03-21-2008, 04:45 PM
#1 |
Oddometer: 604
I remember reading somewhere (here) that folks were having problems with battery vibration wearing the contacts or shutting off the unit or something when mounted to the bike.
Curious - is this a concern if the bike is being used on road or only off road? Does a thin foam shim help to keep the batteries snug and in place? Anyone use dialectric grease on the battery connections inside the unit?
Forum motto - Buy a bike like mine Gravity - It's not just a good idea, It's the law. 1998 Honda Valkyrie 1946 Chevy pickup |
03-21-2008, 07:18 PM
#2 |
Enjoying empty roads...
Why don't you just hardwire to the bike? Fixes the problem of the 60 shutting off and if you need to use it off the bike just carry a set of batteries.
03-21-2008, 08:27 PM
#3 | |
Professional Trail Rider
Oddometer: 1,723
03-21-2008, 08:37 PM
#4 |
earthbound misfit, I
Oddometer: 6,594
I tried mine on my xrl last year with just batteries on a ram mount. It worked ok for the first twenty miles, then just kept shutting itself off. I was just running gravel roads.
I got my hardwire kit and ram mount from cycoactive.
03-21-2008, 08:52 PM
#5 |
Oddometer: 5
gps battery vibration
I read somewhere that constant vibration will cause the battery contacts to arc and make for poor connections. I wrap my batteries with a little black electric tape and use dielectric grease on the contacts. after one year I have had no problems with unit shutting down.
I am also hard wiring the unit to the bike this weekend to eleminate the need to keep extra batteries on board. FYI Mike |
03-21-2008, 08:58 PM
#6 | |
Oddometer: 3,982
not on each battery.
Jerry Counts |
03-21-2008, 10:29 PM
#7 |
Oddometer: 178
I have my uint hardwired and I put a foam ear plug on top of the batteries (actually lay it down between them) and put the cover on. The newer models have a large foam square under each electrical contact to keep it from greaking.
03-22-2008, 05:34 AM
#8 |
Silly Party Candidate
Oddometer: 497
I don't ride off-road, but years ago with my first GPS I discovered that sticking one or two foam earplugs inside the battery case before closing it prevents vibe-induced shutdown 100% (in my case). BTW, I currently use that technique on my 60csx.
2003 Kawasaki ZR-7S ADVRider Relay 2008 - Delaware My stupid little website:Tilted Horizons |
03-22-2008, 09:23 AM
#9 |
Oddometer: 212
My 76cx has a very tight battery box. I used the suggestion to put an earplug between the batteries. Thanks.
But: I have had no problems in the past...several thousand miles offroad. |
03-24-2008, 12:17 PM
#10 |
Oddometer: 313
I have a 60csx and it worked the first few hours on my LC4, then it would die every few minutes on / off road. I tried putting earplugs, tape and anything else i could find behind the batteries with no luck. Hardwired it and now no problems.
03-24-2008, 01:51 PM
#11 |
Oddometer: 21,547
There are a couple solutions:
1. Lithium cells. The Energizer Lithium AA cells are very light and vibrate far less than NiMH and Alkaline cells. They also last much longer and work better in cold conditions. 2. Shim the connection tabs inside the battery compartment. A small bit of cardboard behind the battery tab works as a shim to hold the cell tighter than it would otherwise be retained. 3. Shim the cells with a foam earplug or similar. Same idea as #2 - you're looking to tighten the fit of the cells in the case. 4. Install a small capacitor on the PCB. For advanced users only, as it requires dissasembly and soldering to the printed circuit board inside the case. The capacitor acts as a backup battery, providing power for the moments its needed when the cell connection is broken by vibration. 5. Hardwire the GPS to the bike. Duh. |
03-24-2008, 02:34 PM
#12 |
It's OK we know the Mayor
Oddometer: 265
A little dielectric greese on the contacts took care of the battery/shut off issue on mine. they sell little packs of the greese for $0.99 at most auto parts stores.
Bryce
"It sure beats working all week, boozing it up in some smoky bar or sitting around watching the world go to Hell in living color and still ending up, just before payday, flat broke as usual. That's only existing, not really living."-Don Marshall, Cycles South, 1971 '08 KLR650 - Blue 21 & '06 Ninja 650R - Galaxy Silver |
03-26-2008, 10:10 AM
#13 |
Oddometer: 604
Is there an advantage to hardwiring the GPS to the bike as opposed to installing a marine grade cigarette lighter receptacle. I assume when you say "hardwire" you mean to add a permanent wire to the battery that plugs into the back of the GPS using the standard 4 prong plug right?
Sorry for the Noobish questions.
03-26-2008, 10:36 AM
#14 | |
Oddometer: 3,982
Jerry Counts |
03-26-2008, 01:34 PM
#15 | |
Oddometer: 21,547
Because I use my 76CS for several applications, I'm installing a weathertight "Universal" plug in my power cable. I'll add a mate to that plug in my bike and truck's wire harness. I'll also put one on my NiteRider NiMH battery (I use that for LD trips in the canoe and kayak). |
