Go Back   ADVrider > Riding > Trip Planning
Old 06-04-2008, 08:18 AM   #61
rob1313
Still learning
rob1313's Avatar
Oddometer: 4,381
[quote=Yak_KLR 650]
Originally Posted by rob1313
I need to ensure it is still a multi fuel, the add does not specify but most with the seperate fuel bottle are.
/quote]
Not true Rob. If it doesn't specify, it probably isn't multi fuel. Check out a Whisperlite Internationale - the multi fuel variant of the Whisperlite. Compact, relatively cheap, easy to field repair (buy the maintenance kit).
Thanks for the tip. I bought a MSR PCS stove. Not a multi fuel but it packs very small and fits my needs. It's just me on the bike most days.
"To live is the rarest thing in the world. Most people exist, that is all." - Oscar Wilde
rob1313 is offline   Reply With Quote
Old 06-11-2008, 06:35 AM   #62
benw
off on a DR650...
Oddometer: 14
I have to agree with the Optimus Nova. We looked at the MSR but the Nova won out on a few counts:
1. Packs smaller
2. Takes more types of fuel
3. Has adjustable temperature
4. can switch fuel bottle over so fuel runs out and no spills in bag
5. easier to clean (for me)
i know its been said above, but just repeating it - cos its so good!
benw is offline   Reply With Quote
Old 06-20-2008, 08:48 PM   #63
sherco
Oddometer: 101
stove
A little heavy for ultra lite backpacking, but perfect for the motorcycle------JETBOIL
sherco is offline   Reply With Quote
Old 07-05-2008, 04:43 AM   #64
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,408
i worked at an REI for many years in college as a shop tech and backpacked my ass off (including deep-wilderness in ID and WY).
while working in the shop i wrenched on bikes and tuned skis/boards but also rebuilt tent poles and stoves.
the MSR stoves are very nice because they are light, pack small, and should you have a problem you can find parts at many (dare i say nearly all?) camp stores, including all 60 or so REI's (REI owns MSR) who will next-day you parts if you're stranded or repair it if you're nearby. back in those days you had to prime most of the MSRs-- fill the small cup under the burner with some fuel, light it, and once the burner is hot it will draw the fuel itself. from the looks of it, not much has changed. i had the whisperlite which, as noted, was good to boil but not to simmer. i never found this to be a problem given what we eat on the road (mac and cheese, raman, dehydrated mealpacks, rice in a box, etc which all use boiling water). you do need to keep these MSR's clean. this takes about 2 minutes with the kit they sell. carbon and fuel residue will gunk them up. fuel bottles available in many sizes. the fuel bottle can be kept outside of your panniers so no spills occur.
i also had a coleman dual-fuel stove which was pumped and needed no priming. the burner sits on a small fuel tank which makes it possible to travel for a 3 days without needing extra fuel. it's a good stove to take when you're planning on eating out but want a stove to take 'in case'. the fuel will hold for several weeks without incident. one drawback: they are hard to work on. dare i say they aren't really designed to be worked on-- at least in my time. should they go bad you'll have a hard time getting things replaced... more difficult than the MSRs, anyway. that being said, i didn't see that many come across the work bench. the ones that did were rightly fucked and many never worked again. the fuel tank sealed well and many never had an issue with a spill. still, they sell a bag with is both padded and will contain any fuel spill. if you're planning to place this thing in your pannier, take care unless you really enjoy the smell of petrol.
be aware that some stoves were dual-fuel, some multi-fuel. some would work on any sort of gas (maybe you'd have to change a jet) and some would work only on 2 sorts, white gas and kerosene. anyway, you get the point-- make sure you get something that will work with white gas and unleaded. some of the MSR's would burn anything approaching petrol-- great for europe where bad fuel or even bootleg vodka maybe you're only hope.
as far as the optimus stoves (and there were a few other euro stoves out there as well, some were optimus stoves but re-branded) they worked very well and seemed fairly easy to work on. the parts werent' always easy to get in a timely manner, but we didn't need a lot of those either. most had a small fuel tank as well and some folded into their own little package, very slick, very well used by the mountaineering crowd. the most common downfall of these stoves was the fuel being left in for months-- sometimes years, and crudding everything up. i did get one from the 1950s (?) to work again after cleaning the varnish from what was left of the fuel out of every tube and valve. i saw one that had to have been used as a military cookstove. i never owned one but i can attest to their performance.
i never liked the propane cannister stoves. simply put, if you run out of fuel and there's no store near that sells that brand of cannister, you're stuffed. aside from that you're tossing out another piece of trash. i've never used one so i've little to add. i can say this... i've never worked on one either, if that tells you anything about their simplicity.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 07-06-2008, 08:34 PM   #65
Pele
NYC
Oddometer: 270
$11.97
http://cheaperthandirt.com/ZRW170-297-1391.html
Rides end, memories don't.
Pele is offline   Reply With Quote
Old 07-09-2008, 08:52 AM   #66
Algentry1
no longer valid
Algentry1's Avatar
Oddometer: 54
Thumb Then there's the classics....
Click on image
eBay...60 Bucks
These don't break
I actually carry and use it.
Optimus discontinued
Al in Oklahoma
Another Friend of Bill's
Algentry1 is offline   Reply With Quote
Old 07-09-2008, 10:05 AM   #67
TheDudeAbides
Sarcasm free11/11/10
TheDudeAbides's Avatar
Oddometer: 7,889
Get the JetBoil. Lite, small and FAST. I've been through a lot of stoves over the past 20 years and I'm so glad I switched ot the JetBoil 3 yrs ago.
Best dualsport mirrors I've ever owned
2001 BMW F650 GS Dakar (Stolen!)
2004 DRZE
2004 BMW 1150 GSA
TheDudeAbides is offline   Reply With Quote
Old 07-10-2008, 12:11 PM   #68
Chopboy
Chopboy's Avatar
Oddometer: 6
+1 Optimus Nova
Chopboy is offline   Reply With Quote
Old 07-17-2008, 08:08 PM   #69
twopiper
Oddometer: 2
I've got the MSR whisperlite and love it. It's saved my butt stuck in avalanche shutes at 9000ft in a tent for 4 days, it'll work for you. Burns damn near anything but Yak butter, and is easily maintainable in the field. Doesn't simmer worth a damn, but I'm no gourmet. I like the practicality and the heat, and the shaker jet works great.
twopiper is offline   Reply With Quote
Old 07-22-2008, 08:00 AM   #70
Jmack
Oddometer: 17
A couple people mentioned these, but heres a link to do it your self
http://zenstoves.net/
Jmack is offline   Reply With Quote
Old 09-02-2008, 11:17 AM   #71
79SouthJim
79SouthJim's Avatar
Oddometer: 275
I have been watching this thread for sometime, hoping someone else would ask this question, in case there is some kind of obvious answer that I overlooked.
Before camping with my motorcycle, I had always just used a small bottle of propane with a single burner stove. Is this dangerous to take on the bike? Is it just an outdated way of cooking these days, or simple an issue of storage? I hate to spend money on something new, if my old stuff will still work for me.
Thanks,
Jim
79SouthJim is offline   Reply With Quote
Old 09-02-2008, 03:23 PM   #72
Dr. Benny
Enjoying the Journey
Dr. Benny's Avatar
Oddometer: 859
Jetboil - integrated, efficient, simple.
Dr. Benny is offline   Reply With Quote
Old 09-03-2008, 02:18 PM   #73
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,569
If it is working for you, then it works.
Thanks,
Jim
100mpg is offline   Reply With Quote
Old 09-04-2008, 09:45 PM   #74
TJ Willy
ADV, this, I crave.
TJ Willy's Avatar
Oddometer: 345
JetBoil +1 jabillion!!!
I put off buying my JB for the longest. I used alcohol stoves and even some ultra light burners... But when I started traveling by bike and camping, I decided to give it a shot... but what REALLY got me to switch is when camping with a buddy, he pulled out his JetBoil and had coffee in like 2 minutes. It was amazing.
Also, someone said above that the fuel does not last long... I have been on the same small canister for at least 10 uses. It cooks SO fast - you don't burn much fuel. It gets hot quick.
Someone else said not to believe the hype. I was that way for the longest till I saw the thing in action. It became clear, my way of thinking was a little one sided.
Everything - fuel and even the french press for coffee fits in the boiling cup. Nice and compact... not backpack ultra light compact, but good for traveling.
You can't really cook with it though... heat up beans or a can of soup. It gets too hot. Maybe some have had luck with it... I just won't try it. NOW having said that, there may be an attachment for the thing allowing a full range of uses. I get the dehydrated stuff and add hot sauce to it... pretty good. Easy to clean.
I found mine at 20% off with one of those online coupons. So shop around and you might get a good deal on one.
Phil
2009 Solo TAT Ride Report
01 F650 Dakar | '99 Triumph Trophy 1200
SmugMug Goodness Coupon Code (GZnn7vYHaHJjg)
TJ Willy is offline   Reply With Quote
Old 09-04-2008, 11:44 PM   #75
JustAL
JustAL's Avatar
Oddometer: 1,290
Dragonfly all the way.
The heat out of them is awesome and I've never had a problem simmering. Last week I whipped it out for a brilliant fondue.
From what I've seen many folks are too hamfisted when it comes to selecting the finer settings for simmering. MSR does suggest to use less pumps to maintain a fine flame but I found it easy with the standard 20 pumps and the last 1/16th of adjustment. You only need to understand the flame at a low pressure.
alGARDNER
alexandergardner.com
flickr
WANT TO SAVE $5 ON SMUGMUG? USE MY COUPON! - raflgiWZAtPVY
JustAL is offline   Reply With Quote
Times are GMT -7.   It's 07:23 PM.
