Old 03-30-2008, 05:05 PM   #1
dcwn.45 OP
Frozen Rider
dcwn.45's Avatar
Oddometer: 756
What kind of tire plugs?
I have a small air compressor, and want to carry a patch kit for my Vstrom [tubeless tires].
What kind of plugs should I get, and where can I get them?
Any other tire repair tips or tools I should have ?
dcwn.45 is offline   Reply With Quote
Old 03-30-2008, 05:36 PM   #2
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,025
Some people have success with the plugs (Stop and Go http://www.stopngo.com/motorcycle.asp), but more are happy with the sticky string type repair kits. Especially in steel belted tires the StopnGo pulgs tend to get cut in half and fail. The cheap sticky string kits seem to work but if you want a high quality one, get a Safety Seal one.
http://www.safetyseal.com/store/autokits.htm
The Safety Seal kit can be repacked much smaller (I keep mine in the little StopnGo pouch).
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 03-30-2008, 05:53 PM   #3
VStromTom
Oddometer: 1,579
Those tar snakes Wally sells. Work great.
VStromTom is offline   Reply With Quote
Old 03-30-2008, 07:16 PM   #4
JR356
JR356's Avatar
Oddometer: 3,647
Hi.,
Second on the string/rope type plugs from any auto parts store,Walmart,Kmart,etc.
Monkey Grip and Vulcan are good brands,get the type made for radials.
Someone at one point posted a kit that all broke down and stored
in the handle,I'd like to find this kit if anyone knows the source.
JR356
JR356 is offline   Reply With Quote
Old 03-30-2008, 07:27 PM   #5
ooweel
Jobless, Its OK!
ooweel's Avatar
Oddometer: 799
I use these
http://www.dynaplug.com/
Work great and store in the handle!
ooweel is offline   Reply With Quote
Old 03-30-2008, 07:35 PM   #6
Trinity
Byron in Texas
Trinity's Avatar
Oddometer: 284
+1 on good ole' Wally World sticky rope plugs...plug-n-go sucks ass...(the plugs, not the concept) DAMHIKT
Trinity is offline   Reply With Quote
Old 03-31-2008, 06:43 AM   #7
svwayne
Oddometer: 945
svwayne is offline   Reply With Quote
Old 04-01-2008, 01:18 PM   #8
mkatz
Oddometer: 24
safety seal... looks a bit large!
I've just opened a safety seal tire repair kit that I had ordered last week. The "strings" and tools were a bit larger in diameter than I had expected. Please reassure me: does this kit actually work with to repair typical screw/nail holes without require monster strength to insert?
mkatz is offline   Reply With Quote
Old 04-02-2008, 04:46 AM   #9
svwayne
Oddometer: 945
I've used mine with no problems. Use the lube supplied in the kit. Make sure you have the SSRS or SSRA size plugs and not the larger ones for trucks and heavy equipment.
Old 04-02-2008, 08:13 AM   #10
dan-c
Back
dan-c's Avatar
Oddometer: 13,611
I keep both the stop and go and the string ones in the top case. The stop n go are good for a small puncture but the strings are better for cuts (we have some sharp rocks down here)
dan-c is offline   Reply With Quote
Old 04-02-2008, 10:30 AM   #11
DrumRunner
It's all about the ride!
DrumRunner's Avatar
Oddometer: 1,028
Laugh
Check out this Site: http://www.tirerepairkit.com/ !
That's what I went with.
I haven't had to use it yet, but I like the fact that they pioneered it and supply a good quality kit at a very reasonable price
DrumRunner is offline   Reply With Quote
Old 04-02-2008, 12:38 PM   #12
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,493
Originally Posted by JR356
Hi.,
JR356
JUNK.
www.myerstiresupply.com
Find your local branch and order up a passenger car repair insert kit.
Uses rubber inserts instead of the string that will wick up more road grime into the tire and further contaminating the steel belts.
I used to sell for these guys, good company, great products. They really know what they're talking about.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 04-02-2008, 10:28 PM   #13
JR356
JR356's Avatar
Oddometer: 3,647
Originally Posted by CodyY
JUNK.
Well,you are entitled to your opinion,but those kits have worked just fine for me personally in both auto and MC apps over thousands of miles!
I used to be in auto repair and have changed/repaired more tires than I want to think about.If I did not feel confident with these products,I would not be using them or recommending them.
I have no doubt the product you recommend is just fine too.
The link you provided does not work for me,so I can't see the product.
There have been more than a few reports of rubber plug repairs(Stop n Go,etc)failing in steel belted MC tires.The string plugs don't fail.
The best repair is whatever gets you going,until you can breakdown the tire and use a patchplug.
JR356
JR356 screwed with this post 04-02-2008 at 10:37 PM
Old 04-03-2008, 12:39 AM   #14
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,737
Another vote here that Stop n Go rubber plugs SUCK (I had 2 failures) and sticky strings work (ran one plugged tire 1000 miles and another 4000 miles).
YMMV
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 04-04-2008, 06:40 AM   #15
CodyY
CodyY's Avatar
Oddometer: 9,493
JR356
I agree with you 100% here, this is the only approved method and is the only way to truly "repair" the injury and seal the leak.
Instead of a string plug that will wick road grime and oil up into the tire. Myers/Patch Rubber company (I don't kow what's up with the site?? Should be up) make what's called a Mono-Fill. Instead of gummy string, it's a strip of rubber that's coated in un-cured rubber. They install just like a string plug only you use patch cement on them to seal the injury. They fit tighter, actually seal to the rubber and prevent further damage to the steel belts. About twice the price of string repairs, but what's your tires worth on a bike?
just FYI.
<10 year Lexus/Cadillac Technician/ASE master/Service manager turned Tire supply salesman/ now in construction mgmt.
Times are GMT -7.   It's 10:51 PM.
