12-21-2012, 06:37 AM
#5941 |
All-season-rider
Oddometer: 88
Haha!
Life is a just a game - lets play! |
12-21-2012, 07:27 AM
#5942 | |
Oddometer: 135
oh well, I guess the grass is just greener.... but I found a solution by buying a AX1 - NX250, the Japanese luxury version. Right now it’s still painted in a gruesome yellow, but hopefully in the not too far away future it will look like this specimen below |
12-21-2012, 06:05 PM
#5943 |
Oddometer: 78
In every case I've read about, the cam chain has never been at fault. It has always been related to the tensioner. Evidently it is similar to designed used in the Honda Fireblade/CBR 9xx (?) and it is standard practice for owners of these bikes to swap out the automatic tensioners for manual ones. My own bike fell prey to this and I now run a manual tensioner. No more noise and no more worries. If you've got rattles or it sounds like marbles going through a popcorn machine then you need to get a manual tensioner. I believe that the automatic tensioner is not able to extend as far as it should as the combination of pressure from the cam chain guide and the vibrations from the engine run the tensioner back in. If I start up my bike with the tensioner adjusted but with the jam nut loose it loosens the screw VERY quickly.
12-21-2012, 06:37 PM
#5944 |
My bikes Suck!
Oddometer: 784
12-21-2012, 06:55 PM
#5945 |
Oddometer: 1,832
does anyone here know if NX125 parts (exept engine, of ourse)
interchange with NX250? thanks |
12-21-2012, 08:33 PM
#5946 | |
Oddometer: 38
12-21-2012, 10:45 PM
#5947 | |
Oddometer: 135
AX1 Conversion
The bracket of the headlights is available at CMS http://www.cmsnl.com/products/brkt-f...n_64510kw3000/ As is the complete headlight http://www.cmsnl.com/products/light-...d_33100kw3003/ You can check the OEM part numbers at this site http://www.moto4.ru/fiches/honda_nx250_ax1/ So theoretically it would be possible to convert a AX1 to a NX250 – but it’s way too expensive - not even I would be so mad
12-22-2012, 01:57 AM
#5948 |
Booze Merchant
Oddometer: 547
Today I pulled the tank and the rocker covers from my bike.
Camchain in perfect condition, gears perfect, cams not scored. Had to work then. Going to get the head off before work tomorrow. . . If I'm VERY lucky I may get away with Piston/Ring set and new Valves, Shims and Seats combined with a hone. Also noticed my CDI was repaired in the past, It's never given me trouble so must have been a tidy repair.
CambodiaYeah! |
12-22-2012, 03:58 AM
#5949 |
My bikes Suck!
Oddometer: 784
I am that mad to swap out to the ax1 front end. I will be doing it if the wife wants the nixer
12-22-2012, 07:06 AM
#5950 | |
Oddometer: 38
. But, it is still cheaper to change the bits and pieces than import an AX1 into the USA...plus, I like the wire wheels of the NX better. Maybe if I could find the parts used...off a scrapped AX, it would be more economical...I will have to look for an international eBay site or something, eh? Any recommendations?
12-22-2012, 07:20 AM
#5951 | |
My First Gold Chain
Oddometer: 300
http://advrider.com/forums/showthrea...731237&page=18 The NX250 and NX125 are VERY different bikes. Items that are shared: Front and rear reflectors - I still need the fronts and the little stems to mount them Tail light lens Front Turn Signals - The rears have looooong mounting stems Mirrors - NX125s are cheaper as the rubber vibration mounts are not included Handle Bars are both 7/8" diameter Not much is the same. |
12-22-2012, 03:15 PM
#5952 |
Oddometer: 1,832
OK, thanks
guess I will not buy the NX125 that just popped up on CL |
12-22-2012, 04:37 PM
#5953 |
tractus pro pensio™
Oddometer: 1,564
The NX125 shares the rear fender assembly, iirc..just the plastic and the lights.
the nx125 is the xl185/xr200/ type air cooled motor. |
12-22-2012, 10:04 PM
#5954 |
Oddometer: 135
AX1 parts
That thought crossed my mind
There must be lots of AX1 parts in Russia (the parts list above is from a Russian parts vendor) but since its Cyrillic, I have no idea how to look for them at eBay. If you got a decent Honda dealer, take the OEM part number and ask him if he willing to order them. There is one vendor who organizes Japanese Yahoo auctions, but it’s too expensive, too – don´t get fooled by the prices, you have to multiply them by three until they are shipped to Europe http://auctions.isibike.com/?catId=0&freeWord=AX-1 From time to time a complete AX1 showed up at Ebay UK, they are not even that expensive – 800-1200 £ - looks like I could make a living by buying a container load full of them and ship them to the US? At least you could take a pair of those headlights with 3.5" diameter - same as the AX1. I´m forced by the dang German TÜV to use them, too, since the original AX1 lights are not DOT approved http://www.ebay.de/itm/FROG-EYE-DOUB...item416efbb8b3 There is a very nice site of a Greek guy who totally rebuild his AX1. I do not take any responsibility if you visit this site – you will probably get totally hooked to the AX1 http://dhost.info/ax1/html/the_rebuild.html And if that happens, you could buy an AX1 directly from Japan http://motorcycle.goobike.com/motorc...0B30121108002/ This one looks really nice and shiny, I wonder if the price of 5,800$ already includes shipping - by the way, did I mention that the AX1 musters 3 ponies more than the NX250 ?
12-23-2012, 12:00 PM
#5955 |
Booze Merchant
Oddometer: 547
That is waay too much for an AX-1. I could buy one from Japan ( direct from a container ), register it in my name for under $2000, drive it to Bangkok and have it flown to Europe for around $600/700.
Hell, I could buy a good one here from $800 to $1500. There's a good reason the stock AX-1 lamps are not DOT approved - they suck. I fitted two HID kits to mine lately and it's easily 300% better. One lamp is rigged with a HID for low beam, and the other for high beam. When one is on the other is off unless I use the passing button and then both are on as long as I keep the button pressed.
CambodiaYeah! Jacl-Kampuchea screwed with this post 12-23-2012 at 12:15 PM |
