Old 03-28-2013, 11:26 AM   #586
Sidecar Jockey
Sidecar Jockey's Avatar
Oddometer: 632
I picked up my second xt500 last weekend. This one is a 1978 xt500 E. I bought it from the original owner, with 10,500 miles on it. It looks to be mostly original, and is in great shape. The only problems are 1) dry rotted fork botos and 2) 2 slight dents in the right side of the tank.
I bought the bike not running, but after changing the fluids, adjusting the points, cam chain, and valves, and cleaning the carb it fired up! I took it for a ~90 mile ride and its great!
I also have a 1975 Honda xl250 and a 1976 Honda xl350. I bought the hondas about 1.5 years ago and have been enjoying the heck ot of them.
To compare the xt500's to the smaller Hondas is probably an apples to oranges comparison, but here goes. The sideport (1973-75 Xl's) feel much smaller and lighter. Their seat height is about 4'' lower and they weigh about 40 lbs less. They are great on rough and twisty trails, but really lack the power or size to cruise at 50+ mph comfortably. They have WAY less torque, and require constant shifting on twisty or hilly roads / trails.
The centerport (1976-78) Honda XLs feel a lot like the Xt500's. The frames are similar designs and sizes, and the xt500 only weighs about 25 lbs more than a honda 350. The xt500 and centerport Xl350 feel and handle very similar. The centerport Hondas feel more stable on the road at 50+ (compared to the older sideport frames), although a 350 with stock gearing struggles to maintain 55 mph with hills, headwind, or heavy gear on board. The xt500 is MUCH better on the open road. I think I could cruise at 55 mph on my xt500 for hours, and it is still great for the fire roads and trails!
(Both Hondas will go up for sale this spring after I get my other xt500 up and running... it is currently taken apart and getting new piston rings and a hone/deglaze)
Sidecar Jockey is offline   Reply With Quote
Old 04-11-2013, 12:06 PM   #587
wrryder
wrryder's Avatar
Oddometer: 165
Very nice! Love the swingarm and headlight.
Originally Posted by 'Rett Butler View Post
So hope this is ok with you guys. Its not a resto - just well cared for. I've been riding it since I was 14.
Craig
RD07a
Sacramento, CA
Don't Feed the Bearcat!
wrryder screwed with this post 04-11-2013 at 03:55 PM
wrryder is offline   Reply With Quote
Old 04-11-2013, 12:18 PM   #588
wrryder
wrryder's Avatar
Oddometer: 165
Eye Candy!! WR426 forks but where do you get the triple clamps that will work with the stock tank??? Custom made ($$$)?????
Originally Posted by Rus View Post
Photo 3
Craig
RD07a
Sacramento, CA
Old 04-11-2013, 03:02 PM   #589
teledan
teledan's Avatar
Oddometer: 85
Nice looking bikes here! Here's my 1981 XT500:
And here is my thread:
http://advrider.com/forums/showthread.php?t=877524
teledan is offline   Reply With Quote
Old 04-12-2013, 06:40 AM   #590
Sidecar Jockey
Oddometer: 632
Does anyone know where I can get a rear rack for my xt500?
Or, could someone post pictures of a rack they have so I can look at somethig to go from to build one?
Old 04-14-2013, 07:49 PM   #591
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Have a look a mine. No stickers or stamps so I don't know who made it, but it seems mass produced rather than one-off.
Seems decent size. Doesn't really stick out anywhere.
Mounts to the turn signal bosses and the rear fender loop. Guessing the loop was drilled for the install.
Detail of the loop mount. Pretty sturdy, I can pick the bike up with it. I'd trust a 6 pack on it.
Let me know if you have any more questions.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 04-14-2013, 10:05 PM   #592
vudu
vudu's Avatar
Oddometer: 188
I have seen these guys sell them from time to time.
Manracks
vudu is offline   Reply With Quote
Old 04-15-2013, 07:32 AM   #593
Sidecar Jockey
Oddometer: 632
JAB,
Thanks for the photos. Thats exactly the kind of rack I want.
It looks pretty easy to make... I can probably weld one up from 'scrap' sitting in the garage. It looks like a small diameter piece of steel tube and some steel flat stock is all I'll need.
I just want it to hold a 1.25 gallon gas can, and a small bag of food and supplies, all of which probably weighs less than 15 lbs. Your rack looks plenty sturdy for that.
I'm thinking that I might add an extra loop of steel tube to each side of the rack to make a tiny 'crash bar' for the turn signals. I'n tried of breaking off turn signals every time the bike goes down.
Thanks again!
Old 04-15-2013, 08:20 AM   #594
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
JAB,
Thanks again!
I think you will be fine with 15 lbs. I can push/pull on the rack and it does not move. Seems we have the same bike in similar shape. Missing a few bits and bobs, but the motor is quiet and has good compression. Just got to push a few things around and get it on the road. Good luck with the rack. Post up a pic when you are done.
1991 Honda XR628R
1978 Yamaha XT500
Old 04-23-2013, 08:33 AM   #595
Sidecar Jockey
Oddometer: 632
This might be a stupid question... but does anyone know the differences between the C, D, E, F, G and H models of the xt500? I thought it indicated the year of production, but some letter codes were sold in multiple years.
For example, all 4 of my xt500's are "E", but one is a 1977, two 1978's, and a 1979.
My buddy has a "F" 1979 xt500 and it looks identical to my "E" 1979, except the exhaust because he has a supertrapp...
Old 04-23-2013, 08:51 AM   #596
stteve
Oddometer: 371
Found this, but not sure if this is completely correct:
http://www.topspeed.com/motorcycles/...0-ar37550.html
Yamaha started producing its first 4-stroke enduro in 1976 and it was named XT500C.This bike started the rich heritage for the next generation of reliable enduros.
In 1977 the bike became brown and to mark its evolution, Yamaha added a D to the name of XT500. It had the same technical features, wheels and structure.
As you probably guest, in the following year, the bike was called XT500E. The U.S. model sported the first polished aluminum tank. I should also mention the addition of black fork gators in 1978.
The 1979 XT500F model added new rubber turn signals and a brand new kick start indicator.
In 1980, the bike was not improved and 1981 XT500H was the final production version of the XT500 in the United States.
At the European models we notice the new skid plate and head pipe. The European 1978 XT500E had a new red and white color scheme in stead of a polished tank and black fork gators that were also added that year.
1981-1985 XT500H had a new rear fender and headlight.
Again, there was little change for the XT from 86-89 but we should notice the newer style rims.
Now-1977 YAMAHA XT500 - 1996 HONDA XR400R - 1991 YAMAHA XTZ660
Sold-1983 XT250/1991 TT350/1996 TT600E/1985 XT350/1999 TT600R/2002 TT600R
stteve is offline   Reply With Quote
Old 04-24-2013, 07:11 PM   #597
Sidecar Jockey
Oddometer: 632
Does anyone know where I can buy a new (or rebuilt) stator for my 1979 xt500?
I know there are a bunch of used ones on Ebay... but a would prefer to buy a new or rebuilt one from a reputable source.
Old 04-24-2013, 07:36 PM   #598
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Ricky Stator does rewinds. You might check locally with a alternator/starter rebuilder to see if they can do it.
1991 Honda XR628R
1978 Yamaha XT500
Old 04-24-2013, 07:40 PM   #599
brucifer
brucifer's Avatar
Oddometer: 2,526
I've heard good things about Ricky Stator. They may be able to re wind yours. Click on this link. http://www.rickystator.com/04technic...rewinds01.html
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 04-24-2013, 07:41 PM   #600
brucifer
brucifer's Avatar
Oddometer: 2,526
JAB beat me to the punch.
Times are GMT -7.   It's 01:09 AM.
