09-19-2011, 07:49 AM
#2086 |
Oddometer: 644
09-19-2011, 09:28 AM
#2087 |
Wanderer
Oddometer: 2,442
What are you leaking? Oil? Coolant?
Is the engine side ok, or are you transferring oil? dc |
09-19-2011, 09:33 AM
#2088 |
Stop ruining my vacation
Oddometer: 4,803
Does anyone else see these marks on the inside of their fork protectors?
![]() ![]() I was riding with another 530 rider this weekend and it looks like we both have them. Not sure if the marks are rocks that get picked up in the side knobs or actual wheel deflection causing the contact...
Terry Mc 2010 KTM 530 Six Days terry.mc screwed with this post 09-19-2011 at 10:06 AM |
09-19-2011, 10:04 AM
#2089 | |
Oddometer: 644
Re: Tranny Oil loss - Engine side seems normal...as it ever is but if it is transferring, it seems to be evacuating through one of the typical 530 ways - 1) rings 2) venting 3) valve seals How common was the oil transfer issue...I thought they addressed that with the 09 models? I must admit that it was on it's side more than usual last weekend...maybe 10 times. |
09-19-2011, 01:39 PM
#2090 |
Oddometer: 188
" I must admit that it was on it's side more than usual last weekend...maybe 10 times."
That's one more than the required 9 times Dutch----indicating that you are riding fast enough. Anything less than 9 denotes that you weren't really trying. |
09-20-2011, 11:44 AM
#2091 |
Furbrain
Oddometer: 68
There is a weep hole on the bottom of (an inboard of) the water pump cover to indicate the coolant seal under the impeller is leaking. This leak is fairly common from what I can read. Also, a lot of people INSIST that seal is installed backwards by KTM and this is the cause of the leak. Quite a few people claim to have rectified their leak by reversing the seal. I changed the impeller out to the high flow model and did reverse the seal, based on the argument put forth on KTMTALK that it is backwards. The easiest way is to hit it with compressed air through the weep hole and it will slowly POP out (with the impeller off, of course). Good luck.
AMA - BRC - COHVCO 2011 530 EXC | 2010 990 ADV | 2006 FLHTXI (figure that out) If the only tool you have is a hammer, everything looks like a nail |
09-20-2011, 11:50 AM
#2092 |
First Time Chain Change, I'm Stuck!! Help Please!
Well I did it again went nuts with the wrench and now Im sitting in the garage scratching my head about what length the new chain should be. I had stock gearing on the bike, 15/45. I am now in the process of putting on 14/48 combo with new chain.
I laid out the new EK chain its a 520x120 O Ring chain and when I lay it next to the chain that I just took off the bike it is 3 or 4 links longer than the stock chain. Should I just break the chain at the length of the original chain or just put the chain on as is? |
09-20-2011, 12:07 PM
#2093 | |
Oddometer: 393
DB |
09-20-2011, 12:13 PM
#2094 |
Oddometer: 644
09-20-2011, 12:34 PM
#2095 | |
Oddometer: 644
GASKET WAPU-COVER 08 78035053000 I can't imagine how that could be put on in reverse?? Are you talking about this part? |
09-20-2011, 12:48 PM
#2096 | |
Hydrophobic
Oddometer: 2,401
I think he's talking about the water pump shaft seal. I know they had some issues in the RFS bikes with those being installed backward. I hadn't seen any reports of it on the XC4's.
2011 KTM 990 Adventure R 2010 KTM 530 EXC 2009 KTM 950 Super Enduro Erzberg Edition |
09-20-2011, 05:52 PM
#2097 | |
NorthWest Adventure Rider
Oddometer: 1,681
My 530 started leaking about 80hrs or so, replaced the outer seal and installed it "backwards" with the spring on the pressure side...haven't had any problems since. Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE |
09-20-2011, 07:56 PM
#2098 | |
Hydrophobic
Oddometer: 2,401
09-20-2011, 08:47 PM
#2099 | |
Wanderer
Oddometer: 2,442
)Dutch, I have heard of transferring issues on some 09s, particularly early 09s. Not sure if that is your issue but if the tranny is not leaking and dropping 300ccs but the engine is staying constant, it must be going somewhere. I would guess it's transferring and then blowing by the rings, like mine was. dc |
09-21-2011, 07:41 AM
#2100 | ||
Oddometer: 644
How is your re-build treating you? Any issues? How's the performance? |
