Old 12-25-2014, 01:15 PM   #1
dustyweasel OP
sir crashed alot...
dustyweasel's Avatar
Oddometer: 39
Best KLR suspension upgrade?
I'd like to gather all ideas and experiences with suspension kits or upgrades on the Klr 650. I'm on my third one. Riding a 2012 now. Would like to gain at least an inch more travel and stop the thing from banging the rocks. If I can't gain that, I may end up going orange....
dustyweasel is offline   Reply With Quote
Old 12-25-2014, 01:34 PM   #2
Beezer
Oddometer: 5,734
Moab on the back & Ricor in the front mage my Gen I a new bike
Beezer is online now   Reply With Quote
Old 12-25-2014, 01:44 PM   #3
MacG
MacG's Avatar
Oddometer: 247
I would call Rick at Cogent Dynamics www.motocd.com
Great people, great products.
09 KLR
97 DR650
MacG is offline   Reply With Quote
Old 12-25-2014, 01:58 PM   #4
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,263
Quit screwing around...
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 12-25-2014, 02:23 PM   #5
trailer Rails
trailer Rails's Avatar
Oddometer: 3,780
The KLR and the Orange bikes are completely different. Trying to make a KLR close to a KTM is going to cost a lot more than buying the KTM.
Maybe another KLR rider can help out with doing this.
trailer Rails is offline   Reply With Quote
Old 12-25-2014, 07:34 PM   #6
juddspaintballs
Never too many bikes
juddspaintballs's Avatar
Oddometer: 415
It'll never be a KTM. I hear nothing but great things about the Cogen Moab, but even a good rebuild with a good bump stop, proper fluid level and higher nitrogen pressure to keep it from foaming as much with a properly weighted spring will keep the rear end in check. There's a lot of options for the front end as far as different springs, fluid levels, pre-load, valving, etc. I think there are even drop-in cartridge kits for the Gen 2 bikes.
If you want a performance KTM machine, buy a KTM. If you want stupid simple longterm reliability and low maintenance, keep the KLR and realize what it is and isn't.
Or get both!
KTM 250EXC | KLR650
You can't say happiness without saying penis.
juddspaintballs is offline   Reply With Quote
Old 12-25-2014, 07:41 PM   #7
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,607
I've tried out the new valve that cogent has come out with and was very impressed. Was able to bomb down the rocks, keep solid traction on dirt and was still plush enough for the street. That was something I couldn't get out of my suspension before. Which is why I went with yz forks. If they would of had that valve out I'd been happy with that. I believe with a moab rear shock and front kit you'd be set.
Just for reference I had race tech emulators and springs and it wasn't good enough to keep the stock forks. On my gen1 that combo worked out for me.
johnwesley screwed with this post 12-25-2014 at 08:02 PM
johnwesley is offline   Reply With Quote
Old 12-25-2014, 07:47 PM   #8
Beezer
Oddometer: 5,734
had YZ forks on a Gen I KLR. the Ricor valves make enough difference to make such a change not worth the effort. also KTM.... depends on which one you get and what you plan to do with it. the 640 Adventure is not that big of a step (I already know I'll get flamed but it is what it is)
Old 12-26-2014, 06:11 AM   #9
trailer Rails
Oddometer: 3,780
I put a Cogent rear shock and race tech emulators in the fork on my DR650 and it rides completely different but it is still far from a KTM690.
Old 12-26-2014, 02:27 PM   #10
dustyweasel OP
sir crashed alot...
Oddometer: 39
Thank you very much for the advice. Looks like Cogent rear and Ricor valves seem to be the way to go. I'm still going to buy a KTM 950 SE someday. But for now, I shall keep sinking some jingle into the KLR and rack up the miles.
Again, thank you
Old 12-26-2014, 02:27 PM   #11
dustyweasel OP
sir crashed alot...
Oddometer: 39
Although..... the tennis balls look cheaper..
Old 12-26-2014, 02:34 PM   #12
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 3,921
I've always thought that was one of the best looking KLRs I've never seen.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 12-26-2014, 06:29 PM   #13
guns_equal_freedom
Oddometer: 5,528
I did the RaceTech Emulators on the front and a Noleen shock out back.
It was a 100% improvement to the shit suspension Kawasaki uses on the KLR.
Then I did the ultimate mod to the KLR -
guns_equal_freedom is offline   Reply With Quote
Old 12-26-2014, 06:32 PM   #14
w33b8t1
w33b8t1's Avatar
Oddometer: 264
I want a 690, but back to the point.
On my '11 i did progressive front springs and that helped a ton ,but the rebound valving needed to be stiffer with them.
On the rear I never had a ton of trouble, just cranked up the preload to the max and put some raising links on.
http://ridefourcorners.com
w33b8t1 is offline   Reply With Quote
Old 12-27-2014, 06:01 PM   #15
RsZk
RsZk's Avatar
Oddometer: 161
Yup another plug for Cogent Dynamics Moab shock.
I went for the full replacement Progressive Monotube cartridge kit for the forks. Wow. The combination works excellent in washboard, street, and 2 track/ATV trails.
2013 ride report:
http://advrider.com/forums/showthread.php?t=898211
2012 KLR 650, 2013 Super Tenere
RsZk is offline   Reply With Quote
Times are GMT -7.   It's 11:22 PM.
