Old 05-21-2011, 09:59 PM   #1546
Deseret Rider
Deseret Rider's Avatar
Oddometer: 248
Thoughts on tire balance
I've mounted a set of Dunlop 606's--When I finished the front tire and put it on the static balancer I was disappointed with the amount of weight it took to balance it. So when I had the back tire off I put the bare wheel on the balancer and found it was balanced pretty well with the rim lock off. The rim lock weighs 4 ounces. That's a lot of weight to counter. I went ahead and balanced the wheel by putting 4 oz of weight opposite the rim lock. Then I mounted the tire with the little yellow dot (supposedly the lightest spot on the tire) adjacent to the valve stem. I mounted the tire and checked the balance. It was very close to balanced so the tire itself was well balanced.
Now---I am not pleased with having so much weight hanging on the spokes opposite of the rim locks. I think a solution might be to drill the rim and mount two 'Light locks" from Motion Pro opposite each other? The "Light locks" are less than half the weight of the stock units (thanks for the tip Hodakaguy). They would counter each other and require very little hung weight to achieve good tire balance. On the other hand they would add difficulty to an already difficult tire mounting job but should not make it impossible---????-
Comments from anyone who has tried --or is running--- dual locks on KTM rims would be much appreciated>>>>>>>
Deseret Rider is offline   Reply With Quote
Old 05-21-2011, 10:27 PM   #1547
Bora20
Oddometer: 854
Why not?
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 05-22-2011, 09:07 AM   #1548
Deseret Rider
Oddometer: 248
Why not?
Just seems less sanitary than having the weights internal and out of harms way. What's not to like about that?
Old 05-22-2011, 09:17 AM   #1549
spagthorpe
spagthorpe's Avatar
Oddometer: 14,719
I could see a concern if you thought you could somehow lose the weight while riding. Otherwise, balanced is balanced.
I like the idea of the light locks though. I wonder how much more of a pain in the ass it would be to mount tires with those? I hate dealing with one rimlock.
spagthorpe is offline   Reply With Quote
Old 05-22-2011, 09:47 AM   #1550
Bora20
Oddometer: 854
I bought the screw spokes weights this week. I don't think they will get lost.
Dan
Old 05-23-2011, 06:48 PM   #1551
Deseret Rider
Oddometer: 248
Tire removal
I've been doing it wrong all these years!
no---not that
This;
http://www.youtube.com/user/DUNLOPTI.../9/TVKzoaL8qaI
Old 05-23-2011, 07:01 PM   #1552
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 862
Originally Posted by Didn'tDoit View Post
Nice setup! Is that handlebar custom made?
My right arm is shorter by a couple of inches
FlyingDutchman is offline   Reply With Quote
Old 05-23-2011, 07:08 PM   #1553
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
No really, what the heck is going on there??
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-23-2011, 07:14 PM   #1554
FlyingDutchman
Dirt Biker
Oddometer: 862
2 Rim locks?
In addition to balancing the wheel, it will allow you to ride on a flat (front or rear)when you are in a pinch.
Can someone post a link to the Motion Pro Lite rim locks?
Old 05-23-2011, 07:16 PM   #1555
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
Here ya go. Rocky mountain atv, etc also carry them. http://www.motorcycle-superstore.com/2/9/203/32819/ITEM/Motion-Pro-Liteloc-Rim-Locks.aspx?SiteID=CSE_Gbase_32819&WT.mc_ID=80003&zmam=88421133&zmas=1&zmac=45&zmap=32819
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 05-23-2011, 07:19 PM   #1556
FlyingDutchman
Dirt Biker
Oddometer: 862
Post 1520 has a close-up pic.
Old 05-27-2011, 12:14 PM   #1557
malcolmzilla
Oddometer: 59
Thumb EXCR 530 Christini AWD
Assembled, broke in at 3+ hours, valves checked and set wide, setup bugs mostly out, about ready for the trail IF IT EVER STOPS FLOODING AND SNOWING here!
malcolmzilla is offline   Reply With Quote
Old 05-27-2011, 12:59 PM   #1558
Chowdown
Texas Aussie
Oddometer: 141
on the trails yesterday, already 92 degrees out. i'd take a week or two of snow
Chowdown is offline   Reply With Quote
Old 05-27-2011, 01:25 PM   #1559
malcolmzilla
Oddometer: 59
Trade? DEAL.
Pic from right now a few miles outside one of the local singletrack riding areas.
10 EXCR530 with Christini AWD, street legal
11 FE570S, dual sport and sumo
15 YZ250FX, woods/race
Old 05-27-2011, 02:03 PM   #1560
Chowdown
Texas Aussie
Oddometer: 141
Trade? DEAL.
wow, they have single track at the Antartic? who knew?
Times are GMT -7.   It's 01:09 AM.
