
Oddometer: 23
noise
Hi,
help is needed.
Honda ax-1 has a strange noise or whistle hearing from engine.
http://www.youtube.com/watch?v=8dUbNSkNzrg
odometr >62000km (I have ridden 46000км, there was no speedometer drive(cable) when bike has come from Japan). No one had opened the engine covers since 1989.
Local mechanic has told it is the cam chain noise.
I have replaced cam chain (the old and the new chain have the same length)
http://ax1.f.qip.ru/?1-2-0-00000042-...1-0-1305389284
adjusted valve clearance (was 0.30 0.25 0.25 0.25mm become 0.23 0.21 0.18 0.23 spec 0.23+-0.03)
http://ax1.f.qip.ru/?1-2-0-00000006-...1-0-1305531694
checked cylinder compression: 14 bar, 15 bar with oil. (spec 16).
http://ax1.f.qip.ru/?1-2-0-00000169-000-0-0-1305340373
Noise remained the same.
http://www.youtube.com/watch?v=q0-W_XYnMk8
where is it coming from?
az2002 is offline   Reply With Quote
Old 05-16-2011, 11:36 AM   #4133
RollingJ
The mud in your eye
RollingJ's Avatar
Oddometer: 215
It sounds to me like the compression test is the telling one. adding oil got you one more bar, so you have lower end blow by. Still low compression means top end problems.
I think you need new rings (maybe a new piston and cylinder) and a proper 3 angle valve job.
My best guess, but the whistle is an over-pressurized crankcase and a mostly full breather tube.
Some will fall, others will laugh. I will do both.
06KLX250S 05CRF450X 98ST1100
RollingJ is online now   Reply With Quote
Old 05-16-2011, 10:32 PM   #4134
az2002
az2002's Avatar
Oddometer: 23
May be so.
Oil consumption is less than 100ml on 1000km.
Compression test was not accurate: engine was warmed up for only 2 min, the tester is intended for the car and has a dead(not used) volume in a hose.
A good mechanic said "no crime sound, ride".
So i will wait until next oil change.
Valve clearance depends on cam chain tensioner, I had measured +0.02-0.03mm when removed it.
I have cleaned crankcase breather tube earlier. What "an over-pressurized crankcase" means?
Old 05-17-2011, 12:35 PM   #4135
mito-nx
Dutch Humor
Oddometer: 55
The scar is minor, no problemen.
But did you come across a overbore piston when you were surching for à new one.
Or have you found à substitute model from for instance wiseco?
mito-nx is offline   Reply With Quote
Old 05-17-2011, 04:01 PM   #4136
RollingJ
The mud in your eye
RollingJ's Avatar
Oddometer: 215
By "Over-pressurized crankcase" I mean that blow-by past the rings can pressurize the crankcase if the breather tube is clogged.
Old 05-17-2011, 07:22 PM   #4137
PTC
Oddometer: 179
Originally Posted by az2002 View Post
hi,
help is needed.
http://www.youtube.com/watch?v=8dubnsknzrg
odometr >62000km (i have ridden 46000км, there was no speedometer drive(cable) when bike has come from japan). No one had opened the engine covers since 1989.
noise remained the same.
http://www.youtube.com/watch?v=q0-w_xynmk8
---if the fuel is blowing by the piston rings it will go into the crankcase and mix with your oil, therefor oil consumption may be higher because the level may be an oil and gas mix. Dangerous and bad for lubrication. Does your oil smell like gas? Thats an easy way to judge the situation< just sayin.
PTC is offline   Reply With Quote
Old 05-17-2011, 10:32 PM   #4138
az2002
az2002's Avatar
Oddometer: 23
I have removed a plastic separator and a tube from the engine. The same sound even if I close by the finger a bore in the engine.
Separator is clean.
There is an exhaust from the crankcase, depends on revs. No smoke. Smells like oil.
I have changed oil 4000km before. Level has droped from max to min mark. I dont see a problem in it. Gasoline in oil (if any) quickly evaporates after warming up.
I think in next 20-30 tkm a standart parts will be needed:
RING SET PISTON 131A2-KW3-621
GASKET, CYLINDER HEAD 12251-KW3-003
The best way to increase a combustion chamber: XR650R or WR450.
And the best way of repair of the old faulty engine - replacement in gathering.
Old 05-19-2011, 01:09 PM   #4139
MotoRover
Yarr
MotoRover's Avatar
Oddometer: 70
Thanks APEX for borrowing this picture
http://www.advrider.com/forums/showp...2&postcount=36
MotoRover
Real freedom is to live free enough to give up so called rights, and to go beyond ego.
MotoRover is offline   Reply With Quote
Old 05-19-2011, 02:10 PM   #4140
SaDoW
Oddometer: 76
after six months.... today is a good day
How do you find the sound ? is it good??
http://www.youtube.com/watch?v=-CeWheAPFbc
http://www.youtube.com/watch?v=XL5nOxkq0B4
SaDoW screwed with this post 05-19-2011 at 02:19 PM
Times are GMT -7.   It's 04:30 AM.
