Old 07-02-2011, 06:10 PM   #1726
Bob599
Bob599
Bob599's Avatar
Oddometer: 284
Screw it!
Yeah I just dropped it off at the dealer and they said its under control. Thanks for the responses!
2006 KTM 950 ADV
2011 KTM 530 EXC
Bob599 is offline   Reply With Quote
Old 07-06-2011, 08:44 PM   #1727
GJRider
GJRider's Avatar
Oddometer: 36
coolant catch tanks
Are any of you guys running coolant catch tanks?
GJRider is offline   Reply With Quote
Old 07-06-2011, 09:29 PM   #1728
Bora20
Oddometer: 854
Nope. I haven't lost a drop of coolant with the fan.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 07-06-2011, 09:43 PM   #1729
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 841
Coolant Catch Tank
Nope. I was tempted with that mod first regarding over heating...especially since the jap bikes go that route. I rode my bike for about 3-4 rides on single track with just the basic mods, needle raised 2 positions, fuel catch can removed and uncorked. It rode fine and never boiled over with air temp. around 25Celsius.
To be safe, I followed the flock and installed the fan & JD jetting and tried to stay with that last year. Every time raced, the fan drained the stock battery, I had to kick a lot, So, I now have the TurnTech battery and Trailtech stator.
With the fan in with the stock themostat, it never boils over..must be better for the motor than boiling over and letting it cool.
FlyingDutchman is offline   Reply With Quote
Old 07-07-2011, 05:36 AM   #1730
GJRider
GJRider's Avatar
Oddometer: 36
Thanks everyone Do the Ktm fan kits run all the time? Or have any of you put a switch to run it manually?
Old 07-07-2011, 08:15 AM   #1731
Hugerush
Furbrain
Hugerush's Avatar
Oddometer: 82
The fan is activated by a temperature switch and only runs when the coolant is hot.
It is, however, connected directly to the battery and will run if the coolant is hot enough regardless of the ignition switch (key) position (like a typical car with an electric radiator fan).
Some people add a switch so they can disconnect it if required to conserve (battery) power. I have found, if it does run after stopping, it is not for more than 5 to 10 seconds so no big deal.
AMA - BRC - COHVCO
2011 530 EXC | 2010 990 ADV | 2006 FLHTXI (figure that out)
If the only tool you have is a hammer, everything looks like a nail
Hugerush is offline   Reply With Quote
Old 07-07-2011, 09:53 AM   #1732
bootz
bootz's Avatar
Oddometer: 115
Talking
I have an '08 530. Installed the fan kit, overflow tank, oversize water pump, high output stator, and a manual switch. We just got back from running the TAT in CO. Dropped down into Moab UT for a day or two (friekin hot!). JD Jetting set for 6000-9000 while in CO & rejetted to 3000-6000 for UT. Puttering around in town or doing slow trail work I'd run around 200 degrees. The highest temp I saw was 225. Running down the trail at speed it would vary anywhere from 177 to 200, depending on load and outside temperature. Never boiled over and didn't notice any change in the level within the catch tank. I'm thinking about adding larger radiators or maybe an oil cooler. I'd be much happier if I could keep the temp under 200.
I let the fan run all the time. With the high output stator and upgraded battery, there was never a time when the battery went low. I did kick start it a few times, just to make sure I could. Worked like a charm
The things we regret the most are the things we didn't do!
08 KTM 530 XCR-W, 02 Honda XR250R,
bootz is offline   Reply With Quote
Old 07-07-2011, 05:00 PM   #1733
GJRider
GJRider's Avatar
Oddometer: 36
Bootz- Damn, you have all the goods wrapped up in one there! Sounds like a kick ass trip
Old 07-07-2011, 06:10 PM   #1734
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,591
Chilly White rides the 2010 500 XC-W.
http://www.motorcycle-usa.com/179/10...irst-Ride.aspx
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is online now   Reply With Quote
Old 07-08-2011, 03:05 PM   #1735
309
Special Purpose
309's Avatar
Oddometer: 5,466
Curious what you all are using for carrying tools on the 530? I have used various tool bags over the years, but didn't want to put one on the 530. After carrying everything in a flight vest for a while, I'm starting to consider a tool bag again...
Pics of your set up appreciated.
309 is offline   Reply With Quote
Old 07-08-2011, 03:15 PM   #1736
neduro OP
Addict
neduro's Avatar
Oddometer: 11,956
When running tubes, I run a spare tube in the airbox, across beneath the Battery.
Everything else, I carry in a camelback. My experience has been that stuff on the bike gets the crap beat out of it over time/ vibration.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 07-08-2011, 04:51 PM   #1737
FlyingDutchman
Dirt Biker
Oddometer: 841
I bought a second TwinAir Filter (pre-oiled) from Rocky Mountain ATV over the winter for multi-day rides. I finally put it on and noticed it was a little small-maybe a 1/4 inch around the rim. A bit of stretching and extra grease and it seemed to work OK.
I washed up both today and was able to compare it closely. They aren't stitched the same!
The stick-on lable on the bag does say KTM 530.
Anybody else notice this? I haven't spoken to R.M. ATV yet...
By the way, I found the pre-oiled filter twice as difficult to clean...like the dirt was glued in. Not sure if this is better?
Old 07-08-2011, 04:55 PM   #1738
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,591
Here is a good tool kit thread. Hilslamer has it all figured out IMO.
http://www.advrider.com/forums/showthread.php?t=262998
I run the same belt as Hilslamer, OGIO 450. Mine is the cool KTM orange one. I modded it with some extra strap parts. It wouldn't stay tight.
I also had a Moose fanny pack before the OGIO, I liked it very much as well. Maybe a little better than the OGIO. Not sure if the new Moose is the same though.
I recently added a Kriega R15 backpack. I run a bladder in it. It holds spare gloves, spare goggles, wallet, cell phone, and whatever else. It is not very big, but fits really well. It's a nice backpack.
Motion Pro has a lot of cool tools. I run quite a few of their things in my tool bag. I especially like their aluminum tire tools with built in axle wrench.
Old 07-08-2011, 05:57 PM   #1739
guns_equal_freedom
Oddometer: 5,528
I use a Wolfman Enduro Tool Kit for the tools.
Everything else I keep in the Camelback.
guns_equal_freedom is offline   Reply With Quote
Old 07-08-2011, 07:01 PM   #1740
Bora20
Oddometer: 854
Giant Loop Movaji. Enough room for spare tubes, fuel bottle, food, and all the tools you will ever need for a single or 2-3 day trip (if in hotel). Hasn't moved since I mounted it and is 2" away from the FMF Q4.
My camelback is all that is on my back now. It is heaven and sure makes me less tired.
Dan
Times are GMT -7.   It's 06:27 PM.
