12-08-2012, 12:50 AM
#5881 | |
All-season-rider
Oddometer: 88
Only got a few thousands miles on mine since I bought it earlier this year, but already "in love". My first look made me think of the ugly duckling Not sexy at all. After some thinking and comparing with other dualsports, this one have it all. Well, most of it. Too soft suspension and tiny brakes compared to new bikes, but still this is just replaceables Now when its snow and ice nad low temps, Im just saying "halleluja" This bike really surprises me. So easy to drive on ice, and engine/drivetrain works just as smooth in these temps as in the summertime. Both thumbs up
Life is a just a game - lets play! |
12-08-2012, 01:07 PM
#5882 |
Oddometer: 16
Guess its time to post my NX 250
Here it is guys!!! Enjoy!! ![]() Also i have been having a problem with it. I took it in and got it worked on and thought that might of fixed it. But it still likes to shut off while driving it. But will fire right back up? Dont know if its because the of the sparkplug and its not spaced right? Ill check that out. but if you have any input Let me know Thanks |
12-08-2012, 02:21 PM
#5883 | |
Thumper
Oddometer: 58
12-08-2012, 07:08 PM
#5884 | |
Back Roads Explorer
Oddometer: 167
NX CDI checking
Just in case you don’t have the manual, here’s a pdf version of one. FWIW http://www.powers31.info/Honda%20NX250%20Manual.pdf This is the part on checking the CDI. http://www.powers31.info/1988_NX250_Ign_Sys.pdf Here’s a variety of other info on my NX. If it helps any… http://www.powers31.info/nx250.htm Edit: When my CDI failed, it would not start up when I made a roadside stop. After a bit of cooling down it started. Again it failed to start first thing in morning, then it did start. Finally it failed completely. Only then could I do the resistance tests outlined in the manual to be sure it was the CDI and not another electrical componet. ( Coils, wiring, etc.) larry31 screwed with this post 12-09-2012 at 06:09 AM |
12-08-2012, 10:03 PM
#5885 | |
Rustled softly.
Oddometer: 2,003
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo |
12-09-2012, 03:22 PM
#5886 |
Oddometer: 78
Countershaft
I was in the process of putting on a new chain today when I encountered a problem. The countershaft sprocket was loose. As in, I wondered to myself "is this going to come off on its own", not "oh that has a little play in it" kind of loose. I then tried to take it off but without success. Once I took the face plate bolts out I could then push the sprocket and face plate towards the engine and spin the faceplate around 360*. Nevertheless, the face plate and sprocket would NOT come off. So I guess I have two and a half questions:
1. How much play is there supposed to be in the countershaft? I expect the response to be "a little" 1b. What do I do if there is "A lot"? Buy a new front sprocket? The teeth are ok by my standards. 2. How do you get it off? TB thirstybuck screwed with this post 12-10-2012 at 06:44 AM Reason: E: for typo |
12-10-2012, 04:00 AM
#5887 | |
Oddometer: 135
A “little” play is perfectly normal, even if the engine is new. The extend of “little” is determined by the wear of the countershaft. That’s what a NX250 countershaft looks like after almost 100.000km ![]() The sprocket has worn off quite a bit of material from the countershaft, but it still should be good for a couple of 10.000 kms. If your shaft looks worse than mine, you should consider changing it, in order to avoid something like that in the picture at the bottom . In minor cases it helps changing the fixing plate to reduce the play a bit.The fixing plate may be also worn or bended, which makes it hard to get it of – than you have to use some force
12-10-2012, 04:14 AM
#5888 |
All-season-rider
Oddometer: 88
Does anyone know the sizes for wheel ball bearings and sealings, or know where I can find that info?
In need of replacing rear bearings, considering replacing all 5 wheel bearings when I'm at it :-)
12-10-2012, 12:31 PM
#5889 | |
Oddometer: 78
sprocket
The countershaft is in good shape. I still think that that is a hell of a lot of lateral play, but I haven't had to deal with countershaft sprocket before. The back and forth play, chain directions, is much better than side to side. Tell me what you think. I failed at getting the video to embed so you'll have to settle for the link. http://youtu.be/tNeEyZYpMQ4 |
12-10-2012, 12:59 PM
#5890 |
Oddometer: 48
I don't know if this is against the rules, but there is a nice NX250 for sale in Western PA. I know the ad says barter, but when I spoke to him he said he'd sell it outright. Not in the cards for me, but maybe for you (yinz) guys.
http://pittsburgh.craigslist.org/spo/3378800606.html |
12-10-2012, 02:19 PM
#5891 |
Oddometer: 19
[QUOTE=thirstybuck;20219026]Scrambler - thanks for the reply and the pictures; that answered a lot of questions. I put the NX back together and rode it to work and back, about 6 miles. The new chain is great and the countershaft didn't
The countershaft is in good shape. I still think that that is a hell of a lot of lateral play, but I haven't had to deal with countershaft sprocket before. The back and forth play, chain directions, is much better than side to side. Tell me what you think. I failed at getting the video to embed so you'll have to settle for the link. thirstybuck: It does seem a little more "loose" then the new sprocket I just put on mine, or even the old one I replaced. Also, is that sprocket stock? My old one didn't look like that and the new Driven one I put on sure isn't like that either. I'm referring to the steel material on the face of the sprocket. |
12-10-2012, 02:25 PM
#5892 | |
Oddometer: 19
I replaced all my bearings recently. I just ordered off of ebay. All Balls bearings. Came with oil seals and all the bearings needed, no problems with install. Cheap as well, maybe $30-40USD for front and rear shipped. http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 |
12-10-2012, 03:13 PM
#5893 | |
Oddometer: 179
12-10-2012, 03:20 PM
#5894 | |
Oddometer: 78
sprocket
[QUOTE=polarized;20219825]
12-10-2012, 03:24 PM
#5895 | |
Oddometer: 78
Sprocket
Thanks for the feedback. I'm going to order another sprocket. Do they come with the faceplate and bolts? |
