04-28-2011, 07:38 PM
#1486 |
Oddometer: 44
Take the smallest drillbit you have and drill a small hole in the seal, then take a small fine thread wood screw and screw about two threads in the hole then pull on the screw.
Before putting the screw in I would use a shop vac to suck any shavings out of the hole, even if you cant get them out they are really soft and no damage will occur if they get past the bearing.
2007 XR650R 2007 KTM 300XC-W 2011 KTM 530 EXC |
04-28-2011, 08:40 PM
#1487 |
Texas Aussie
Oddometer: 130
so my bike has less than 2 hours on it and the end cap/screen has gone missing. Is it the actual spark arrestor or is it just a noise reducer? i wouldnt bother with it if its just for noise, but i do want to ride in the forest and dont want a ticket from a ranger for no spark arrestor..
2012 Triumph Scrambler |
04-28-2011, 08:49 PM
#1488 | |
Special Purpose
Oddometer: 5,359
Noise is bad for the sport. |
04-28-2011, 09:01 PM
#1489 |
Texas Aussie
Oddometer: 130
thanks. i agree about noise being bad, but i havent been able to tell its any louder than when the screen was in, the stock pipe seems reasonably mellow to me.
04-29-2011, 04:02 AM
#1490 |
Oddometer: 4
I took out the restrictor inside and somehow my screen also fell out on a ride, guess i didnt screw it back on tight enough. Anyhow noise does slightly increase but still very respectable. I get passed by some of those crotch rockets that are much more loud. Theres also a vid on youtube with a sound test with the above mods, it ranged 94-95 db.
04-29-2011, 09:32 AM
#1491 |
Adventure Now
Oddometer: 37
Loc-Tite (the red kind) works as well.
04-30-2011, 07:06 PM
#1492 |
North Georgia Dual Sportr
Oddometer: 1,692
Roger that
![]() The Blue is useless
2008 KTM 690 ENDURO ![]() http://www.advrider.com/forums/showp...postcount=1784 http://www.advrider.com/forums/showp...postcount=8594 http://advrider.com/forums/showpost....&postcount=683http://www.youtube.com/watch?v=gnFCdoc_IDE |
04-30-2011, 07:15 PM
#1493 |
Oddometer: 1,692
That is one FINE LOOKING BIKE, Orange Frame & all
![]() It just needs SILVER RIMS to match the SILVER FORKS 3
05-02-2011, 01:38 PM
#1494 |
Oddometer: 50
A pic of the AWD build as it sits, about 60% complete. Taking my time, 1st KTM so familiarizing myself with not only the bike, and setup, decorking, emissions delete, aftermarket armor, suspension, controls and other parts, but also the AWD conversion.
Question: Is the black plastic housing in the coolant lines above the crankcase a thermostat? Can I eliminate it? With factory XCW parts, or an aftermarket line kit? Thanks in advance. |
05-02-2011, 01:43 PM
#1495 |
Oddometer: 50
Also, as above the screen in the exhaust tip is NOT the spark arrestor? It's for noise supression? I wired it on. Cut out the internal restrictor.
05-02-2011, 01:53 PM
#1496 | |
Hydrophobic
Oddometer: 2,400
![]() I think the real spark arrestor is a Krizman (sp?) type way down in the muffler.
2011 KTM 990 Adventure R 2010 KTM 530 EXC 2009 KTM 950 Super Enduro Erzberg Edition |
05-04-2011, 03:46 PM
#1497 |
Oddometer: 22
don't start with kick
HI every body, my bike start verywell with the e-start, but won't start with the kick
any issue ????when I try to ride at a regular speed like 50mph, it's seem the rpm won't still a the same point it's alway have a small variation, making the bike very hard to drive on road, |
05-04-2011, 06:25 PM
#1498 | |
Oddometer: 845
Dan 2010 KTM 530 EXC Champion Edition - factory street legal Pix - http://Bora20.smugmug.com/ |
05-04-2011, 07:30 PM
#1499 |
Oddometer: 13,676
530 changes from 2008-2009? I know they fixed some things with the 2009s, and that would be the way to go, but if you found a 2008 for the right price...
How would you know if it was a burner if buying it used? What could you check? Anything that would make less than 2009 a deal breaker? I know Ned seemed to like his 2009 a lot more. |
05-04-2011, 08:08 PM
#1500 |
Oddometer: 22
It is already re-jet, de smog, my question his more it his to lean or to rich or wrong carb set up
