Old 03-12-2009, 10:40 PM   #211
AZbiker
Crunkin' with crackers
AZbiker's Avatar
Oddometer: 6,916
Finally got my Connie to pass emissions after spending $400+ on the carbs.
What I've learned:
The K&L bowl seals are only useful to tie back long hair--they are a couple of mm too small in circumference to work properly.
The engineer that came up with the air-cut valve design needs a swift kick in the slats.
I hope this tank gets better than 30mpg. If not, I'm putting the goofy bodywork back on it and putting it up on the block. The only thing I haven't replaced in the carbs are the slides. At $400+ for all four, they just aren't worth replacing.
rubber side down,
derek
http://azbiker.smugmug.com
Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q
AZbiker is offline   Reply With Quote
Old 03-13-2009, 04:42 AM   #212
concours
WFO for 41 years
concours's Avatar
Oddometer: 4,015
Originally Posted by Z-rex1100
That's awesome.
Not often do you see touring bikes doing wheelies.
I could carry the front wheel on mine all the way through 1st...
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 03-13-2009, 11:46 AM   #213
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 6,768
Send a message via AIM to HaChayalBoded
I just ordered an ME880 for the front, since i'm running a 17" front tire I can't find a matching set of tires front and rear aside from the ME880s.
Any of your tires cupping horribly also? Seems to be a common problem.
Eddie
Stuff FS
'00 Harley MT 500
'93 Concours, extreme farkle (for sale)
'00 Shadow ACE Tourer (for sale)
'03 Shadow Sabre (Gone)
'90 Honda Hawk GT NT650 (Gone)
Lookin' for a (cheap) '95 GSPD Classic
I've been stranded in the combat zone
I walked through Bedford Stuy alone
Even rode my motorcycle in the rain!
HaChayalBoded is offline   Reply With Quote
Old 03-13-2009, 01:29 PM   #214
UPSam
All jacked up on Dew
UPSam's Avatar
Oddometer: 16,370
What I've learned:
I didn't even know they emission tested bikes in Phoenix
I don't think I got under 40 mpg going 90 mph on I10. 30 mpg is pretty shitty for a connnie.
"There was a lot of talk last year about how Barack Obama would be a “transformational” president — but true transformation, it turns out, requires a lot more than electing one telegenic leader." -Paul Krugman 8/30/09
UPSam is offline   Reply With Quote
Old 03-13-2009, 02:57 PM   #215
Gary B.
Older than dirt...
Gary B.'s Avatar
Oddometer: 542
Mine gets 45-50 every time I've checked it.
"Male menopause is a lot more fun than female menopause. With female menopause you gain weight and get hot flashes. Male menopause ? you get to date young girls and drive motorcycles."----- John Wayne
DR stands for "Daily Rider"
'06 Suzuki DR650SE
'06 Kawasaki Concours - 2up Cruiser
'99 Yamaha YZ400
'05 KTM 125SX-SOLD!!!
'90 KTM LC4-the bike's gone, but the memory remains, along with the oil spots on the floor
Gary B. is offline   Reply With Quote
Old 03-13-2009, 07:07 PM   #216
AZbiker
AZbiker's Avatar
Oddometer: 6,916
Emissions will probably end some time in 2010.
I know my mileage is crap, not sure yet what's causing it.
rubber side down,
derek
Old 03-13-2009, 07:29 PM   #217
concours
WFO for 41 years
concours's Avatar
Oddometer: 4,015
I always got 33 to 38 mpg....
2007 Tiger 1050
1973 Yamaha TX750
Old 03-14-2009, 03:09 AM   #218
AZbiker
AZbiker's Avatar
Oddometer: 6,916
32mpg last tank.
I don't think it's low compression, I don't burn any oil.
Float heights are good, it has new float needles, and one new air cut valve on carb #4. The valve on carb one looked fine, I pulled it. The fuel screws are all set @ 1.5 turns out.
I'm thinking it's either worn needles or slides. Has anyone ever heard of the Kehins eating needles like Mikuni carbs do?
The needles are "only" $21.24 each. If it's the slides, those are $101.39 each. Dammit. I hope someone just steals the damn thing at this point.
rubber side down,
derek
Old 03-14-2009, 09:25 AM   #219
UPSam
UPSam's Avatar
Oddometer: 16,370
32mpg last tank.
Valves could cause low compression. Former owner never adjusted them? Scorched a couple?
What do the test for on emmisions? Just particulates?
Make friends with somebody that has a dyno and a exhaust analyzer?
Nobody steals connies. Maybe a harley sticker on the gas tank?
Old 03-14-2009, 10:08 AM   #220
Audacious Nick
Forever indecisive
Audacious Nick's Avatar
Oddometer: 656
32mpg last tank.
I could arrange that. Just leave the key in the ignition, and have the title signed on the seat.
Bikes:
2006 Husky SM610
2000 Honda Superhawk
Audacious Nick is offline   Reply With Quote
Old 03-14-2009, 12:25 PM   #221
AZbiker
AZbiker's Avatar
Oddometer: 6,916
They were all tight when I checked 'em. You may have a point.
They do a 2-gas test here, CO & HC. I may have a lean misfire, I dunno.
Last test my CO was at .39% and HC was at 1644ppm.
FWIW, my 60,000 mile XLH883 puts out 1.5%CO and 700ppm HC.
I'm rediscovering that used Asian bikes are maintenance-intensive and fragile.
rubber side down,
derek
Old 03-15-2009, 11:58 AM   #222
ROKSTAR
Whoring it up
ROKSTAR's Avatar
Oddometer: 356
Thoughts on a '92 Connie with 33K that needs fairings for $1300?
- gonna need the lower front fairing, front fender, and misc.
ROKSTAR!
'92 Yamaha Seca II (new sport tourer)
'03 BUELL XB9S Lightning (hooligan )
ROKSTAR is offline   Reply With Quote
Old 03-15-2009, 01:34 PM   #223
UPSam
UPSam's Avatar
Oddometer: 16,370
You can get a much newer complete bike for $3500. Check Ebay for what those parts go for. Insurance companies total connies for minor tip-overs which gives you an idea.
33k is not a lot of miles. 16 years old is old though. seals and gaskets start going. carb problems.
http://www.concours.org/
check the forums
Old 03-15-2009, 08:46 PM   #224
HaChayalBoded
Brooklyn Bored
Oddometer: 6,768
depends, when you say lower fairing, do you mean the belly pan or lower side fairing? The lower fairings are very cheap, the mid and upper fairing are expensive.
Eddie
Stuff FS
'00 Harley MT 500
Old 03-16-2009, 03:36 AM   #225
ROKSTAR
Whoring it up
ROKSTAR's Avatar
Oddometer: 356
I mean the fairings above the belly but below the main fairing that holds the headlight.
ROKSTAR!
Times are GMT -7.   It's 01:03 PM.
