Old 04-06-2008, 02:17 AM   #46
twintwin
twintwin's Avatar
Oddometer: 661
Sorry for the [FONT='Verdana','sans-serif'] stuff, I do not kow what happened!, if the moderator can fix my mistake, I will appreciate and it will be much more pleasant to read. Thanks
twintwin is offline   Reply With Quote
Old 04-06-2008, 08:32 AM   #47
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,636
Originally Posted by mikepa
Four bolts and one electrical connector and the tub can be de-rigged from the bike. It literally takes about 5 minutes.
For maintenance? Looks like the right side valve cover will clear the rigging.
Have you ridden the modified bike w/o the hack?
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 04-06-2008, 06:10 PM   #48
gregbenner
Oddometer: 1,171
Mike, when I posted this, i was only half serious, and was referring to my 1000 Strom/rig. After reading a bit more, and thinking some, which is always dangerous, I am now 90% serious. I certainly dont want to hijack this thread, it is way too cool. I signed up for GlobeRiders, have a few questions on bikes, e.g. a KLR, spoked wheels on my 650 Strom, which trip,etc. I will send you a pm or e mail in a couple days.
greg
We've just provisionally qualified a rider on a 'Strom for the Silk Road next year. Our concerns with this capable-looking bike are twofold: (1). that exposed, chin-mounted oil cooler and (2). the cast wheels. However, we've noted our concerns to this rider, and he understands his "exposure". I look forward to seeing how the 'Strom does. It would be good to put another model on the approved short list. Certainly, Touratech has put their (farkle available) stamp of approval on it .
Best,
2014 Triumph Tiger 800
2015 Vespa 300 ABS
2007 Dyna, 1947 Harley 45 flathead
1975 BMW R75/6
gregbenner is offline   Reply With Quote
Old 04-07-2008, 06:15 PM   #49
mikepa OP
SideCzarist
mikepa's Avatar
Location: Seattle, WA in the Great Pacific NorthWET (USA)
Oddometer: 306
Given that I wear a prosthetic, I don't ride any "bike" unless it has a car attached, so no, I haven't tried. I'd expect the steering would be a bit dodgy .
Best,
Mike M. Paull
'05 BMW R1200GS/EZS Rally "L" (UberHack 1.0)
'05 BMW R1150GS Adventure/Ural "SideCzar" (Uberhack 2.0)
'04 BMW R1150GS Adventure/Ural "WarBird" (UberHack 3.0)
http://www.globeriders.com
Kenmore, WA
USA
"The world is a book and those that do not travel, read only a page." - St. Augustine
"...not all those that wander are lost." - J. R. R. Tolkien
mikepa is offline   Reply With Quote
Old 04-07-2008, 07:59 PM   #50
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
Although the question seems obvious, it's completely unnecessary, whether or not you wear a prosthesis. Once you ride with the hack, you won't want to ride without it
Well, your truth as to that may vary. The real truth is that if you're capable and desirous of riding on two wheels you'll probably want a second bike. AT the very least, the sidecar will wear the tire unevenly, meaning you'll have to keep a set of wheels around as well if you plan on making the change regularly.
Also, once you start to ride the rig and realize how much you like it, odds are you'll want to make additional tweaks to make it 'just right' for sidecar duty that will compromise two-wheeling even further.
eastbloc is offline   Reply With Quote
Old 04-08-2008, 08:19 AM   #51
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
Everyone's trunk rack angles down.
Wouldn't it make it easier to keep stuff on the rack if it were prarallel to the ground?
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 04-08-2008, 08:33 AM   #52
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
Presuming you're going to secure it with something other than gravity, I don't think it matters much :)
The stock Ural rack has a more convenient shape for object retention, with raised bars at the front and back. But if you ever want to strap an object to it larger than the distance between the raised bars, they're a hindrance.
Old 04-08-2008, 11:15 PM   #53
AceRph
Affluenza Free!
AceRph's Avatar
Oddometer: 24,636
Best,
Duh Ace!
Old 11-29-2008, 03:06 AM   #54
rohdster
The Leaping Wombat
rohdster's Avatar
Oddometer: 13
Eek Great Mod but ....
At one point I was considering Jay’s lower bridge but I went another way and have used the Dedome mod to ease the steering effort on my R1100GS rig.http://www.dedome.com/
How to reduce the trail on the bmw with telelever without changing the angle of the fork and of course without dropping the front stock height!!. To do so, the steering angle must be straight up; this angle is the line between the bearing bolt located in the upper fork brace and the ball joint in the lower bridge. To change this line, once again without changing the angle of the fork, the ball joint must be relocated. To achieve this trail reduction, Dedome manufactures a new longer lower bridge and in the same time, to straight up the steering angle, he also changes the location for the ball joint on the A arm (telelever), shortening the A arm (cut and re-welded) to the same distance he has lengthen the new lower bridge (about ¾ inch). In other words, this pivot will move backward, and the trail is then reduced. The result is very convincing; the steering effort is much less. In my opinion the engineering is great and smart (does not change the look of the bike), and the finish is awesome, a real piece of art!
Does anyone know what a telelever is made of?
Perhaps the welding consumables and procedure?
rohdster
rohdster is offline   Reply With Quote
Old 12-01-2008, 07:58 PM   #55
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,312
The TILT does not last. There is a thread with I think a dozen broken ones. But the need is really not there anymore is the rig if well ligned up. I must have been lucky as mine is and I truly do not miss it.
Shocks... TwinTwin and someone else came up with a tongue weight formula which I believe is 60% of the car weight will be on the bike. Out of that weight 60% is on the rear. I changes my Ohlins to springs for a 500lb +/- rider and it is fantastic. A bit stiff off road but very doable. I just installed a HAGON shock on the Ural. For $140 delivered these people sell value!!!
This rear wheel fabricated by David Hinze (owner by the way of that rig on page #1... red GS + Ural) has made all the difference in the world, handling and comfort. I have done much off road with it and amazingly, could be the much larger footprint it goes through deep sand and all with much ease...
More photos here...
It is a 30,000 mile tire VW...
Juice... with 7 headlights and full Gerbing gear I have never had a problem using also an Odyssee battery...
Great thread... much drooling!!!
Be well... see you down the road!
Ara & Spirit
PS: question about your NATO cans! I just happen to order 2 today with their holders... are you usning them for fuel or water? I will be using mine for water and was told you can line them (somekind of silicone liquid fuel tank liner)... any clues? Thanks!
BeemerChef is offline   Reply With Quote
Old 12-01-2008, 08:02 PM   #56
eastbloc
comprador bourgeois
eastbloc's Avatar
Oddometer: 1,345
So you swapped out the spring on your Ohlins, huh?
How much did that cost, if you don't mind me asking, and how long did it take?
I have been drooling over a shock upgrade for a while, with new kit all around, but I can't afford to do it; meanwhile my rear shock is an Ohlins although set up for a solo ride.
Since that is the most 'deficient' unit for my setup (although the Russian squeaker does not inspire confidence) it may be the cheapest way to improve my suspension...
Old 12-01-2008, 08:32 PM   #57
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,312
If I remember the springs are $100. If Ohlin has it in stock just a couple to three days.
Check with Hagon also.
Best to speak with them on the phone for your needs.
Be well... Ara & Spirit
Old 12-02-2008, 05:15 AM   #58
claude
Sidecar Jockey
Oddometer: 3,642
Ara wrote:
>The TILT does not last. There is a thread with I think a dozen broken ones. But the need is really not there anymore is the rig if well ligned up. I must have been lucky as mine is and I truly do not miss it.<<
It is still nice to have some adjustability if possible. If the electirc setup is questionable a manual setup can take it's place. That way if loads in the sidecar vary or road conditions warrant it the driver might be much happier.
Example: Droning down a long straight road all day is no fun at all if the rig wants to pull to the right . To be able to easily dial in a little more tilt to take this away is never a bad thing.
Have to admit on my personal rig the manual tilt is very seldom used but if needed it is nice to have a simple option.
Ara wrote:
>>This rear wheel fabricated by David Hinze (owner by the way of that rig on page #1... red GS + Ural) has made all the difference in the world, handling and comfort. I have done much off road with it and amazingly, could be the much larger footprint it goes through deep sand and all with much ease...<<
I was looking forward to seeing Twin Twin and David as they were heading to the shop a couple weeks back but something came up. Was sure looking forward to seeing the wheel that David is making. Great looking product from th epictures and the way David explained to me on how he had done it sounds great. Not surprized as David is quite the craftsman when he gets into something.
As you know we have done many rear wheel conversions using the same tire (165r15) and I can attest to how well they perform. We never have setup to do the conversions for bikes other than the ones that had the brake rotor seperate from the wheel. David pulled that off and it is good to see!
If ANYONE feels the cost of a wheel conversion to run a car tire is high all they have to do is weigh the issues in front of them. Theses tires run around 50 bucks or so. Compare that to motorcycle tire prices. Then compare what kind of milage one gets between the car tire and a cycle tire on a typical sidecar rig and it isn't long before the value in doing the conversion begins t make sense.
We have found that the 165 tires typically get at elast 20,000 miles and soem guys have gotten more than that. The worst we have seen was 16,000 but it was on the rear of a K1200LT that ran a lot of miles in the hot southwest pulling a large camper trailer. The setup on that rig was also unknown so that could have been a factor. Heck even at 16k for a 50 dollar tire the economics still are good in the long run.
Some have opted to run 155 tires which are just a little smaller in diameter than the 165. This gets the rolling diameter back to stock so the speedometer is not off hardly any. Even with the 165 the eror isn't much at all especially if you consider that BMW speedos are not really known for being that accurate anyhow. The 155 does cost more.
Others have run down to 135r15 tires. These are much smaller in diameter and do cost more. Availability is also an issue. Coker Tire typically stocks them though.
I think for the GS type rigs the 165 is the champion. Costs are not bad and avaiability is USUALLY decent. Note that it is not a bad idea to purchase two of these tires when doing the conversion. Keep one on hand as a backup spare. These tires are manuafactured regularly but not daily so to speak.
There have been times when on hand stock was limited or non existant for short periods on almost a national basis and that could be a bad deal if someone needed one immedialtely. I don't think we will ever see the 165 tires quit being made as they were a tire made for the older VW Beetles and are still quite popular among th eBeetle nuts and also some dune buggy folks.
It is possible to groove these tires if a more agressive tread is wanted. Installing studs for winter are also a possibility.
Below is a pic of one of our conversions on a K100 rig we built.
Claude
http://freedomsidecars.com/
claude screwed with this post 12-02-2008 at 05:52 AM
Old 12-02-2008, 07:00 AM   #59
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,312
I have to say that I DO FOR SURE like the fact that in 5 minutes I can dial in manually the TILT mechanism, which I have till I got it right... Quite often, with my rig anyhow, even a new tire versus an old worn out will affect which way the darn thing wants to go!!!
Hope you get to see that wheel soon Claude... Even if I only get 15,000 miles I will be more than happy! + as Dave says, I can change it with 2 butter knives!!!
PS: can't wait to see you shop!!!
Times are GMT -7.   It's 03:46 PM.
