Closed Thread
Old 03-28-2008, 10:44 PM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb LOOK HERE FOR FORUM CONTENTS GSpot FAQ
GSpot Frequently Asked Questions
Welcome to the GSpot FAQ!
Some questions have been asked, and answered, more than once in GSpot. We have collected quite a few of them, together with the answer that will (or should) be given. You might find you favorite question already answered.
This GSpot FAQ has seven parts. The parts are:
  • Part 1: Introduction, global Table of Content, and Trivia (this post)
  • Part 2: Terminology here.
  • Part 3: Mechanical here.
  • Part 4: Brakes and ABS here.
  • Part 5: Oil here.
  • Part 6: Modifications here.
  • Part 7: Miscellaneous here.
A valid first question is: Why is it split over seven posts? The answer is that there are so many FAQ that the original post exceeded the maximum allowed in the system.
Now, on to the Real Stuff:
Whether the bike has ABS or not is in fact indicated in the model. Thus we have
  • GS (bare bone)
  • GSA (GS with ABS)
  • GS Adventure
  • GSA Adventure (a GS Adventure with ABS)
However, here in GSpot barely anyone pays attention to the official names of the models. Here, GSA almost universally means "GS Adventure". The GSpor FAQ advice is "si fueris Romae, Romano vivito more; si fueris alibi, vivito sicut ibi" (info here).
However, whenever you ask about brakes, always make it clear in one way or another, if you have ABS or not.
Table of content
Part 1: Trivia (at the bottom of this post)
1.1 Why is it called GSpot
1.2 Units of measurements
1.3 Legal Notice
Part 2: Words and Terminology
2.1 Acronyms
2.2 Wisdom
2.3 n00b
2.4 Who is GB
2.5 Who is JJ
2.6 ADV sticker (decal)
2.7 Hexhead
2.8 Oilhead
2.9 Airhead
2.10 Camhead
2.11 Wethead
Part 3: Mechanical
3.1 Part numbers
3.2 FD failure (with repair)
3.3 Spark plugs
3.4 Mileage
3.5 Cruise control
3.6 Service plan
3.7 Can I do maintenance / service myself?
3.8 Warranty
3.9 Charcoal-canister
3.10 Replace alternator belt
3.11 Replace front fork seal
3.12 Change tyre
3.13 Tires
3.14 Tires
3.15 HID lights
3.16 Horn
3.17 My 1150 stops
3.18 Warming up the engine
3.19 Fuel filter hose clamps
3.20 Oil in the airbox
3.21 Pushed rubber plug from timing hole into engine
3.22 Lights on left- vs. right-hand models
3.23 CANbus
3.24 Doesn't start / no spark
3.25 EWS Failure
3.26 Smoke from exhaust
3.27 Running rough after (unrelated) repair
3.28 Bypass the fuel pump controller
3.29 Torque value bar riser bolt
3.30 Throttle cable
3.31 Surging
3.32 Over tighten bolts (wheel bolts in particular)
3.33 Replacing the front fork seal
3.34 Fixing the fuel gauge on the 1150
3.35 Replacing the clutch slave cylinder
3.36 Flushing oil in the the clutch
3.37 Engine running; Noise on left side (chain tensioner)
3.38 Display says bulb broken, but it works
3.39 Part number for center stand lowered 12GS
3.40 Are the 11xx rear wheels interchangeable
3.41 What are the valve settings, in INCHES
3.42 Which parts to bring along when riding
3.43 My fuel indicator does not work, or does not work correctly
3.44 Can't I get crush washers for my 12GS any longer?
3.45 Will heated grips from F800 fit the 12GS?
3.46 Turnsignal (cancel) button (switch) not working
3.47 I need more light, can I use a stronger bulb
3.48 Fuel pump problems
3.49 Replace air filter on 2011-model
3.50 Can the battery in the TPMS be replaced
4.1 Description of ABS and bikes
4.2 "Clank" upon starting
4.3 Is ABS on?
4.4 Reset ABS
4.5 ABS, ABS-2, I-ABS-1, I-ABS-2
4.6 Turn off ABS
4.7 Flashing ABS lights
4.8 Bleeding breaks
4.9 EVO and ABS
4.10 Is ABS good?
4.11 Removal of ABS
4.12 Changing pads, front
4.13 Other ABS problems
4.14 Grub screw
4.15 Servo issues
4.16 Servo pump continues to run
4.17 Repairing the ABS-pump
Part 5: Oil
5.1 How much oil in the engine
5.2 Part number of oil filter
5.3 Washer
5.4 What oil in the engine
5.5 How much oil in the transmission
5.6 How much oil in the FD
5.8 What kind of oil in the FD?
5.9 Can I use 75W140 in my FD?
5.10 Change oil in the FD
5.11 Overfilled engine
5.12 Dino
5.13 Oil consumption
5.14 How much oil is in the engine
5.15 How hot is the oil
5.17 Oil in the air box.
6.1 More fuel into the tank
6.2 LED turn signals
6.3 Can I replace the Adventure fogs with new LED-ones from BMW?
6.4 How to raise the seat on the 12GS
6.X Well documented modifications
7.1 BMW roadside
7.2 Other resources
7.3 I'm buying a used bike, what to look out for?
7.4 How to rekey the Vario panniers (hard luggage)
7.5 How to trailer and tie down a GS
7.6 I have another question!
PART 1: TRIVIA
1.1 Why is it called Gspot?
Because GS is the name of the bike, and this is the spot where it is
discussed. No other connotations have been considered.
1.2 Measurements
Beacuse BMW is based in Europe, measurements in the GSpot FAQ are metric: bar, gram, meter (distance and volume) and liter. However, we will try to remember to convert to psi, unces, feet and gallon.
Of the three gallons in use, we will use what is called a US Gallon (and thus not Imperial Gallon) This is 3.785411784 (exactly) liters.
If you wonder why BMW uses metric, watch this.
1.3 Legal Notice
This FAQ has been put together by a professor in computer science with no formal training in mechanics. It is offered here solely for entertainment purposes. As this FAQ includes forward-looking statements such as “believe,” “estimate,” “anticipate,” “plan,” “predict,” “may,” “hope,” “can,” “will,” “should,” “expect,” “intend,” “is designed to,” “with the intent,” “potential,” the negative of these words and such other variations thereon, and also comparable terminology, you are advised to obtain legal and mechanical council before basing any actions or decisions on this FAQ.
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk screwed with this post 01-02-2013 at 06:21 AM Reason: Fuel gauge
tagesk is offline
Old 03-28-2008, 10:47 PM   #2
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 2 (Words and Terminology)
This is Part 2 (of seven) of the GSpot FAQ. In Part 1 (here) you will find the Table of Content.
PART 2: Words and Terminology
2.1 Acronyms
ASC : Automatic Stability Control. Stops your rear wheel from spinning.
Uses the same mechanisms to detect spinning as ABS uses to detect
blocking. Becuase it can prevent you from a experience a low-side it is deemed
a safety item. 1200GS only.
ATGATT: All The Gear, All The Time = Never ride your bike without your protective gear (hemlet, gloves, etc.)
DWA
: Diebstahl Warn Anlage = Theft warning system
EWS : Elektronische Wegfahr Sperre = Electronic immobilizer lock
FD : Final Drive. Where the drive shaft arrives at the hub.
GS (As in R1150GS): It's short for Gelände / Straße, also written Gelaende / Strasse if you don't have the proper set of fonts.
GS thus seans “Overland / Street” or perhaps "Terrain / Street" depends on how you interperet the word Gelände, which can mean area, land, and other
not-quite-right-for-the-mission meanings.
Another, equally likely, meaning is
Geländesport which means something along the lines of enduro in German. This view is supported by this article.
Pronounciation is like G'- lehn-deh Strahss-eh. Please don't say the last "e" in the words with an "uh" sound! It goes "eh," which almost, but not quite, sounds like the "a" in "say." Saying "Strah-say" is much better than "Strass-uh."
HES : Hall Effect Sensor. It signals th
e Motronic computer when the crankshaft is at TDC and BDC. It's located behind the lower pulley of the alternator belt.
OVAD : Oilhead Valve Adjustment for Dummies.
Valve adjustment is part of routine maintenance of BMW boxers. This document can be found here, and is part of Wisdom (see XX).
RDC:
Reifen Druck Control (Tyre Pressure Control). The system used to warn you about falling tyre pressure.
RTFM
:Read the Fine manual. In most cases this implies that the answer to your question is written in large and friendly letters in the Fine Owners Manual.
For a suitable definition of Fine.
STFU : Shut your Terribly Foul mouth Up
TBS : Throttle Body Synchronizing. See TBSD.
TBSD : Oilhead Throttle Body Synching for Dummies.
This is a document available in Wisdom.
TT : The company Touratec.
ZFE : Zentrale FahrzeugElektronik = Central Vehicle Computer
2.2 Translation from German to English?
Many terms in the GS-world is in German. A translation of many of them to English can be found in Wisdom in a document
named BMW Tech Terms. Wisdom? Check the question below. In any case, link here.
2.3 What is Wisdom and where can I find it?
At the very bottom of every page on ADVrider, there is a (too) small
banner of links. One of them is Wisdom. The link is here.
2.3 What is n00b (november-zero-zero-bravo)
Wikipedia says: Newbie" can be used as a term to identify
newcomers to a game, place, or organization. The variant spellings
of "newbie" are also used, especially in online games, as a
catch-all insult regardless of the recipient's actual skill or
experience. Someone who acts like a "newbie," but isn't one would be
referred to as one of the variant spellings. The variant "noob" has
become common in spoken English by juveniles. Alternate spellings
include "newb", "n00b", "noob", "nooblet", "nub", and the recently
popular "nublet." These alternate spellings of the term, other than
"newb," inherit the definition of "newbie" but are generally used in
a derogatory manner to indicate uselessness because of the ignorance
associated with being a newcomer.
As most inmates here are grown-up's, n00bs are generally treated
very well. Be polite, ask quetions and be prudent about making
statements (that is, try "is it not true that X" rather than "It is X!"), and you'll be fine.
2.4 Who is GB?
GB is short for Gadget Boy, which is the user name of one of the
moderators in GSpot.
2.5 Who is JJ
JJ is short for Johnjen, which is the user name of one of the moderators in GSpot.
2.6 How can I get one of those cool ADV stickers on my bike?
Those cool decals (as they are called here) are made by GB. The
first post in this thread contains
pictures and order information. That first post is edited to keep
it up-to-date. Ignore all other posts in the thread.
2.7 What is a hexhead?
The R1200-series engine has cylinder heads that, when viewed from
the side, are somewhat hexagonal.
2.8 What is an oilhead?
The R1100- and R1150-series of engine is partly cooled by oil, as
opposed the earlier versions which where only cooled by air. Thus
they are called Oil-heads.
2.9 What is an airhead?
Older, air-cooled BMW boxers.
2.10 What is a camhead
The 2010 model 12GS saw a new engine design. With cams "in" the head. Not surprisingly, they are called camheads.
2.11 What is a wethead?
The 2013 model 12GS saw a new engine design. With water cooling. Not surprisingly, they are universally referred to as wetheads.
IBA: 33616
tagesk screwed with this post 03-28-2013 at 01:24 AM
tagesk is offline
Old 03-28-2008, 10:49 PM   #3
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 3 (Mechanical)
This is Part 3 (out of seven) of the GSpot FAQ. In Part 1 (here) you will find the Table of Content, and links to all the relevant sections.
PART 3: Mechanical
3.1 Where can I find part numbers?
From Hammersley Cycles here.
From MAX BMW here.
From RealOEM here.
A&S BMW Motorcycles here.
Sometimes you will need to know the production month of your bike, when changes were made mid-production. You can find this on your VIN sticker
or, in most cases, plug the last seven characters of your VIN (something like ZB12345) into the website to get the same info.
Parts within the B
MW system are organized by Main Group (11 is engine, 23 is transmission, 46 is frame, etc) although you might not see the
numbers themselves. Keep in mind that what you're looking for might not be in the group you think it should be in. For instance impact protection stuff
might be under engine (skid plates, valve cover protectors) or frame (crash bars). Likewise the flywheel on a pre-81 bike is in Engine, but the
equivalent on a newer bike is in Clutch.
In addition, you will find the torque values here.
Regarding this list of places to obtain part numbers, the following important reminder was received from a fellow traveler:
Question: How can I consistently determine correct current part numbers for single replacement items or groups of related items for my BMW bike?
Answer: Without the help of an adequately skilled BMW dealer parts guy with current access to dealer-only web-based and phone-based information systems, you will eventually encounter situations where no consumer-accessible online info source gets the job done. Real-OEM is about as good as it gets, and usually contains what you need.
Caveat Emptor!
3.2 What is FD Failure?
The design of the FD has a weakness that it makes is prone to failure. It seems
that the design requires exceptionally careful assembly which might
or might not be adhered do. Quite a few FDs have failed, although
we do not know how many. Some say 4% and some say 10%, some quote much higher numbers.
First the good news: If your FD fails, you will almost always notice in advance.
That is, it is not a sudden failure where something "breaks". It is almost always proceeded
by changes in the colour of the oil in the FD (which should be
changed every time you change the oil in the engine), and with
increased play (horizontal and vertical) in the wheel.
Every BMW with a driveshaft will have a failure if the tell tale signs of worn bearings aren't observed and rectified.
Failure at low mileage is unacceptable. Part of the problem is not having a manufacturer's recommendation on when to
replace the FD bearings, so folks ride and ride and ride till the bearing / bearings fail and voilà, an FD failure. There is
such a thing as preventative maintenance but since one cannot visually inspect the splines or the bearings, worn bearings
tend to go unnoticed till they fail.
That being said, the issue of FD failure often stir up very heated
discussions. Owners of BMWs simply expect them not to fail, and
many are disappointed. Only BMW knows how many have failed.
On the other hand, it should also be noted that the nature of discussion forums such as ADVrider inflates problems
because they are discussed over and over.
How to fix a failed FD yourself is here.
3.3 Which spark plugs can I use?
XXX: Shall we list only what the documentation says, or also what is deemed "equivalent"?
1100 :
1150 : BMW, the designer and manufacturer, specifies NGK BKR 7 EKC.
1200 : BMW, the designer and manufacturer, specifies NGK: DCPR8EKC, DCPR8EIX or Bosch YR5LDE.
That being said, here is a list of spark plugs that are believed to work equally well (or better) on the 1150 at least:
Bosch FR5DTC
Bosch FR6DDC
Bosch FR6LDC
Bosch YR6LDE (snd of twin spark models)
Bosch FR6DP1
Bosch FR6DS (silver)
Bosch 4417
Bosch 4418
NGK BKR7EKC
NGK BCPR7ET
NGK BCR6EIX-11 (iridium)
NGK IZFR6 B (iridium use at your own risk, very long protrusion, does NOT touch piston, sleep well)
Autolite 3923
Champion RC7YC(C)
Champion RC8YCC
Champion RC9YC (-4)
Spark plugs for REAL EMERGENCY ONLY on the road: CHAMPION RC12YC
Denso iridium IQ20 hot
Denso iridium IQ22 cold
Denso iridium IK20 hot
Denso iridium IK22 cold
Brisk DR15ZC hot
Brisk DR14ZC cold
Brisk DOR14LGS
Brisk DOR12LGS very cold
3.4 What mileage are you getting?
Obviously this varies wildly depending on temperature, tyres, riding
style, and so on. The numbers are meant to indicate what the inmates here regard as normal. That is, if your mileage is
more or less identical to these numbers, you need not ask if yours are normal.
1100:
1150 one-spark: 17 km/l - 40 miles per gallon
1150 Adventure: 16.5 - 17.5 km/l - 39-42 miles per gallon
1150 two-spark:
1200: - 18 km/l - 42 miles per gallon
3.5 Can I have cruise control?
Yes you can http://www.mccruise.com/
3.6 What does the dealer do to the bike when it is in for service?
R1200GS service sheets can be found here.
R1200GS 6.000 miles (10.000 km) service can be found here.
For the R1150GS, here are some videos that might be helpful. They show 600 mile (1.000 KM) service, ignition timing/Hall sensors, Throttle Body Synch and V-belt adjustment.
3.7 Can I do the maintenance / service myself?
Consensus is that it is not very difficult to do your own service and many, if not most inmates here, do it themselves.
3.8 Will doing my own maintenance void the vehicle warranty?
In the US, the vehicle manufacturer (BMW motorcycles in this case) can not demand (by linking it to the warranty) that you use a specific shop for your maintenance, without also paying for the cost of service. Thus, in the US, you can do your own BMW motorcycle maintenance without affecting warranty. You should probably keep meticulous records of what you do, how you do it, which oils, and so on.
Verify the legal situation in your own country. And pay attention to the "LEGAL NOTICE" at the end of this post.
3.9 My bike has a charcoal-canister; can I remove it?
Yes. In the US, doing so might not be legal. Description of how to do it can be found here for the 1200 and here for the 1150.
There is, however, at least one compelling reason to keep i t. When the content in the tank expands--due to heat, for example---air and vapour is forced out
(though the canister). The purpose of the canister is to trap fuel-vapour so it doesn't escape and harm the environment.
When the content in the tank contracts--due to cooling, for example--air from the outside is deawn into the tank. This also happens when the content of the tank is consumed (as happens in normal operation).
Since the purpose of the canister is to trap vapours, and it is highly efficient, it also hinders humidity from getting into the tank when air
is drawn in.
Or, in other words: The canister is an efficient way to prevent the tank from rusting.
3.10 How do I replace the alternator belt?
For the R1150GS it is described here.
3.11 How do I replace the front fork seal?
3.12 Is it possible to change a tyre yourself?
It is indeed; look here and here for a pictorial.
3.13 What tires can I use?
Comparison of many tires can be found here. Anton Largiader offers BMW approved tire list. The latest version is here.
If youalso want to see the tires, then this thread is for you.
3.14 I have another question about tires
Then this thread is for you.
3.15 Can I install HID lights on my GS?
Yes you can; pictorial here. Notice that there are legal implications when changing the lighting equipment on any vehicle. In particular, upgrading from halogen to HID without further ado is not legal in many countries.
3.16 My horn is too weak, can I have another?
Yes you can, see here. If you are on the R1200GS pay attention to where you obtain the power.
3.17 When I turn the handlebar the engine stops
1100/1150:
The wires that emerge from below the key can become worn over
time. In particular at the first strap. If they break the engine will stop. If you can't solder you need: 61322306103; ignition switch & harness.
3.18 Warm up the engine?
No! The owners manual says: Do not run engine warm by idling. Ride off immediately after starting. The GS is air cooled and might overheat quicker
that you would imagine if there is no air-flow over the engine. Never leave the bike unattended while it idles. If you do not believe that a GS will overheat
if left to idle, check out this picture. This R1150GS was left to idle for ten minutes.
Or, When I change my fuel filter, can I reuse the clamps?
Or, When I change my fuel filter, can I use any clamps?
The crimp-on clamps are once-only and you should not reuse them even it is known that with creative use with pliers you can get them back on. Here are the part numbers:
16121176918 non-reusable crimp-type clamps (originally fitted)
13311460928 perfect fit to replace the originals. Reusable.
Also you might want to consider replacing the large gage-plate o-ring. The part number is 16141341008
3.20 Valve adjustment: Can I damage the bike?
In general, the answer is no. If set so tight that the vales might be damaged from overheating, you will have a hard time getting the bike to run as it will poor compression. If set too loose, it will not start at all.
3.21 Pushed the rubber plug covering the timing hole into engine
Consensus is that you can leave it in the engine. It will fall to the bottom and remain there. No damage to the engine due to this has been reported.
Many have substituted the plug with the one that came with the 1100 engine. That plug has a different design, and is virtually impossible to push into the engine. The part number for that plug is 11111744327.
Furthermore: No damage is known to occur even if you ride (for a while) without the plug.
The opening isn't into the engine itself.
3.22 Is there any difference in the headlight for the GS sold in Left hand and Right hand drive countries?
Yes. The the low-beam throw the light far along the shoulder of the road, and the sholder in question is, as you can imagine, not on the same side in left- and right-hand side drive. The lens takes this into consideration. Thus they are different. This has been confirmed by the part numbers explicitly stating RHD and LHD.
3.23 CAN BUS
Regardless of what you might hear from old-time mechanics, CAN bus is a technology the tremendously simplifies the design and maintenance of vehicles. The problem is that when you add more and more electronics to the bike, the numbers of wires, relays, switches, fuses and so on go up dramatically. CAN stands for Controller Area Network, the the network is a bus. Thus names CANBUS.
The CAN BUS is just a wire, and the design of the protocol running on the wire is robust and reliable. You can not, however, dig into it's inner working with a wrench. But you can't fix your trip computer with a wrench either, so electronics on bikes are not a new thing. When you hear "The CAN BUS" failed and...." it is almost never correct.
A good introduction to the technology, and why it is needed, can be found here.
3.24 Bike cranks but doesn't start - no spark
If your bike has power and the engine turns, but it refuses to start, and if you ground a spark plug and see that there is no spark, a common cause is a HES failure (see Acronyms above). There is a document in Wisdom (see above) on how to change the HES. For your convinience, the document is here.
3.25 EWS failure
1200GS only.
The key has a code in it. The
main computer on the bike only allows original keys to start the
engine (in other words, it is not sufficient to be able to turn the
key in the lock). The key contains a small radio antenna. The
bike has a ring-formed antenna which is situated on the lock. That
ring-antenna is used by the bike to communicate with the key.
If the ring-antenna fails (mechanical or electrical) the bike is
unable to verify an original key is used, and will not start. This
is signaled on the display as EWS failure. The ring antenna must
be replaced. There is no way to start the bike without having a
working antenna so the bike can communicate with the key.
Or, in other words, if your ring antenna fails you can install a
temporary ring antenna, disconnect the original one, store a spare
key in the temporary ring antenna, and start the bike. A photo of a
bike with a failed ring antenna, where a spare ring antenna has been connected can be seen here.
The part number most frequently used are 61357714207 and 61357717136-01. However, one inmate
has recently reported that BMW now labelles this part as 61357705247.
When ordering a spare antenna for your bike, BMW (seems!) to make sure you get the latest version.
What the differences might be between these parts are unknown (to us).
3.26 Smoke from exhaust pipe
If you leave your bike on the side stand, it is normal that some smoke comes out of the exhaust when you start it. The smoke is oil that accumulate in the left cylinder.
Here is a real question
Originally Posted by RealUser
This morning I went to start my 01 R1150GS and it's only running on one cylinder. I appears to be the left one.
Last night I moved the tank around to install a carbon fiber intake, so I never even went by the right side.
This afternoon I removed the tank and checked the plug wires and they seem to be connected.
In almost all cases where the bike doesn't run properly after having being worked on, in particular if the tank has been removed, the reason is that
one of the throttle cable isn't properly seated in the throttle body. Before checking that there is fuel in the cylinder, that there is spark and so on,
check both throttle cables where they end in the throttle body.
1200GS / GSA only.
If the fuel pump controller fails for some reason (water inside, for exampl), the fule pump will not run and the bike fail to start. The controller can be bypassed to get the bike moving again. Links here and here (both are posts at ADVrider.com).
3.29 Torque values Bar Risers bolts
I just received the torque specifications from my dealer for the 2008 12GS Bar Riser bolts, for those interested in flipping the risers/bar position "on the fly":
10mm Bolts (Positioned Forward in "Normal" mode): 36 N-m
8mm Bolts: 16 N-m
3.30 Throttle doesn't snap back
When new, the throttle will snap back if you release it. After a while, it doesn't. If it really stuck, you will have to deal with it. The job, however, is not easy. The Bowden box is hidden below the ABS unit, there is very little space, and the assemblies at both handlebars must be taken apart.
Do not try to grease the wire. The cable has teflon on the inside, and any grease will quickly clog the wire. If one of the three cables cable are the culprit, they must be changed.
3.31 Surging
Surging is when the bike will not keep a steady speed, but surge up and down. It can be very, very annoying.
Because it has two independent throttles, the boxer is very prone to surging. It is mostly felt the the engine is running almost without load, at medium speed (that is, at 50 km/h in 3rd).
First observation: If everything is OK, the bike should not surge (or only marginally).
Here is a list of well known prime suspects (all these should be checked before you even consider taking the bike to a dealer):
  • The end-rocker and valves must be adjusted.
  • The two sides must be balanced (provide the same amount of air). Check out Wisdom on how to do the balance.
  • The coils must be checked. In particular if you have four sparks.
  • The throttle bodies must not leak air. You check this by spraying WD-40 or equivalent on the TBs while the bike is running.
    If some is sucked in you'll hear the idle change.
  • Replace the plugs (set the opening to 0.8 mm). Notice that the gap is curved; the gap should not be less that 0.8 mm at any point (and not larger).
  • Replace the oxygen sensor. It is a Bosch Universal Oxygen Sensor 15729 (~$65 at auto parts store)
For the 1100 here are two additional tips:
  • single electrode spark plugs had the biggest effect to reduce it. I used Bosch FR6DC and FR6DC+ (more durable).
    Bosch FR5DC is one grade colder and gave me the impression of slightly reducing pinging.
  • New lambda sensor almost completely removed surging (I would dare say 99%), in conjunction with single electrode spark plugs. I used Bosch 0258986506-36Y generic lambda sensor. The package contains a connector to use with the old harness.
3.32 What happens if I over-torque a bolt
Some bolts, the wheel bolts in particular, are prone to being over torqued. It is easy to think "I'll pull them real hard, for safety".
That, however, is not at all safe. The values have been set with great care.
Check out this post for details of the danger.
Note with great care that the torque value (110Nm) assumes dry threads. If some lubricant has been added, and the lugs are torqued to 110Nm, the bolts are over-torqued and might stretch as shown in the picture referenced above.
3.33 How to replace the front fork seals
First, do recall that the front forks are empty. There are no springs inside. The GS has telelver the the
spring is attached to the shock underneath the tank. Or, in other words: Replacing a leaking seal is simple.
Detailed instructions can be found here.
You fill the tank, but the fuel gauge doesn't show all bars?
The low-fuel light doesn't come on, even though there are no bars left on the display.
Probably the contacts inside the pump is corroding. Everything you need is here.
Detailed procedure here.
3.36 Flushing the clutch hydraulic oil
1150 only
The oil in the clutch should be replaced (flushed) as part of regular service.
A detailed description of how to do it, with a Mityvac, can be found here.
The thread has very good photos.
Notice that many, maybe most, replace the grub screw and place a standard nipple there instead (see question 4.14 about the grub screw).
If you don't have a Mityvac, you bleed as you bleed the brakes (that is: carefully apply pressure on the lever, open nipple to let the fluid out,
close nipple while NOT letting out the lever, repeat).
3.37 Engine running: noise on left side (timing chain slapping)
On the 1150 the chain that drives the cams is dampened by oil in a cylinder.
If your engine starts to get noisy on teh left side, in particular when hot, it is probably time for
a chain tensioner upgrade.
Very detailed description, from a sickening clean bike, here.
The new part is rather expensive, and there has been some success with only changing the
spring. A new spring seems to be about 5 mm longer than the old one, and this seems to help a lot.
You need
Spring:T99V00F 11-31-1-341-015
Gasket Ring:0785 07-11-9-963-308
Long discussion about the parts in question, here.
3.38 Yellow triangle lights up on display, but bulb work
(1200, and 1150 from 2002 and onwards)
BMW performed some electronic magic. If the tail light filament fails, the brake light filament will be illuminated at a reduced
output to make up for the loss until the bulb is replaced. This makes it appear that the bulb is okay.
Low stand to fit lowered 2007 R12GS non-Adv is: 46527712774.
Note: BMW's parts catalog incorrectly depicts both this stand and the non-low 46527684948 stand as horseshoe-shaped, rather than H-shaped.
3.40 Are the rear wheels interchangeable?
11xx only:
All rear wheels are the same. Very late wheels have a different ABS sensor ring, which can be fitted to the earlier wheels.
3.41 What are the valve settings, in INCHES?
As we know, the valves need to be 0.3mm on exhaust and 0.15 mm on the intake.
If you live Over There you might not have metric gauges, but if you have .006 and .012 in
inches that is WAY close enough.
3.42: Which parts to bring along?
If you are about to set out on a very long ride, it can be tempting to haul along some spare parts.
Which ones?
In general everything can break. Thus, to be absolutely safe, you must bring along everything. And all the tools you can imagine.
Most find that bringing along spare parts is a slippery slope; if I bring this, why not that?
The GSes are very reliable bikes. Make sure your bike is well maintained before you depart.
In particular, make sure the cables are good, fluids aren't getting dirty too quickly, etc. Check the pivot bearings or just
replace them. Replace the alternator belt. Make sure all of the scheduled maintenance items are fresh.
Shocks not leaking. Fork seals dry and not rusty under the dust caps. New brake pads. Lube the centerstand and sidestand.
Then, just ride away.
You could, however, bring along one part: a final drive bearing. The issue with this part
is that it is easy to replace, but hard to get hold off, and no alternate part exists.
You will need a kit with tire-plugs. Practice on how to use them before you need to know!
How are you going to inflate the tire?
Make sure you have a spare keys installed on the bike somewhere. Ignition and panniers. Make sure
you can get to the key without tools (which are in your locket panniers).
or: What is the Fuel Strip problem?
In 2007 (thus on the 12GS) the mechanical float mechanism inside the tank was replaced by a strip.
The problem is that it can (and do) fail. Can not be repaired and must be replaced.
We (as in the GSpot readership) do not know how many have failed, but it seems to be fairly common.
When it fail it does not effect the bike in any way (except, obviously, that you can not rely on your
fuel gauge any longer).
Replacing the fuel strip seems to be simple. It is described here. In that thread you will find that the
part number is 16 14 7 675 547.
If you go to a dealer to get new crush washers for the trans and final drive, it is very likely that
you will be told they are not sold any longer.
You are advised to buy a new non-replaceable nut with non-replaceable washer.
These are OK, but they are expensive.
Option one: Ask for
07 11 9 963 200 - washer for trans drain plugs
07 11 9 963 300 - washer for trans fill plugs
They have them (because the 11xx series uses them). But you need to know the part number.
Option two:
Get the new plug(s). Then, later, you can simply cut off the washer that is attached to them (and use the part numbers above).
Yes. See this thread.
Inside the handlebar fittings, there are several small switches.
No alternative source of them are known.
They can be serviced. See this post.
No. The problem is that there is not enough cooling to disspasiate the extra heat.
At least one user has reported a melted plug with a 80W bulb.
More light is obtained wither with Xenon (HID) or auxellary lights.
Note that installing Xenon in teh low beam is not legal.
3.48 Fuel pump
Twice as much as you ever need to know about the fuel pump can be found here.
On the cam-head, the air-filter is no longer under the seat.
Detailed descriptions are here.
Yes; see this thread.
IBA: 33616
tagesk screwed with this post 08-18-2012 at 09:20 AM Reason: Fuel strip replacement.
tagesk is offline
Old 03-28-2008, 10:51 PM   #4
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 4 (Brakes and ABS)
This is Part 4 (out of seven) of the GSpot FAQ. In Part 1 (here) you'll find the Table of Content with link to all the other parts.
PART 4: Brakes and ABS
Before reading any of the answers below, it would be an advantage if you know which type (yes, there are several) of ABS
you have on your bike. If you do not know if your bike has ABS, check out the question "Does my bike have ABS?".
ABS-II: The non-servo ABS installed on the 1100/1150 models.
I-ABS (Integral ABS):
- This is the ABS with linked servo brakes
- 'i' for integrated. BMW term for linked brakes.
- The brakes are linked on the street models. The front brake lever operates the rear brake too. And the rear brake lever operates the front brake too.
- The GS brakes are only 1/2 linked. The front brake lever operates the rear brake too. The rear brake lever only operates the rear brake.
- Not sure, I think it was first installed on the RT in 2002
- The GS, and I think also every other model, had the iABS servo brakes by 2003
I-ABS-II
- Same linking function as iABS except no servos. Fitted on the 1200 from 2007.
4.1 Does my bike have ABS?
If your bike has ABS there will be a ring with small studs attached to your front wheel inside (smaller diameter) the brake disc
(called rotor by some). In addition there will be a button on your handlebar (1100/1150: Right-hand side, 1200 left-hand side) labelled ABS.
in addition, on the 1100 and 1150, you have two red lamps labeled ABS.
The red ABS lights should blink (as a pair) when you start the
bike. As you start riding, they will go out.
4.2 I hear one or two 'clank' when I start riding
1100/1150 non-servo ABS:
This is part of the ABS-unit self-test. Furthermore, if you ride
for more than seven minutes and come to a complete halt, when you
start up again the ABS will self-test again with the same 'clank'.
4.3 How do I know if ABS is turned on?
If you have ABS, it is turned on unless there are red warning lights
blinking. That is, the ABS is always on, unless you explicit turn
it off.
4.4 How can I reset the ABS?
1100/1150:
  • Locate round adapter on top of air box.
  • Ground out the brown/blue wire at pin #2. You can stick a wire in it and put it to a GOOD GROUND.
  • NOW turn key on.
  • NOW hold ABS button down for 10 seconds, count slowly.
  • NOW release button.
  • Only NOW turn off key.
  • Only NOW remove ground wire you added.
Write this down in your handbook. Don't have a handbook? Get one!
4.5 What is I-ABS, and what is the difference between I-ABS I and I-ABS II?
I-ABS is the servo assisted ABS brakes (power assist) which has been
controversial and a source of endless discussions here.
BMW has now done away with it and replaced it with what feels like
regular brakes with ABS and the semi integral (linked function) and
this comes on '07s.
4.6 Can I turn off the ABS?
Yes, you can. And if you are riding downhill on gravel, you probably should turn it off. Notice that ABS is considered a safety
feature. Thus, when you turn it iff, you will be warned (the light does not go out). This is by design.
1100, 1150
Turn off the bike. Turn the key to on (but do not start the engine). Press and hold the ABS button for a few seconds. The red
ABS light will come on. Start the bike. The red light will not go out in order to warn you that the ABS is not engaged.
To re-engage ABS, turn off your bike and start as normal.
You can also remove the ABS relay in the fuse box. It is relay number XXX
1200:
If you have servo:
Push the ABS button, THEN turn the key (while you hold the button), and start the bike. Let up the button and the light
stays on letting you know it has disabled the ABS. To re-engage ABS, turn off your bike and start as normal.
If you do not have servo (2007 and newer): Come to a complete stop, push and hold the ABS button until the ABS light ignites.
The light will be your reminder the ABS has been turned off. To re-engage, draw to a complete stop and press and hold the ABS
butten. The light will go out and self-test will occur as normal.
4.7 Both my ABS lights are flashing after having started the engine.
1100/1150
First, the two lights will always flash together (not alternating) after the engine
has been started. When the bike reaches a speed of 5 km/h you can hear a "clank"
and the light go out. The "clank" is the ABS system's self-test.
The lights are flashing (alternating):
The ABS is a very sensitive system, and it does not take much for it so fail. In particular, if
your battery is slightly weak it will not be able to maintain voltage as the starter is engaged.
When the voltage drops too low, the ABS fails. In other words, the source of this problem is more
often than not related to the battery.
To verify that the battery, and not something else, is at fault, do as follows:
- Ride a short trip to heat up the engine (carefully - remember your ABS is not working)
- In a down hill, pull in clutch and turn off the bike (with the key). DO NOT WITHDRAW THE KEY AS THIS WILL LOCK THE STEERING!
- Turn bike back on, and CAREFULLY let out the clutch to jump-start the engine again.
- Your ABS-lights will now blink in parallel (not alternating). They blink because the self-test has failed.
The test failed because the bike was rolling when the ABS system was powered up.
- Pull to a full stop.
- Ride on.
The ABS will now self-test as normal, you'll hear the 'clank', and the lights will go out.
You now know the battery, and not the ABS, is at fault.
1200
A number of problems can arise if the handguard touches the brake lever. Among those things known to happen are
"Front wheel lock-up" and "Brake Warning light stay on". If you have have a 1200 and experience problems with your
brakes, please read the following very, very carefully: The handguard can easily get in a position to touch (not as press
fully in, but touch as in caress) your brake lever. The ABS (and relates systems) are very, very delicate, and if your brake
lever is not fully released (as in air in front of it), all sorts of odd problems seems to occur.
So, before asking, check very carefully (look carefully!) that your brake lever is not touching the hand guard. Notice: Touching
is not enough to turn on the brake light. You need to inspect the lever and verify it does'n not touch.
Failing to check this carefully seems to be behind the majority of brake-related issues at GSpot.
4.8 How do I bleed the brakes?
That depends on the model of your bike, and its configuration:
1100 and 1150: Conventional wisdom says that even if you have ABS, bleeding at the end-points
(that is, the nipples front and rear) is sufficient. This will also
replace the fluid inside the ABS.
However, there are strong indication that bleeding at the end-points do not replace all fluid int he ABS. Check out
this image. The brakes were bled very, very carefully two weeks prior. When the ABS was bled, the tar was found.
XXX The following two links will be incorporated as soon as the overview of ABS, ABS-2, ABS-3, I-ABS-I, I-ABS-II etc, etc, is ready.
http://advwisdom.hogranch.com/Wisdom/service_abs3.pdf
http://advwisdom.hogranch.com/Wisdom/abs3_filling_adapter.pdf
1200 I-ABS-I:
1200 I-ABS-II:
4.9 What is EVO and is it part of the ABS system?
EVO is a brake hardware change. EVO isn't related to ABS. During 2001-2002 all bikes received the new EVO hardware, whether or not they had ABS.
External: EVO is a brake caliper 'appearance' change. The name "Brembo" is replaced with the initials "BMW" on the outside of the caliper casting.
External: The front pads can be changed without removing the calipers. The pads slide out from the back side of the caliper.
Internal: Unchanged. The hydraulic piston diameters in the master cylinders and calipers stay the same, pre-EVO and post-EVO.
EVO includes larger diameter rotors on the cast wheels, but not the spoked wheels
The EVO brakes have BMW on them, the pre-EVo has Bremo.
4.10 Is ABS a Good Thing or a Bad Thing?
Many will tell tales of how ABS has saved their life (or at least, saved them from crashing); for those it concerns it is a very
convincing argument (to say the least).
Equally many will tell tales of how it destroys their joy of motorcycle riding; what is the purpose of riding if it is no fun?
Some will say it is an expensive and overly complex solution to a non-existing problem. Some will say it does not work.
And so on, and so on, Ad Nauseam.
Regardless of your point of view, you should have read this article Motorcycle Consumer News. It is a classic point of reference.
For the more technically inclined, read here is a detailed description of ABS-II (see above what ABS-II is).
As GSpot FAQ editor I am at liberty to say the following: Unless your name happens to be Hayden or Rossi, you should have ABS on your bike.
4.11 Can I completely remove ABS from my bike?
1100/1150
Yes, you can remove the ABS from your bike. If you have servo assistance together with your ABS you can remove that as well. You can not remove only the servo.
Basically, you want to convert your bike from a GSA to a GS (check the second paragraph in this FAQ for the meaning of GS and GSA).
You do that by bypassing the ABS/servo unit. That is, the brake line from the front handle should go directly to the calipers (without going into the ABS/servo) and likewise for the rear.
Up front you have two alternatives. The simplest is to contact a supplier of brake lines, Spiegler for example, and tell them
you have a non-ABS model and that you want to renew everything. This has been done in 2008 and the cost was about USD 200.
In particular, make sure you obtain a new T where the brake line is to be split into two for both calipers up front.
The other alternative is to purchase 34 32 7 650965 - Distribution piece. This part then attaches as shown in this image (which is a
demonstration not an actual drawing) . This approach has not been demonstrated but is believed to work.
For you rear brake lines you purchases a new line that bypass the ABS/servo unit. You need one of these two lines
34 32 7 677201 - steel flex brake hose (L=345MM)
or 34 32 7 684408 - steel flex brake hose (L=370MM).
We do not know which one.
Electrical:
When the ABS/Servo is removed, all the hardware to operate the tail light and brake light remain. They just need to be connected.
Everything needed is there, switched power, tail light, brake light, and brake light switches.
As you can imagine, the front and rear brake levers operate electrical switches. The wiring to those switches terminate in the large ABS connector you mention.
The tail light and brake light filaments are also wired to that connector.
There is a switched voltage wire at that connector as well. BUT it is a special switched voltage, it is 'hot' both when the key is on, and when the key is in the park position.
Once that 'special' switched voltage is found, pull and replace the fuses one by one to determine which fuse supplies that wire.
Check your Owner's Manual, maybe the brake and tail light fuses are listed.
The brake light: The switches seems to be different than normal ones (conducting when the level is not pressed). Several suggestions has been made.
To replace them with ordinary switches (from a non-ABS model) is probably simplest.
Then, finally, you can remove the large and heavy ABS/servo unit from the bike, together with the break lines that no longer is in use.
You would probably also want to remove the bulbs in the now flashing ABS lights on your dash.
More information here and here.
4.12 How do I change the brake pads, front
If you have the EVO brakes (see the question on what EVO is, and how to determine if your bike has it), then the calipers for the servo brakes are
the same as 1150 non-servo and non-abs. The pads pop out of the back of the caliper without removing the caliper.
The significant difference is the brake fluid reservoir is part of the Servo ABS unit, as you know I'm sure. So watch that reservoir instead of the reservoir on the handlebar.
If you have 1150/1100 without EVO, remove the pin, remove the caliper, lift out the pad, press back the pistons with a c-clamp while watching the reservoir on the handlebar.
1200GS
The Honorable rideLD has, based on years of following GSpot, compiled the following list; his experience is that almost all failures are one of these six.
6 things to cause ABS failure.
1- Lever or pedal failing to travel fully back to the correct position. This is usually caused by the hand guard preventing the front brake lever from fully extending or a pebble or twig preventing the brake pedal from returning to its up most position. An easy way to tell that this is your problem is if your brake light is always be on. Notice, however, that it is possible to pull the lever sufficent for the ABS system to detect it, but not enough for the light to come on. This can be a confusing situation.
2- Sensors. If either of your brake sensors fail the brake light will stay on. Severed wires, dirty sensors or melted sensors can cause this failure. If your speedo works then your rear sensor is definitely OK. Make sure your front sensor is clean and wire is not severed.
3- Fluid levels. Tip overs can cause fluid to leak out of the ABS pump under the gas tank. Pull off the gas tank and top off each of the circuits. This will fix a fluid level related failure.
4 - Microswitch problems. There is a little tiny switch under the front brake lever and next to the rear brake pedal. You should hear an audible click when you activate either. This switch can fail although it is rare. If your problem is not 1,2 or 3 then this is probably your problem. If the switch is bad your brake light will not activate from the bad switch.
5- Low battery voltage. This is a the common cause of ABS failure on the 11xx versions of ABS. Usually the ABS will start working normally when the alternator gets the charge back up to normal. The ABS versions on the R1200GS are not as senstive to low voltage issues and voltage related failures are very rare.
6- Bad pump unit. Very rare. In fact I have not heard of one failing on the R1200GS yet. There have been a few replaced but these were diagnoses errors and real problem was one of the four items above.
4.14 Grub screw
If you look carefully at the two calipers on your bike, you will notice that where you would suppose you could bleed the brakes, on the right side, there isn't a nipple but a much bigger black thing. That black thing is called a grub screw. Also, if you want to bleed your clutch, and locate the end of the clutch line underneath the luggage rack on the right-hand side, you will find a grub screw also there.
First, what does it do?
If you unscrew the small hex on the top of the grub screw, you will find threads into which you can screw a standard nipple. Inside the grub there is a small ball, and below the ball is the brake (or clutch) fluid. If you carefully screw a nipple into the grub, the end of the nipple will push down the ball, and you will be able to bleed the system.
Second, what is it for?
We believe BMW fills both the clutch and the brakes "bottom up". That is, the initial filling isn't done at the reservoir, but the flud is forced in from the "bottom". For that to work, you need a valve to hold the fluid, and that is what the little ball does.
For you, during maintenance, the grub offers absolutely no functionality.
Third: Can you remove both of them (brake and clutch)?
Almost all do.
The nice thing is that the bottom of the grub is identical to a nipple. That is, the caliper and end of the clutch line
was designed to hold a nipple, but BMW inserted a grub instead.
What most do is to remove the grub with a pair of pliers, and insert a standard nipple. The nipple that fits has
P.No 34212330310. It is a standard M10 nipple. In 2008 it cost 6 euro from BMW (and comes with a rubber cap).
However: The grub has been set with LockTite, and should be heated when unscrewed. There has been reports of grub
screws breaking when unscrewed cold. Not many, but sufficient to warrant heating.
Details in this photo.
4.15 Servo brakes issues
You might want to check the filters in your servo. Details in this thread.
4.16 Servo pump continues to run....
....even after ignition has been turned off.
Can happen on the late 1150 and early 12GS (with ABS and servo, the ABS-II). You need to pull
the tank and disconnect the battery (to save the pump).
Your ABS relay is most probably stuck. It can be (temporaryly) fixed by cleaning the contact points.
The realay must be replaced. ALternatively, you can convert your bike to a non-abs, not-servo layout.
It is not possible to retain the ABS without the servo.
4.17 Can the ABS-pump be repaired?
It seems so; check this thread or directly here.
IBA: 33616
tagesk screwed with this post 08-06-2013 at 08:11 AM Reason: ABS reset
tagesk is offline
Old 03-28-2008, 10:55 PM   #5
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 5 (Oil)
5.1 How much oil goes into the engine?
1100/1150:
Without changing the filter: 3.5 liter (0.92 US gallons)
With change of filter: 3.75 liter (0.99 US gallons)
R1200GS: With change of filter: 4.0 liter
11xx/hexhead/camhead:
From lower edge of the glass to the high edge is 0.5 liters of oil.
wethead:
From lower edge of the glass to the high edge is 1 liter of oil.
5.2 What is the part number for the oil filter?
1200: BMW part # 11427673541 Filter
Here is an alternative list of filters:
Oil filters:
FRAM is the correct FRAM but hard to find at WallyWorld. PH6063
FRAM is readily available and works PH3614
AC DELCO PF-53
NAPA 1348
Mobil-1 M1-102
BMW 11.42-1 460 843 or 845
Mahle/knecht/microstar/tecafiltre (original part) OC91
Champion (of motorcycle range) C301
Purflux LS188B
Tech9 (France only, made by Mahle in fact) n°16
Hiflofiltro (from Thailand) HF-163
Mann-Hummel MW712
Detlev Louis (Germany) 10050195
Toyota 08922-02004 or 90915-YZZB9
Perf-form (on www.perf-form.com) BMW-1
UFI makes one too (italian)
Donit (www-motobins.co.uk) 43 10 133
For After May, '97, 1100RT
Purolator P/N11421460845
AMSOIL SMF122
Bosch 3330
WalMart ST3614
Purolator L00241
AC PF53
The author of this table, the Honorable JVB, writes:
Keep in mind that that list was originally compiled for the R1100/1150 bikes.
But they will fit and work on an R1200. I will not personally attest to their suitability
in either application. I only know that countless people have successfully used them
on the R1100/1150, and more and more are using them on the R1200. I am aware of no
reports of any issues with their use.
5.3 Can I reuse the washer when changing the oil?
Yes you can, if you must, but preferably not. It is a so called crush washer that deforms to seal perfectly.
Thus the bolt and case are designed with the assumption that a new washer every time. They are inexpensive!
BMW part # 07119963252 Crush washer
5.4 What type of oil can I use in the engine?
For every bike, there are two, not one, answer to this question. The first answer deals with the quality
(chemical properties) of the oil. That is answered here.
The second answer deals with the viscosity (how thick is it). These two are NOT related.
You need to get both correct for your bike.
Here is a real question which started Yet Another Oil Thread in GSpot, and the Politically Correct answer:
Originally Posted by Joe User
Hello, I wanted to know what type of oil do you use on your bike. I own an hp2 and I am thinking to use Bel Ray
Sae 20w-50 (API SG, JASO MA). I was using Castrol full synthetic, but my dealer told me that there is no need to use full synthetic,
as BMW suggests for air-cooled engines simple oil. This is true or not? Does simple oil lubrictes as well as full synthetic or things are
different for boxers? Thanks.
Too many questions at once.
First, it is true that BMW, the designer and manufacturer of your HP2, clearly states that the engine has been designed to run on
plain mineral oil. They do so by stating the requirements for the oil. Plain, traditional mineral oil meets these requirements.
You are free to value the opinion of BMW, the designer and manufacturer or your HP2, lower or higher than opinions aired on the Internet.
Second, it is not true that an old-style mineral oil has as high (and stable) quality as an expensive, fully synthetic oil.
It is also not true that an old-style mineral oil lubricates as well as an expensive, fully synthetic oil after even the shortest use.
Now, based on these three observations (one true and two false), you must decide with great care which of them you believe answered the question you wanted to ask.
You see, I believe you wanted to ask the first question. On the Internet most answers will be to one or both of the second two questions.
In particular, you can expect most replies to answer your first question with false BECAUSE the two second questions have false as their answer.
Here is from the manual:
11xx: "HD Oil classified as API SF, SG or SH, or HD oil classified as CCMC G4 or G5."
Hexhead: "Engine oils API SF/ACEA A2, or better. BMW Motorrad recommends not using synthetic oils for the first 10,000 km (6.000 miles)."
Camhead: "Oil of quality API SF/ACEA A2, or better" (assuming above freezing)
Wethead: "API SL JASO MA2". Note that the wethead has, as a first, a wet clutch. Do not use JASO MB or "normal" car or truck oil.
What does this mean? Oil is classified based on how "good" it is. The S-series spesifies the quality of oil. In general, the later
specifications improves on the old ones. So SG is a better oil than SF, ans SH is better that SG.
When an engine is designed, the oil filter, the interval of oil-changes, and so on is all based on the MINIMUM quality of the oil.
That is, the engine will be designed to run well and without harm on the worst oil meeting the required specification (given that you replace it
as expected). For the GS (assuming above freezing) the minimum quality that is required is SF. You will be hard pressed to find an
oil that does not meet the SF quality criteria.
Notice that the quality of the oil does not depend on whether it is syth or dino!
This concludes the answer of the first of two questions about oil. See 5.14 Which viscosity or the second answer.
5.5 How much oil goes in the transmission?
1100/1150:
You fill until it is full. That will be circa 800 ml (0.8 liters).
1200: 800 ml (0.8 liters). Actually, the number seems to be somewhat less.
5.6 What kind of oil goes in the transmission?
1100/1150/1200:
BMW, the designer and manufacturer, specifies: Oil for hiopdial
gears class API GL5. Above 5 degrees C SAE 90. Below 5C SAE 80.
Or as alternative SAE 80 W 90".
In other words: Any modern hypoid oil with API GL5 and SAE 90 on it is fine.
5.7 How much oil goes in the FD?
11xx:
Fill it until it is full at the bottom of the threads. It will be circa 250 ml.
1200:
200 ml on initial fill and 180 ml on oil change (notice: it is not a spelling error - 200 and 180).
On the 1200 there might, or might not, be proper holes to drain and
fill the FD. See the document R12GS Final Drive Oil Change.
In the document, the author writes you should fill 250 ml of oil in the FD. That is not correct.
The wethead also uses 180 ml.
5.8 What kind of oil goes in the FD?
BMW, the designer and manufacturer, specifies "Oil for hiopdial
gears class API GL5. Above 5 centigrades SAE 90. Below 5
centigrades SAE 80. Or as alternative SAE 80 W 90".
In other words: Any modern oil with API GL5 and SAE80W90 on it should be fine.
Yes you can, and many do.
However you might consider that BMW has specified 75W90, probably becuase if your rear drive gets
hot enough to require the 140 chances are you already have final drive problems. Otherwise the 75W90
will lubricate better with less fluid drag, the slightly lighter fluid is better for the bearings.
Heavier fluids with higher temp. ratings (140) work well for extreme temperature's (hotter than your final
drive gets) and higher shock loads, otherwise the lighter fluid is a better lubricant overall.
5.10 How often should I change the oil in the FD?
The consensus among the majority, and now the dealers, is that you should change the oil in the FD at 600 miles (1.000 km),
and then every 12.000 miles (20.000 km).
On the 1100 and 1150 changing the oil is simple.
For the 1200 there is a document in Wisdom (see http://advwisdom.hogranch.com/Wisdom...%20Change.html).
5.11 I overfilled the FD or my engine - what do I do?
If you overfill, consensus is that you should drain and then
fill in the proper amount. There is a real chance of destroying
seals inside due to the pressure becoming too high.
That being said: The most common error (at least in Europe) is to fill 4 liters (and not 3.75) in the engine.
Consensus seems to be that it is not a crucial amount, and that you can choose to ignore it.
5.12 What is "dino oil"?
Dino is short for dinosaurus. Dinosaurus lived on Earth at more or less the same time as the deposits were made
that we now extract as mineral oil. Oils are either dino, part dino and part synthetic (called synth), or pure synth.
As per the manual, it is normal for oil to be consumed at a rate of 1 liter / 1.000 km (1/4 gallon 600 miles).
There is no reason to worry, or to take action, if your bike uses oil at this rate.
It is, however, not at all common.
5.14 Which viscosity can I use
First, please note that this is the second of two answers to the question "which oil can I use?".
Also, the words CAN and SHOULD have very different meaning.
Camhead:
The primary oil is 10w-40. That is, you should use 10w-40.
Assuming you don't ride below freezing (0°C or 32F) you can use:
15w-40, 10w-50, 10w-40, , 5w-40 and 5w-50
Assuming you do start the bike, and ride, down to -10°C (14F):
10w-40 (not 15W- and not -50).
HExhead:
Primary oil is 20w-50. That is, you should use 20w-50.
In addition you can use (but take careful note the temperature ranges below):
5w- >=30
10w-40
15w- >=40
20w- >=40
5w- >=50 Synthetic
10w- >=50 Synthetic
Below 20C (68F): All the above.
In the 20C - 30C range (68-86F): all the above, except 5w dino.
Above 30C (86F): All the above, except 5w dino and 10w-40 dino.
Notice that 10w-40 synth does not meet the demands of the engine when the ambient temperature is above 30C (86F).
In this range the oil must be either 15w-40 dino, 20w-40 dino or 10w-50 synthetic.
Wethead:
5w-40 synthetic (all temperature ranges).
5.15 How hot is the oil?
For oil temperature LCD readout, there are 10 BARS, with no bars showing to be taken as zero bars:
0 33.5° C ..... 92° F
1 40° C..... 104° F
2 65° C..... 149° F
3 80° C..... 176° F
4 90° C..... 194° F
5 105° C..... 221° F
6 130° C..... 266° F
7 150° C..... 302° F
8 160° C..... 320° F
9 170° C..... 338° F
10 175° C..... 347° F
Modern oils are designed to work best in the range of 110° C...130° C (230° F-266° F).
This means about 5 or 6 BARS. Above 150° C (302° F), oil breakdown increases exponentially,
and by about 160° C (320° F), degradation is quite rapid. Petroleum oils will cease to lubricate
with any effect, at about 170° C (338° F)...synthetics at about 190 C (374° F).
A reading of 8 BARS would be the absolute maximum normal operating temperature.
5.16 How much oil is there in the engine
On both the 12GS (hexhead and camhead) and the 11xx, there is an "oil sight glass" on the left side of the engine.
To obtain a correct, and repeatable, measurement of how much oil there is inside, ride
the bike until the engine is warm (at least three bars).
Then, on the 11xx, let the bike sit some minutes on the side stand.
Quite a few bikes needs this to drain the oil cooler.
Then, up on the main stand.
At this point you will see the level in the sight glass.
Obviously, the longer you wait, the more oil will slowly seep down, and the level will rise (a tiny bit).
If you can not see the level because it had been over filled, get some help and lean the
bike towards the right side.
If this enables you to see the level, then, even though you technically speaking have too
much oil, you can safely ride the bike. No need to drain the oil.
If you can't see even when leaning, you have severely overfilled and you should drain.
As long as you see oil in the glass, you have enough oil. I repeat: If you see oil in the glass,
there is no need to fill oil.
Finally: When the bike is on the side stand, the level will be above the top of the glass.
However, this also means that when level, it will be above the bottom of the glass.
Or in other words: If you park your bike on the side stand when warm, and you see that the
glass is completely covered in oil, you have enough oil. No need to establish precisely how much.
Regarding the wethead: The difference between low-and and high-end of the glass is now 1 liter (not 50 cl as older models).
5.17 Oil in the airbox
It is normal to find a little oil in your airbox. The crankcase pressure will almost inevitable blow some oil into the air box. It does not always implies the engine was over-filled.
The harder you run the bike, the more oil you will find in the air box.
IBA: 33616
tagesk screwed with this post 08-04-2013 at 11:57 PM Reason: More details on the 1200 oil.
tagesk is offline
Old 03-28-2008, 10:57 PM   #6
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 6 (Modifying the bike)
This is Part 6 (out of seven) of the GSpot FAQ. Part 1 (here) contains the Table of Content and links to all the other parts.
PART 6: Modifying the bike
6.1 How can I get more fuel into the tank
This question can be phrased also as follows:
  • What is this fuel neck mod' people keep talking about?
  • How do I do the fuel filler mod?
  • I can't fill my tank up all the way. What can I do?
1100/1150
The neck into the tank is to ensure that you don't fill the tank all the way to the top. The reason is that a completely full tank will overflow if you put the bike on the side stand. If you make (by drilling, for example) one or more holes in the neck there will be room for another two to three liters of fuel (1/2 to 3/4 gallon)
1200
There is a rubber neck inserted into the steel neck in the tank. It's purpose is not clear. You can remove it. Another two liters (1/2 gallon) will fit in the tank.
6.2 LED Turn Signal
If you want LED turn signals on yoru 1200GS (as shown here) you should order
LED Front turn signal (you need two): 63 13 7 708 048
LED Rear turn signal left: 63 23 7 710 575
LED Rear turn signal right: 63 23 7 710 576
These have been designed to work the bike and they will not trigger a "lamp failure".
6.3 New LED fogs on "old" 12GS Adventure
Yes, you can replace the old halogen fogs (55W) on the Adventure with the new LED (14).
Part numbers et cetera here.
6.4 How to get an (even) higher seat on the 12GS
All you need to know is in this thread.
6.X Other well documented modifications
  • Handlebar risers here.
  • Replacing heated grip rubbers here.
  • Installing 1200ADV winglets on a standard 12gs here.
  • Aeroflow install and review.
  • Alternate skid plates here.
  • Alternate footpegs here.
  • Install ADV tank in standard 12GS here.
IBA: 33616
tagesk screwed with this post 05-23-2011 at 02:40 PM Reason: LED Turn signals
tagesk is offline
Old 03-28-2008, 10:58 PM   #7
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,229
Thumb GSpot FAQ: Part 7 (Miscellaneous)
This is Part 7 (out of seven) of the GSpot FAQ. In Part 1 (here) you will find the Table of Content and links to the other parts.
PART 7: Miscellaneous
7.1 What is the toll-free phone number for BMW Roadside Assistance?
In the US, call 1-877-680-2176
7.2 Other resources on the Net?
If you don't find your answer here in this FAQ, it does neither imply that it has not been asked and answered here at ADVrider before (just that your question isn't frequent), nor that the ADVrider community doesn't know the answer. Try to use Google like this: "Your Question site:advrider.com". Google is very good at these things!
Now, if that isn't enough, here is a list of other well-know resources that populate the surroundings:Manufacturers of Hard Luggage
1) ALPOS:
http://www.bykebitz.co.uk/acatalog/Available_Sizes_.html
2) BMW Adventure: http://www.bmwmotorcycles.com/
3) BMW System Cases: http://www.bmwmotorcycles.com/
4) BMW Vario: http://www.bmwmotorcycles.com/
5) Caja Sahel: http://www.cajasahel.com/panniers.html
6) Caribou: http://cariboucases.com/
7) Coocase: http://www.twistedthrottle.com/
8) Givi: http://www.giviusa.com/ and http://www.adventuremotogear.com/
9) Happy Trails: http://www.happy-trail.com/
10) Hattech: http://www.hattech.de/
11) Hepco & Becker: http://www.hepco-becker.de/ and http://www.adventuremotogear.com/
12) Jesse: http://www.xplorermoto.com and http://www.jesseluggage.com/
13) Kappa: http://www.kappaluggage.co.uk/
14) Krauser: http://www.krauser.de/
15) Metal Mule: http://www.bestrestproducts.com/ and http://www.metalmule.com/
16) Micatech: http://shop.micatech.net/
17) Moto-Sport: http://moto-sportpanniers.com/
18) Pelican: http://cariboucases.com/
19) Shad: http://www.binetto.com/
20) Stahl Koffer: http://www.stahlkoffer.com/
21) Studebaker: http://www.whitehorsepress.com/
22) Touratech Zega: http://www.touratech-usa.com/
23) Touratech Zega Pro: Coming In April 2009?
24) TraX:
http://www.mo-tech.de/trax/ and http://www.twistedthrottle.com/
25) WorldBeater: http://www.projectvnd.com
Manufacturers of Seats
1) Air Hawk:
http://www.therohostore.com/ and http://airhawkguy.com.au/
2) Alaska Leather: http://www.alaskaleather.com/
3) Australian Cumfy Motorcycle Seats: http://www.australiancumfymotorcycleseats.com.au/
4) Bead Rider: http://www.beadrider.com/
5) Bill Mayer Saddles: http://billmayersaddles.com/
6) Carolina Butt Buffer: http://www.carolinabuttbuffer.com/
7) Corbin: http://www.corbin.com/
8) Custom Motorcycle Seats: http://www.motorbike-seats.co.uk/
9) Diamond Custom Seats: http://www.diamondseats.com/
10) Hartco International: http://www.hartcoseats.com/
11) Kon Tour: http://kontourseat.com/
12) McRoadrunner: http://custommotorcycleseats.com.au/
13) Moretti Ltd: http://motorcycleseats.co.uk/
14) Rich’s Custom Seats: http://www.richscustomseats.com/
15) Roberti Customs: http://www.roberticustoms.com/
16) Russell Cycle Products: http://www.day-long.com/
17) Saddlemen: http://saddlemen.com/
18) Sargent: http://www.sargentcycle.com/
Various Vendors and Resources
1) A&S BMW Motorcycles:
http://www.ascycles.com/default.aspx/
2) Adventure Designs:
http://www.advdesigns.net
3) Adventure Workshop:
http://www.adventurersworkshop.com/
4) Adventuremotogear:
5) AeroFlow:
http://www.aeroflowscreens.com/index.html
6) AeroStich:
http://www.aerostich.com/catalog/US/index.html
7) Beemer Boneyard:
http://www.beemerboneyard.com/index.html
8) Best Rest Products:
http://www.bestrestproducts.com/default.aspx
9) Cee Bailey's Aircraft Plastics: http://www.ceebaileys.com/bmw/1200gsgrd.htm
10) Cycle Gadgets:
http://www.cyclegadgets.com/
11) Cycle Nuts: http://www.cyclenutz.com/
12) DDM Tuning: http://ddmtuning.com/index.html
13) Doran MFG LLC: http://www.doranmfg.com/index.html
14) Dual Sport Touring:
http://www.dualsporttouring.com/
15) Eastern Beaver Company:
http://easternbeaver.com/index.html
16) Euro Motoelectrics: http://www.euromotoelectrics.com/
17) Excel Cycle & Macine Werkes:
http://www.excelcyclewerkes.com
18) Fuze Blocks: http://www.fuzeblocks.com/
19) HID 50 Hard Core Lighting: http://hid50.com/
20) Hyper Lite LED Products: http://hyperlites.com
21) Identi Tape Inc.: http://www.identi-tape.com/
22) JVB Productions: http://www.jimvonbaden.com/
23) Kisan Technologies Inc.: http://www.kisantech.com/
24) LD Comfort:
https://ldcomfort.com/store/home.php
25) Machine Art Moto: http://machineartmoto.com/shopsite_sc/index.html
26) Marc Parnes Products for Motorcycles:
http://www.marcparnes.com/
27) Motoport:
http://motoport.com
28) Motorcycle Cruise Control: http://www.mccruise.com/index.html
29) MV Motorrad: http://www.mv-motorrad.de/
30) New Enough:
http://www.newenoughhp.com/
31) P3 Lights: http://www.p3lights.com
32) Pro-Moto Billet: http://www.promotobillet.com/index.html
33) Sierra BMW: http://www.sierrabmwonline.com/
34) Southwest Moto Tires: http://arizonamoto.com/Merchant2/merchant.mvc?
35) Super Bright LEDs Inc.:
http://www.superbrightleds.com/led_prods.htm
36) SW-Motech: http://sw-motech.de/
37) Ted Porter’s BeemerShop: http://www.beemershop.com/
38) Tires Unlimited: http://www.tiresunlimited.com/default.htm
39) Touratech:
40) Twisted Throttle: http://www.twistedthrottle.com/
41) VVME HID Lights: http://vvme.com/
42) World Vintage Motorcycle Sales Co.:
http://www.hippohands.com/index.htm
43) Wunderlich: http://www.wunderlich.de/ or http://www.wunderlichamerica.com/index.html
44) Xenon Rider: http://www.xenonrider.com/
7.3 I'm buying a used bike - what to look out for?
99-02 1150GS: here.
7.4 How to rekey the Vario hard luggage
Look no further, it is here.
7.5 How to trailer a GS
Not that is needed, but just in case, it is here.
7.6 I have another question
If you have a question you think should be included here, please feel free to send me (tagesk) a PM and we'll discuss it.
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk screwed with this post 09-25-2012 at 01:44 PM Reason: Added links
tagesk is offline
Old 11-10-2009, 09:32 AM   #8
Dirt Devil
Dirt Devil's Avatar
Oddometer: 21
ESA rear shock protection questions...
I have a new '09 GS with ESA. The rear shock has an existing protective partial cover yet I am wondering whether any or rather which of the rear splash guards would give the best protection to the shock from mud, spray, and general road crap etc. Excluding Carbon Fiber, there still is a wide price difference between the various mud guards with only some poorly visualized differences that I can determine from the site pics. Unfortunately for us with the ESA feature the shock is not rebuildable nor even covered by extended warrantees.
Thanks, Dirt Devil
Dirt Devil screwed with this post 12-01-2009 at 08:49 PM Reason: Want to move it to GSpot, Don't know how...
Dirt Devil is offline
Old 02-16-2010, 12:00 AM   #9
smithlanger
Oddometer: 1
How much the price difference in different splash guards.?
ccie exam preparation and more about icnd and ccnp
smithlanger is offline
Old 03-10-2010, 05:42 AM   #10
Raineman
Oddometer: 62
Thanks for all the hard work in producing this brilliant information.
I am new to 1200GS land, and have some brake problems, which I will work through using your advice.
I also got worried about tales of final drive failures, etc. and was starting to think I made a boo boo buying the GS, but your info put things into perspective.
Thanks again, it is much appreciated
Raineman
Raineman is offline
Old 05-02-2010, 03:38 AM   #11
xaphod
n00bin' around europa
xaphod's Avatar
Oddometer: 158
Hey Tage, found something you could add to the FAQ: at what tread-depth should the front & rear tires be replaced?
Disclaimer: i used IE's search functionality and couldn't find the word "tread"; i also browsed 3.13-3.16 and did not see it there.
Thanks for the FAQ, it's great!
xaphod is offline
Old 05-14-2010, 12:22 AM   #12
rattis
rattis's Avatar
Oddometer: 1,260
Cry no video
can't see the videos/films concerning the DIY service of da 1150 GSA
help pleeeeeeeeeeeease
rattis is offline
Old 05-15-2010, 03:00 PM   #13
watercooled
watercooled's Avatar
Oddometer: 15
Eh? GS transmission oil change
maybe I've missed in the FAQ's and general lurking about, but can some direct me to "how to change the transmission oil on a 09 GS 1200"?
watercooled is offline
Old 05-21-2010, 02:59 PM   #14
milehigh
Oddometer: 7
Re: 3.37 -- Does the Rubber Chicken Racing mod work?
For the early 11xx GS's, Rubber Chicken Racing offers an upgraded tensioner. It's a lot cheaper than the one in the write-up (nice job there!...). MCN (U.S.) liked it a lot.
Does it do the job? Is it the same as the BMW-numbered upgrade?
Cheers!
JS
milehigh is offline
Old 09-27-2010, 07:58 AM   #15
stephen.stallebrass
stephen.stallebrass's Avatar
Oddometer: 272
Globeriders do a dvd on BMW R1200 GS, including maintenance, you should check it out. They also do the 650 & 800. I don't know if they're any good though.
www.AdventureVagabond.com Mongolia & Siberia 2012: Adventure Moto Madness
stephen.stallebrass is offline
Closed Thread
Times are GMT -7.   It's 06:13 AM.
