06-03-2011, 12:28 PM
#1591 | |
Tuareg 2013
Oddometer: 11,344
EXC is like the XCW except with a very small plug at the end, which is easily cut off.
For Sale: FJ60, or Defender 90, Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
06-04-2011, 06:38 AM
#1592 | |
North Georgia Dual Sportr
Oddometer: 1,696
![]() I put a SX silencer on my old 525 EXC & liked it well [exc silencer was restricted compared to the sx]
2008 KTM 690 ENDURO ![]() http://www.advrider.com/forums/showp...postcount=1784 http://www.advrider.com/forums/showp...postcount=8594 http://advrider.com/forums/showpost....&postcount=683http://www.youtube.com/watch?v=gnFCdoc_IDE |
06-04-2011, 06:43 AM
#1593 | |
Oddometer: 5,052
I am running the SX muffler that came with my 07 XCFW 250, it's got a bit more bark and bite to it. The downside is that it does not have a spark arrestor, although I am sure that I could find and end cap that has one. |
06-04-2011, 10:06 AM
#1594 |
Oddometer: 343
How do you distinguish the difference between the the 2010 old frame, and 2010 new frame. The did change mid year, didn't they?
02 Ducati ST4S 08 KTM 530 EXC 03 KTM 525 EXC |
06-04-2011, 12:19 PM
#1595 | |
Tuareg 2013
Oddometer: 11,344
Really, though, all true 10's have the new frame. Only the rebadged 09's (Champions Editions) are the old frame.
06-04-2011, 08:42 PM
#1596 |
Map Guy
Oddometer: 22
Fork Tube Setting in Triple Clamps
I have an '09 EXCR. I am looking for some feedback on how much fork tube should stick through the upper triple clamp. The manual says it should be flush to the top triple clamp. What are you guys running for fast two track and single track?
KTM 350 EXC |
06-04-2011, 09:02 PM
#1597 | |
Wanderer
Oddometer: 2,442
I found the steering was too heavy flush to the triple. YMMV. dc |
06-05-2011, 06:45 AM
#1598 |
Tuareg 2013
Oddometer: 11,344
You should definitely experiment for yourself- other people's settings will be meaningless. Also, note that your rear ride height (sag) will have a similar effect, so there are many ingredients in how the bike handles.
06-05-2011, 12:46 PM
#1599 |
Oddometer: 189
What is wrong here?
After riding, and when the bike is warm, the engaged clutch will allow the engine to idle in gear--no problem---there doesn't feel like there is any 'clutch drag'. Even so, I can't hold the clutch lever in and start the bike because there is so much 'drag' that the bike will 'pull through' the clutch and propel the bike forward. The handle bar lever adjustment is all the way out---that is there is a full 'throw' and maximum apparent travel of the master cylinder piston. What gives with this?
06-05-2011, 06:07 PM
#1600 | |
Oddometer: 644
06-05-2011, 06:17 PM
#1601 | |
Oddometer: 644
Under those conditions, I prefer bars forward, no riser and the forks up 5-10mm...going to experiment with a tall firm seat on those rides too. Dual sporting and rally style riding, I would lean to stock seat, and riser and the forks flush....FWIW. I think I would always leave my pegs in in the stock position to protect my toes. |
06-05-2011, 06:30 PM
#1602 |
Oddometer: 644
Dented head pipe
What do you do when you dent your head pipe?
It hasn't affected performance, at least with my seat of pants observation. |
06-05-2011, 08:25 PM
#1603 |
Oddometer: 189
dragging clutch
Dutch---To clarify-- my problem isn't that the bike won't start---it will start easily in neutral. The problem is that when the bike is in gear I can't pull in the clutch and start it because the clutch hasn't fully disengaged. It's as if the clutch actuating rod needs to be a little bit longer. Or perhaps the 'travel' of the rod needs to be a little bit longer. I do believe I am getting full available travel at the master cylinder because the adjustment there is max'ed---I have no 'slack' in the lever and a full ark available . The fluid level in the master cylinder is full and as far as I know there is no air in the line? So I am puzzled why the clutch doesn't fully disengage? I am wondering if the clutch plates are sticking? I'm using 20W/50 weight motor oil in the transmission and the same in the engine crankcase. I'm inviting comment and suggestion of how to solve my problem ? The clutch should fully disengage and allow the E-start when the bike is in gear---NO?
06-05-2011, 09:56 PM
#1604 |
Map Guy
Oddometer: 22
Thanks for the feedback. I have just replaced the rear shock spring with Trail Tricks extended length spring. Javier recommends this approach in order to minimize the amount of pre-load and prevent coil binding. So far, I like it for my 200# riding weight. I was running 3 rings of fork tube exposed above the triple but once I got the rear sag set correctly, the front end was not quite as stable. This seemed to me like I lost too much trail. I am going experiment with the fork adjustment and will post my findings.
KTM 350 EXC |
06-06-2011, 05:28 PM
#1605 |
Map Guy
Oddometer: 22
Dented pipe
I have read that you can seal the ends, fill the pipe with water and freeze it. As the water expands, it will remove the dent. I am not sure about how to seal the ends.
KTM 350 EXC |
