Old 02-23-2013, 07:40 AM   #6091
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 174
Battery problems
Originally Posted by fiep View Post
all electrics on Else are NX250
she just developed a strange, bad behavior
I start wit a fully charged battery,
starts right up, light (HID) works fine,
5-10mi down the road the light's off due to a completly drained battery
bike runs until I shut it off,
then of course it will not start with no more juice
once the battery is charged we start over
alternator output is good
no loose connections, no loose ground wire,
any ideas?
thanks
Check voltage at the battery terminals while running at about 2000 rpm. ( Should be about 14 volts and steady.)
If it’s good, the regulator should be good.
Shut bike off and measure voltage at battery terminals while cranking the starter.
If below 10 volts, the battery may be suspect.
If the voltage is 12 volts or below while running at 2000 rpm, your regulator or alternator may be bad.
You could also check for a short. Disconnect the battery and with ignition switch off, measure from positive battery wire to chassis. ( The wire lead, not the battery terminal )
Here’s a link to electrical trouble shooting for the NX.
http://www.powers31.info/nx250.htm
Scroll down to heading…
NX250 Ignition System
( from 1988 Honda Service Manual )
{ View as a pdf file }
The NX250 shop manual. Link is just below. Note: It may take a while for this file to display.
larry31 screwed with this post 02-23-2013 at 08:03 AM
larry31 is offline   Reply With Quote
Old 02-25-2013, 04:38 PM   #6092
RollingJ
The mud in your eye
RollingJ's Avatar
Oddometer: 216
Time to sell the old girl
I hate to do it, but I think it's time. I need to get a bike for my boy that doesn't cry so much when you drop it.
89NX250 $800
Located in Bastrop Texas, just east of Austin.
21/17 tires and the stock 19/16 go with it as well. I have a few things not shown also included, like the passenger pegs and a rack for saddlebags. The sprockets are brand new (one ride) and the chain is an expensive D.I.D. x-ring that should never wear out on this little 250. There are handguards, a one-way sign skidplate, and a flood light for better nighttime vision.
She runs really strong, the valves/camchain/tensioner are in spec, but is having a hard time shifting from 1st to 2nd. Most of the time she just goes to neutral unless you time the revs just right and powershift without the clutch. I thought seriously about splitting the cases and fixing the problem, but I'm ready to sell and know I won't recoup the cost.
I obviously went the high fender/aftermarket headlight/cut down plastics route. There is no speedo. I have the broken left tank cover and I may try to rebuild it. The tank had a pinhole leak that was repaired with gas tank putty and a sheet metal screw over a year ago.
I really don't want to part a running, titled bike. I would rather sell it outright at $800 and let someone who will keep it for a while do the work to make it theirs, but if I don't have any interest I will start to take it apart and sell the bits on ebay.
Pm me if you are interested.
Some will fall, others will laugh. I will do both.
06KLX250S 05CRF450X 98ST1100
RollingJ screwed with this post 02-25-2013 at 04:52 PM
RollingJ is offline   Reply With Quote
Old 02-25-2013, 05:01 PM   #6093
tntmo
Oddometer: 229
I have a good, but ugly tank available if anyone buys RollingJ's bike. Cheap!
Buncha dirt bikes with license plates.
tntmo is online now   Reply With Quote
Old 03-01-2013, 05:37 AM   #6094
thirstybuck
Oddometer: 80
We got a couple days of warm (>32*F) days here recently so I untarped the NX, flipped the choke, and hit the button. Vroom! Fired up like I just shut it off.
thirstybuck is offline   Reply With Quote
Old 03-01-2013, 07:29 PM   #6095
Psychoboy
Psychoboy's Avatar
Oddometer: 14
So my dad gave me one of these 89' NX250 (only 2900 miles on it). Well I got it running and took it out. Was tons of fun. It's not my first bike I now have 2 bikes one for my normal cruising and this one which I am considering a toy.
One thing I eventually want to do with it is going on a weekend ride out here in the desert (AZ) and that will need some sort of saddle bags to put some extra items in. I am wondering if anyone has ever custom fitted ones for it like maybe attaching some old ammo boxes to it is kind of what I was thinking? I don't want to really invest a ton of money into this thing bike. Any idea's or inexpensive ways to accomplish this would be greatly appreciated.
Here are a pictures of it from my last day trip if anyone is carious :)
Psychoboy is online now   Reply With Quote
Old 03-02-2013, 04:37 AM   #6096
larry31
Back Roads Explorer
larry31's Avatar
Oddometer: 174
I made some frames out of electrical EMT pipe.
Here's what I did, if it helps any...
http://www.powers31.info/Side_Luggage_Frames.htm
http://www.powers31.info/nx250_saddlebags.htm
If it helps, here's more on my mod's to my NX250
Old 03-02-2013, 06:05 AM   #6097
Drifter.
Oddometer: 14
Anyone have or know of an nx for sale in florida? I sure miss the old craiglook.
Drifter. is offline   Reply With Quote
Old 03-02-2013, 08:17 AM   #6098
Sinan
Oddometer: 56
Hi all;
My Nixie hit the 82.000 kilometers on odo.And still as rock solid.
I am a little jealous about you.How can you find 3000-5000 mileaged NXs.I can give a lot of dollars for them here. Hard to see even a rolling one nowadays in here.
Sinan is offline   Reply With Quote
Old 03-02-2013, 10:14 AM   #6099
scrambler66
scrambler66's Avatar
Oddometer: 137
300cc and 30hp anyone?
http://www.xlitemoto.com/products_li...159018943.html
scrambler66 is offline   Reply With Quote
Old 03-02-2013, 05:52 PM   #6100
CurtW
Thumper
CurtW's Avatar
Oddometer: 58
I'm not sure what craiglook was, but based on the name, I'm guessing that searchtempest.com will stand in...
CurtW is offline   Reply With Quote
Old 03-02-2013, 06:13 PM   #6101
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,566
has anyone found a cheap source for the brake caliper piston seals, and dust seals for the NX?
$25 is kinda high for four rubber bands
rebuilding a spare first, then just going to swap it with the one on the bike. hopefully the issues with tire wear, caliper wear, slow acceleration and poor mpg's will ALL clear up...
It just appears like the caliper pistons are finally crudded up and dragging slightly..?
Will, of course, shoot photos and write it up!(brake rebuild, YAY)
Also, it's time for the valve adjustement again........that's right, AGAIN.
600 + 26000 +26000
Miles fly when you are having such a good time
Honda NX250??
I prefer to ride, and when i do, it's 'un Equi
valvecrusher is offline   Reply With Quote
Old 03-02-2013, 06:44 PM   #6102
valvecrusher OP
tractus pro pensio™
Oddometer: 1,566
found another future NX2 rider...
thanks, LoadedAgain? for the tip-off down in Inmates..
This little sweetheart wanted to know how many views she got, well, let's give one little one a bit of JOY!
Honda NX250??
Old 03-02-2013, 06:51 PM   #6103
Orkodelamuerte
Orkodelamuerte's Avatar
Oddometer: 78
600 + 26000 +26000
Check this out, I just bought them here...
http://www.partzilla.com/parts/detai...9-MA3-006.html
have fun!
Orkodelamuerte is offline   Reply With Quote
Old 03-02-2013, 07:45 PM   #6104
Psychoboy
Psychoboy's Avatar
Oddometer: 14
Originally Posted by Orkodelamuerte View Post
I have used partzilla to order other parts. They are a great company as far as I can tell (I have only ordered OEM parts from them)
Old 03-03-2013, 05:48 AM   #6105
legends117
Oddometer: 44
Drifter - I just sent you am PM. - JD
Peace - JD
'75 BMW R90S
'89 Honda NX250
'11 Triumph Tiger 800
...currently, but always looking for the next one
legends117 is offline   Reply With Quote
Times are GMT -7.   It's 02:30 AM.
