03-27-2008, 10:34 AM
#16 |
Oddometer: 802
Just an FYI... I had a 60CS wired to the moto, but left the batteries in anyway. After some months, when the unit was off the moto and powered by batteries the slightest tap would shut it off. The contacts looked good (no visible arc damage) and I sent the unit back to Garmin and they completely refurbed the unit (biffed up buttons and display bezel replaced!) under warranty. Their report said the contacts were damaged internally.
So I never run units on the moto that take AA's with the batteries installed. Next time the failure might happen after the warranty expires.... YMMV... |
03-27-2008, 04:57 PM
#17 | |
Oddometer: 3,978
Jerry Counts |
08-06-2012, 06:15 PM
#18 |
Supermoto Rider
Oddometer: 59
Just to bring this thread back from the dead, I'm having the same issue with my 60Cx.
6000RPM on my 1-cylinder seems to be the worst speed, about 75MPH in 6th gear. What I actually think is happening is that the vibration is messing up the unit's estimate of the battery voltage, as the battery meter appears to drop before the unit shuts off. After a shut-off, even hand-holding the unit the battery power may go out. I don't think it's a matter of losing power all at once, but the unit powering itself down when it senses the voltage dropping. Anyone switched to the Oregon, Montana, or Dakota after a 60CSX and been happy? |
08-06-2012, 07:59 PM
#19 |
Procrastinators
Oddometer: 5,780
Oh yes, but the Montana's the only one of the three you suggested which has a proper power connection, through a wired mount with surface connectors.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
08-07-2012, 09:30 AM
#20 |
Oddometer: 3,978
Is it hard wired to bike battery? If not do it and don't run internal batteries, much less mass and therefore vibration problems.
Jerry Counts |
08-07-2012, 03:30 PM
#21 | |
Oddometer: 1,203
If you use external power I would recommend disconnecting the tiny internal connector. Then try to clean the contacts on both sides and put dielectric grease on them too. And while you're at it clean the grease the contacts on both ends of the external power connector. |
08-07-2012, 04:02 PM
#22 |
earthbound misfit, I
Oddometer: 6,591
Don't give up on your 60 until you wire it to the bike's 12vdc. I got a montana 600 recently, while I like the bigger display I have to stop to use the touchscreen. I would prefer buttons.
http://www.youtube.com/watch?v=PZKIh5aCYCI |
08-07-2012, 04:49 PM
#23 |
Procrastinators
Oddometer: 5,780
I'm not sure why people think the power cable alone is going to put and end to the vibration related shutdowns on the 60. Mine continued to die with batteries and power cable hooked up. I didn't open my 60 to work on the internal connections, though.
08-08-2012, 12:25 PM
#24 | |
Supermoto Rider
Oddometer: 59
The 60Csx is still the best moto GPS Garmin has made as far as I can tell hardware-wise. The 62 series isn't impressing anyone, and I see the Montana as being the unit of choice on this board not because of the touchscreen but because of its top-of-the-heap feature set like those external power contacts that don't break the waterproof barrier. ...and all this just to get the unit to stayed powered on and alive on the bars where you can operate it, then there's the crappy old software and the problem of finding a decent set of maps that won't set you back half the cost of the unit every year. |
08-08-2012, 12:34 PM
#25 | |
Procrastinators
Oddometer: 5,780
But one major advantage of the Montana and the rest of the modern line is that you have a helluva lot more flexibility in the map loading, since they don't all need to be loaded at once into one file as on the 60/76 series and most of the other legacy units.
08-12-2012, 07:21 PM
#26 | |
Supermoto Rider
Oddometer: 59
I'm probably going to get a Montana with a proper mount as soon as I've had it with the 60Cx.
My Posts | My Videos on Vimeo | My Videos on YouTube | Supermoto Adventures | Ton-Up Washington |
10-12-2012, 04:22 PM
#27 |
Oddometer: 4,809
There are sponge rubber nose pads that you put on eyeglasses to make them more comfortable. I put these on the battery cover over the batteries and it snugged it up enough to stop the batteries from vibrating and losing contact
RIDE SAFE |
10-12-2012, 08:14 PM
#28 |
Procrastinators
Oddometer: 5,780
Often it's not the batteries losing contact; it's the battery terminals to main circuit board that loosens up. Your method will work in some cases of vibration induced shutdown, but not all.
10-13-2012, 09:12 AM
#29 | |
Oddometer: 4,809
RIDE SAFE |
10-21-2012, 07:29 AM
#30 |
Take off, EH!
Oddometer: 790
I also say to anyone, dont give up on the 60 yet. I guess im one of the lucky ones, Ive been running my 60 csx for years now on both my sled and bike with minimal issues, hard wired to both, with batteries in so it stays on when the ignition is off. Ive used both a cig. lighter plug and direct wire with both of them being direct wire now and good quality rechargable batteries.
The bike is my DR 650 thumper and the sled is a 800cc 2 stroke that appears to be shaking itself to death at idle, lol. Im sure mines checked out a couple times, more so on the sled I think, but mostly its been no issues, as I said I think Im one of the lucky ones as I have killed a couple legends before. If you can hard wiring is the key I think. Even on old or 2 stroke bikes it can be done, on the sled I made up a very simple rectifier to convert AC to DC to run the unit and even mounted a very small gell battery to store the power as well. I stole that idea from this unit http://snobunje.com/public/store.php...on=show_detail Good luck, Todd
"It's all about the beer" drcool 08DR650 - Jack of all trades, master of none Summer's going fast,Nights growing colder,Children growing up,Old friends growing older |
