11-03-2009, 06:27 AM
#136 | |
Tuareg 2013
Oddometer: 11,344
So, in fact I mispoke above, my bike has 19mm offset as well.
For Sale: FJ60, or Defender 90, Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
11-03-2009, 07:13 AM
#137 |
Terlingua
Oddometer: 235
Neduro your right I had seen that they were set to 19 in the parts look up. If they are set at 19mm I thank it would be hard to see any real deference in 1mm.
I am still looking for gas range ya'll are getting out of the stock and bigger tanks? BCK
Just a nother day in paradise! Down to 94 FXR'1 custom HD 02 KTM EXC 200-plated FOR SALE 06 KTM 950 Adventure 09 KTM 450 XC W-plated |
11-22-2009, 05:20 PM
#138 | |
Oddometer: 313
1) With your '09 530, did you experience any of the oil usage issues some owners have? I got 600cc out of the engine side on my 09 the first oil change and I put 600cc back in. Next change I got 550cc out and put the same in. Next one was 450cc out. No smoking or problems with the bike, but I'm adding between 50 and 75cc of oil every couple hundred miles. 2) The 2010 rings are updated and supercede the 09 rings, which makes me wonder if there's an issue with the 09s. Is your oil level stable and are you getting consistent amounts out when you drain the engine? Thanks. Redline screwed with this post 11-22-2009 at 08:30 PM |
11-22-2009, 07:16 PM
#139 |
OCD Hobbiest
Oddometer: 321
Same here
on the adding of 50-100 cc of oil every couple hours... 2009 530EXC.
11-22-2009, 08:47 PM
#140 | |
Motion is Life
Oddometer: 1,856
I now have 11000km on mine and am thinking it might be time for a top end rebuild - so plan on another leakdown test to see if it is really necessary. The plan it to do this tomorrow (either make a Leakdown tester or take it in) so we'll see what comes of it. D
"If it is small enough to eat in a single meal, don't worry about it, hit it!. If it is too large to eat in one sitting, get the hell away from it!" Jack Splash commenting on animals on the trail. Rally Connex Adventures Off-Road Adventures Make It Stick Media Adventure Has No Destination 08' KTM 450 EXC - The Half Beast - 04' Yamaha TTR250 (for the wife) |
11-23-2009, 03:57 AM
#141 | |
Oddometer: 2,433
JayBo on Safari Bro 1, Kiwi Safari Team, Perth, WA KTM 450 Rally ... arrived ![]() ![]() KTM 530 EXC-R (R for Rally, right!!) ... or Retired or Redundant ![]() Cagiva 750 Elefant - Lucky Explorer '88 |
11-23-2009, 04:48 AM
#142 | |
Tuareg 2013
Oddometer: 11,344
Out of curiosity, does the bottom clamp have 2 bolts or 3? In the US, the uppers are all the same as far as I can tell. The lower clamps on XC-W and EXC are 2 bolts, and have a 19mm stem installed. The lowers on XCs and SXs (everything with twin chamber suspension) are 3 bolts and have the 1mm offset stem. When I was in Mexico this spring I offered to help someone with their 990... and it was completely different than an American one. Turns out Mexico gets AU bikes, it's interesting how they mix spec for different countries.
11-23-2009, 04:55 AM
#143 | |
Tuareg 2013
Oddometer: 11,344
My 09 was pretty stable on oil use- a little bit but not much. My 08 consumed more, and 08 rings supercede on part number to the 09's. My 10 is still new enough that I don't have a good read- it's only got 30 hours or so on it. Been too busy to ride enough! Interesting to hear that there are now 3 different spec of rings. I don't measure when I drain, though I probably should and it's a good idea. I have a ritual I go through starting it before I get dressed, letting it idle for 3-4 minutes, then checking engine oil level. I don't worry where it is in the window other than at that time. ---- An interesting note- my Dirttricks Ironman Sprocket (50T rear) has been on all 3 530's and even done time on my 300- it's got something like 400 engine hours on it, I'm guessing, all off-road, all being flogged. I was so impressed with it's durability that I ordered another one for my 300, and when I held the new one over the old, the wear was indiscernible. That's amazing to me. The chain holds up a lot better too, since it's not stretching across weird tooth spacing on the sprocket... typically, I get about 60-70 hours out of a set of chain and sprockets. Money well spent, IMO!
11-23-2009, 05:00 AM
#144 | |
Oddometer: 2,433
11-23-2009, 08:26 AM
#145 | |
Oddometer: 313
11-23-2009, 09:11 AM
#146 |
OCD Hobbiest
Oddometer: 321
Ned - I'm curious, because the manual says to only check the oil level window when the engine is cold... What gives? Thanks! Toby |
11-23-2009, 06:21 PM
#147 |
Oddometer: 591
Oil use on these bikes comes from super vacuum from air box. Run rocker breather and crank breather to UNI filter up behind radiators, one on each side using 3/8 fuel line. You will be happy. Don't believe me? I bet you have a puddle of oil in the bottom of intake just behind your filter. Just two cents from a Utard.
11-24-2009, 05:44 AM
#148 | |
Tuareg 2013
Oddometer: 11,344
![]() Seriously, I found that I got different oil height readings (sometimes higher after being lower without adding anything, therefore it had to be inconsistent), so I came up with something that seems to be consistent for me. Typically, I run it a bit overfull as well- you have to tip the bike slightly away to get the oil down to the top of the window. Mine have all come that way from the factory, and don't pump it out the breather which is the typical sign of overfull in my experience. ![]() If you're blocking off the breather as Ryman suggests (did it on my 08 and 09, haven't yet on the 10 but it hasn't consumed any) then you may be able to find a Zerk grease fitting at your hardware store with the correct threads to block the carb entrance more convincingly than just a rubber plug that could split.
11-24-2009, 07:52 AM
#149 | |
Oddometer: 313
I run a closed loop vent that I read about on KTMTalk, so the rocker cover breather does a big loop up along the frame then down to the 'T' that leads to the carb...it basically uses gravity to keep oil from getting to the carb, but it doesn't end with a filter. Maybe I should give the Uni a shot.So you're running both the crank vent and rocker cover to two separate filters? Did you see a drop in oil usage after doing this? |
11-24-2009, 11:57 AM
#150 | |
Wanderer
Oddometer: 2,442
I think the Blais de-smogging kit just runs the crank and valve cover breather hoses out the bottom of the bike. dc |
