12-10-2012, 07:12 PM
#5896 | ||||||||||||||||
Oddometer: 1,832
12-10-2012, 11:42 PM
#5897 |
All-season-rider
Oddometer: 88
polarized and fiep :
Thanks alot for helping out here Reason I ask is that I would prefer (bit I do not need to) to shop locally, with brands like SKF, Koyo... I can get bearings for reasonable prices. Maybe it's just me that is not familiar and not trusting brands like All-Balls? ![]() My simple brain associate All-Balls with a men's only pub or something ![]() Maybe I should give them a try. After all it's very cheap (more garage beers).
Life is a just a game - lets play! |
12-10-2012, 11:52 PM
#5898 |
All-season-rider
Oddometer: 88
thirstybuck ;
On mine (using AFAM sprocket and original (31.000KMs) plate/bolts, the sideway play is considerable, but I belive it is not as much as yours (not big difference though). When I replaced the sprocket, I belive the old one was original, at least it the bike has been serviced by a Honda garage, there was some red silicone-liquid-gasket-like stuff in the gap, so free play was a bit less and "softer". I just removed this and replaced with new sprocket, and could not feel any siginificant difference. I'm not an mecanic (far from), but have replaced some sprockets trough the years, and cannot remember I have seen this much free play on any bike.
12-11-2012, 01:59 AM
#5899 | |
Oddometer: 135
Hmm, looks normal – but as I said, the wear of the countershaft is crucial. It’s kind of hard to tell with the bare eye; before I took the picture I thought there was no wear. Only after zooming the pic I saw that the shaft lost actually some material. Btw, it looks like you got an original sprocket, since that is the only one that got that rubber mounts. Honda used that "flexible" mounting of the sprocket on all dirt bikes of that period (dunno about the CRF etc.) and a lot of drivers got puzzled by that. I was told that the side to side play is necessary to counteract torsions of the frame/swingarm for instance during hard landings. I heard of some problems with that flexible mounting on the much stronger XRV650 Africa Twin. Many drivers had to buy new countershafts, some of them tried to glue (no kidding) the sprocket to the shaft, but I don’t know if that is advisable. And there had been many discussions among XRV drivers about the quality of aftermarket sprockets, apparently some are made of harder steel than the shaft (JT), or are not made with the necessary precision (sunstar). I don’t know if that is the case with the NX250, but given the consequences, I would go with the OEM sprocket (plate and bolts are sold separately). And a bit of grease and chain lube from time to time shouldn’t hurt ;-). scrambler66 screwed with this post 12-11-2012 at 04:51 AM |
12-11-2012, 03:48 AM
#5900 |
Booze Merchant
Oddometer: 547
Countershaft repair.
I know this will sound WRONG to many, but it does work:
Remove or disconnect battery. Remove sprocket. Plug in electric arc welder Do a very quick bead of weld on the countershaft. Cool immediately with water to avoid melting the oil seal. Repeat the above two steps until the worn bits are built up. Use a dremel, small grinder or needle files to file new splines into the countershaft. It's a most effective $2 repair.
CambodiaYeah! |
12-11-2012, 04:08 AM
#5901 |
Booze Merchant
Oddometer: 547
I've done perhaps 35 thousand km's on my bike now.
No big mechanical issues - but it has had some issues with the valvetrain. Basically the bike was in Cambodia for a long time before i got her and the valves in it are re-ground and sound clattery as hell lately. I want to buy new valves, seats and seals in the interest of preventative maintenance. I just know Honda parts. Are there any aftermarket valves out there?
CambodiaYeah! |
12-11-2012, 04:40 AM
#5902 | |
Oddometer: 135
cam chain tensioner?
?![]() I tried this fix since my engine was also making a lot of unpleasant noises - and it worked - at least for the last 3000kms ;-) scrambler66 screwed with this post 12-11-2012 at 04:48 AM |
12-11-2012, 08:08 AM
#5903 |
Oddometer: 5
AX-1 Thailand
I live in Chiang Mai Thailand. I was happy to be riding it. And have good instructions from here. and buy spare part from http://find.powersportsplus.com/?q=*...et:%22NX250%22 Thank you. https://www.youtube.com/watch?v=UCsPYeniAO0 ฺBefore Rebuild http://image.ohozaa.com/view2/wvPfW868VzRSI2Jl After Rebuild http://image.ohozaa.com/view2/wvPfZFSXLuM7zGz9 http://image.ohozaa.com/view2/wvPg3dFMBtQaL14V http://image.ohozaa.com/view2/wvPg6LsBrc7vF7Wp http://image.ohozaa.com/view2/wvPgajfqgQZMXesg https://www.youtube.com/watch?v=UCsPYeniAO0 IamsaparoS screwed with this post 12-11-2012 at 12:09 PM |
12-11-2012, 08:24 AM
#5904 |
Oddometer: 5
ฺBefore Rebuild
12-11-2012, 08:37 AM
#5905 | |
Booze Merchant
Oddometer: 547
CambodiaYeah! |
12-11-2012, 02:26 PM
#5906 |
Oddometer: 1,832
is it OK, to mention
I finally got my ... in motion and took pictures of what I have left of that poor NX I ripped to pieces when building Elsie if not, mea culpa http://www.advrider.com/forums/showt...6#post20227456 |
12-11-2012, 03:33 PM
#5907 |
Oddometer: 179
12-11-2012, 06:24 PM
#5908 |
Oddometer: 16
Can anyone tell me where i can Purchase a GearBox. The thing that spins at the wheel to show my mileage and speed.
Mine is broken and looking for one to replace it but cant find any online |
12-11-2012, 07:56 PM
#5909 | |
Oddometer: 135
http://www.powersportsplus.com/parts...EEL/parts.html
12-12-2012, 07:02 PM
#5910 | |
Rustled softly.
Oddometer: 2,003
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo |
