04-08-2008, 08:14 PM
#46 | |
Tryin Hard
Oddometer: 2,764
For a more rigorous approach, look up 'self sealing fuel bladders'
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider) |
04-09-2008, 04:17 AM
#47 | |
Old Guy nOOb
Oddometer: 2,690
I use Slime a lot on bicyle tires and it works great on small holes, like from thorns, but if you get a hole too big for it it makes a gigantic mess when it sprays out the hole all over you and the bike, which has happened to me twice.
It isn't the conditions its the decisions Don't bring a motorcycle to a car fight |
04-09-2008, 04:53 AM
#48 | |
Oddometer: 14
I haven't had the need to check out the sealing properties (yet), but from all reports, this stuff works. Usual disclaimer applies. |
04-09-2008, 05:04 AM
#49 |
Redemption.
I'm definitely in the minority here, and this thought is pretty old school.
But riding on a plugged tire is suicide IMHO. I know that there are tons of people that do it. I might do it just to get down the road to a shop. But even if it were a brand new tire, I'd replace it with a good one. I have a lack of confidence in a plugged or patched tire, and when I'm on two wheels, I want everything to be right.
Danger is one thing. But danger plus extreme discomfort for long periods is quite another. |
04-09-2008, 06:02 AM
#50 | |
ADVenture Capitalist
I've said my .02, Ride on.
Not an ACTUAL motorcyclist |
04-09-2008, 06:30 AM
#51 |
®egister this:
Oddometer: 2,966
Well, nothing like a little pissing contest over tire repair.
I've had bad experiences with the stop n go system, but they did have a run of bad plugs i'm told. The goopy cords have worked most consistently for me, they pack well too. Currently running a plugged rear tourance that has over 10k miles on it. About 8k with the plug. I wouldn't use slime either, unless you don't mind the mess it makes. Good way to get on your tire installer's bad side.
04-09-2008, 07:33 AM
#52 | |
Oddometer: 14
04-09-2008, 07:39 AM
#53 | |
Oddometer: 1,214
Good write up! But what about the centrifugal ( know, no such thing) force from the tire rotating at 105 mph (not that I, personally would EVER drive that fast, since that would be illegal and I am a law abiding citizen ). I thought the belts were more intended to keep the tire from coming apart at speed.I know it seems like losing a couple of threads out of a hundred or more is an insignificant percent of the whole, but isn't it like a rope where losing a few strands causes a "chain reaction" that just keeps causing more and more to fail? Obviously, I don't have a clue what I'm talking about , but these would be the thoughts going through my head the whole time I was hauling ass (at legal speeds of course) down the highway with a repaired tire....Terry
"The rights of every man are diminished when the rights of one man are threatened." John F. Kennedy, June 11, 1963 |
04-09-2008, 09:46 AM
#54 |
Gunslinger
Oddometer: 13
Well?
What did you guys think of my stopngo write up on page 3??? For you folks that say the tire will fall apart and explode and collapse into a black hole and kill everyone, what do you think? I had FOUR plugs in the back tire and one very near the sidewall of the front tire and was taking the bike past a ton several times in the course of a month. I think you need to realize that a modern tubeless tire is far tougher than inner-tube tires of the old days. As for stopngo, the shit works, so long as it has been properly installed and it's a round hole. Think of it this way: it's worked FIVE times out of FIVE for me under normal full out riding conditions.
Tip for stopngo people: don't be afraid to pull hard on the plug stem to set it. Use pliers. Also, and very important here: DO NOT cut the stem flush with the tread. It will wear down eventually, but I had a few fall in the tire when cut flush, before I figured it out. I believe it's held in place by friction and by pressure from a full tire. Having said all that, I still carry the goopy linguini as a backup! Who's got experience with Ride-On that actually got a flat? |
04-09-2008, 09:57 AM
#55 | |
Oddometer: 1,422
The above seems fine for a static tire and, really, whoever heard of a static tire blowing a plug? However, when a tire is in motion, it is flexing. I humbly submit that this makes the physics much more complex. More importantly, the puncture is flexing, possibly changing shape and diameter. Over time and miles, I am assuming this could potentially lead to air leaks and/or losing the plug. I realize that motorcycle tires do not flex as much as the sidewall of a car tire, but there must be some movement. Temperature changes due to motion would also affect the size/shape of the puncture, the ability of the plug to adhere to the hole, and the pressure within the tire. All this means it is far too complex for my brain to figure out, but I would not completely trust a plug if I were about to attack some serious twisties.
Bob 2002 R1150R And a harvest of righteousness is sown in peace by those who make peace. James 3:18 |
04-09-2008, 10:03 AM
#56 | |
Oddometer: 1,214
I do know I've read many stories of people having trouble with the stopngos here on ADVrider. Both trouble getting them in, and trouble with them coming out after a few miles. Probably a matter of improper technique, but more people seem to have issues with the stopngo than with the strings. That's why in my "emergency kit" I carry the strings. They seem to be fool-proof enough that even a clod like me can fix a flat and have at least a temporary repair 'till a new tire can be fitted. I use the green slime stuff in my lawn tractor tires. They are so full of holes and even cuts that it amazes me that they hold air at all. The slime really works well. I have no doubt that it will seal a puncture. At least when fresh. But after a year or so? Not so sure. Also, I would like the chance to know I've got a puncture or cut, inspect it, repair it, and decide how much farther I should drive on it. With the run-flat or slime apprach, you might be driving around on pretty cut up tires. I know all the rest of you guys all inspect your tires before every ride, but we are talking about me here .Terry
04-09-2008, 11:33 AM
#57 |
Old Guy nOOb
Oddometer: 2,690
But should I use Dino strings or synthetic strings?
04-09-2008, 01:53 PM
#58 | |
2007 R1200GS Adventure
Oddometer: 741
Check this out: http://www.amazon.com/Slime-Deluxe-R...7774196&sr=8-2 |
04-09-2008, 02:07 PM
#59 | |
Tryin Hard
Oddometer: 2,764
The carcass of the tyre also acts like a composite structural material (fibreglass or carbon fibre) and are quite damage tolerant. In fact, the job of the rubber is really to protect the cords, and to transfer the load straight into the fibres - the rubber itself doesn't carry significant loads. What does happen though, is that when you break a cord, that part of the tyre becomes more elastic (higher local strains) and the load then gets shed into the stiffer adjacent cords next to the break. Your biggest problem now becomes fatigue or just plain tensile overloading in the cords adjacent to the damage. Kevlar and nylon don't have tensile fatigue properties like steel does, however you have to remember that if the increase in local load seen by the fibre isn't enough to exceed its fatigue stress for the number of cycles the tyre will probably see, then nothing will change. As long as the plug is more flexible than the tyre carcass around it, and you managed to cement the whole face of the repair, then you shouldn't have the plug leak for the life of the repair - (by that I mean a reasonable life, not running it down to the cords before replacing it or leaving it in the shed for 20 years and then deciding that it's still a good tyre to use!) THe other point is that if you have a tyre with mostly 0 or 5 degree belts (ie radial ply racing tyres) there is very little to stop the hole splitting sideways across the face of the tread. If you've had a sidewall puncture or a big stick go through your tread and tried to repair it, you'll have recognised this behaviour. This is the type of damage for which a string (or anything) really is a temprary repair. There is a lot more to a repair than a blanket rule - something that many people seem to gloss over. Regarding rotation derived loads in the tyre - For this reason it is never recommended that you use a repaired tyre to its undamaged potential - ie don't plug it and then do racetrack speeds, or here to wollomollo at 200mph. That doesn't mean however that at sane speeds, you can't continue to use a patched tyre - I think the biggest problem some people have with 'temporary' repairs, is that they never take the tyre off and check that the repair was sound (ie you put the string or plug in properly). Does this all make sense? There is analysis in why i'll ride on a patched centre tread hole made by a screw or nail, but when I got this key (that took three strings to repair so that I could limp home), the tyre went straight in the bin! BTW, the maximum open road speed where I live is 110KM/h, not miles per hour. I'm happy running at that speed - not sure i'd run a patched tyre at 170km/h though! ![]() I agree that a purely static analysis isn't the be-all and end-all, but I wanted to point out that cody's scaremongering of 'omg, truely massive pressures inside, it's a bomb, don't taze me bro' (sorry mate ) has no scientific merit. As a first approximation though, the tyre is only a single sided balloon. THe centripetally derived loads may introduce a load equivalent to that that should be taken by the bead (R3 and R4). There are also more cords in the sidewall to take acceleration and braking loads that exceed the centripetal acceleration loads and also take pressure derived hoop stresses away from the tread face, so it shouldn't be a super poor analysis.
He immediately paid me the one of the highest compliments an Advrider can receive: "You're nuts!" (Alcan Rider) bonox screwed with this post 04-09-2008 at 02:22 PM |
01-27-2013, 07:51 AM
#60 | |
Stroppy.
Oddometer: 24,374
Given that its purpose will be to let me finish the ride and then replace the tyre, I'm currently tending towards string type repair kits. Questions: Any more experiences with StopNGo? String repairs - insertion tool with slot at tip and no twist to release vs. insertion tool with slot in mid section and twist to release string? With strings, to use glue or not (kits seem split 50/50)? Best CO2 inflator (no room for electric pump.) Thanks in advance y'all.
. . "Discourage self-help, and loyal subjects become the slaves of ruffians." - A. V. Dicey "The ultimate result of shielding men from the effects of folly is to fill the world with fools." - Herbert Spencer "Socialist governments traditionally do make a financial mess. They always run out of other people's money." - Margaret Thatcher |
