Old 11-11-2011, 02:32 PM   #2356
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,384
Here's what I've got going on right now. Bought an under bar stabilizer mount from PRD. Really nice made little part, Made in the USA, and thought the price was very reasonable considering both of those things. Would have been a straight bolt-in deal except that am running these PHDS perches, and then I wanted to make a few small changes/improvements.
The BRP SUB-mount for the KTM bikes is not made with the same 20mm wide slot that the factory billet KTM triple clamps have, so none of the handlebar perches with 20mm wide slots will not work - at least not without either, 1) modifying the SUB-mount (like Javahead & LukasM), or 2) machining/filing off the slot-tabs on the perches. Have talked to BRP about this issue, so they're aware of it, but dunno if they're going to change the way they make those parts. The PRD underbar stabilizer mount is machined with 20mm wide slots, so I didn't have to modify it to work with the slotted perches that I'm running.
My brother has been through a couple of the BRP SUB-mounts on his EXC, and don't think it's got anything to do with the quality of BRP's parts, it's just a matter of leverage. Not sure why KTM is using smaller hardware than all the other manufacturers, but they just don't seem to hold up very well when used with handlebar risers of any substantial height (+.5-.75" maybe?). After smearing the first BRP SUB-mount, we drilled-out the threaded bolt-holes. 2nd SUB-mount smeared too, but that was during a particularly hard (race-ending) crash during the V2R race. Still think drilling out the threaded perches to secure the underbar stabilizer mount with four bolts is step in the right direction, so that was the first thing I did with this PRD mount.
Then I mocked-up the stabilizer mount and all the rest of the parts to take a look at the overall stack-height. Found that the setup was about an 1/8" taller than it needed to be, so machined that amount off the underside of the PRD stabilizer mount. Know that a lot of people like the additional height, so it's not good or bad, but I like the lower bars position better on this bike.
...and this is what we were talking about: machining pockets into the PHDS perches so they would work with the underbar-mounted steering stabilizer. Think I read something about Neduro having to modify his perches in a similar fashion.
Had to turn-down the heads on a couple of 12.9 allen-bolts in order to work with the new/modified parts.
And this is how it turned-out. Haven't had a chance to ride it off-road yet, but have been bombing it around on the street a bit, and haven't found the vibes to be a problem at all. Not idea if I can attribute that to these perches though, because I just picked this bike up, and never rode it with the hard-mounted perches. What have you guys noticed? Noticeable difference? Talked to Charlie at rallypanam about them and he said they worked great for him. Mine were used, so I poked around online and found out that a company called XTRIG makes them for KTM (along with most of the billet aluminum machined parts that come on KTM's). Evidently XTRIG makes and sells their own version of these clamps, and when I called to ask about purchasing some replacement parts (elastomer bumpers), we got to talking about the perches and I was told the they have made several improvements to the newer XTRIG versions. Wondering what those are. Anybody tried them? They're going to set me a set to do a review/comparison. Will post-up as soon as I get them. Only thing I know so far is that they use a wider slot, so they won't key into the billet tripleclamps, but might work with the cast/forged tripleclamps?
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 11-11-2011, 04:55 PM   #2357
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,949
I did the same thing, and I think anyone with this type of riser, of which there are a few manufacturers, ought to consider drilling the threads out and mounting it with a through bolt to the triple. I mentioned it to PRD, but he hadn't really heard of any problems. It's a shame they aren't drilled already, since the hole alignment is perfect to the triple to allow 4 bolt mounting.
This was mine after a relatively minor high side on ice. After this, I replaced the bent bolts, drilled the threads and it hasn't moved yet, and it has had at one giant wreck, and many small offs.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 11-13-2011, 06:05 AM   #2358
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
I would argue there is no such thing!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 11-13-2011, 09:05 AM   #2359
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,596
[QUOTE=FlyingDutchman;17273519]
Originally Posted by neduro View Post
FWIW......
QUOTE]
White plastic looks great, eh!?
I think Ned has built a pretty sweet ride there. Seems like he kept it simple and straight forward.
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is offline   Reply With Quote
Old 11-13-2011, 12:23 PM   #2360
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,949
Yes, you're right on that. Check out the 1:47 mark on. It wasn't super fast, but high sides feel like the same thing a football feels when the athlete throws it to the ground after achieving a goal in that particular 'cup based reward' sporting event.
Old 11-13-2011, 07:03 PM   #2361
xcflyn
xcflyn's Avatar
Oddometer: 1,145
lost rear brake on my 2011 ?
Fluid is full- adjuster is fine and operating plunger. I have not had time to research this too much yet and thought I would ask incase there is a common problem (and hopefully quick fix). I did take a minute to crack the bleeder and did get it to spit very slightly, but not really anything coming out. I suspect the master is bad ?
xcflyn is offline   Reply With Quote
Old 11-14-2011, 08:43 AM   #2362
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 843
Happened to me once...I was told that it can suck some air in. I drained it and refilled and it was fine.
FYI: Dealers sell a rebuild kit too...
FlyingDutchman is offline   Reply With Quote
Old 11-14-2011, 11:38 AM   #2363
Krazyjohnny
Oddometer: 445
Steering Stabilizers
I am looking at acquiring one of these devices. Which ones are most effective? Easiest to install? least troublesome? I have seen some folks like the GPR over the Scotts or Ohlins. I am sure this can get into the which oil thing real quick. I am looking for something that does not require a whole lot of modification to install. I am not a machinist and prefer the "bolt ons".
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 11-14-2011, 12:01 PM   #2364
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
IMO, the Scotts is the best option for a number of compelling reasons. The GPR has a very simple damping circuit that is either ineffective or intrusive. The Scotts, with a separate high and low speed adjustment, does its job much better. It's bolt on unless you have weird ergonomic requirements.
www.brpmoto.com has all the stuff...
Old 11-14-2011, 12:01 PM   #2365
jesusgatos
jesusgatos's Avatar
Oddometer: 2,384
GPR is an inferior product and their customer service is TERRIBLE.
Old 11-14-2011, 01:01 PM   #2366
DirtJack
DirtJack's Avatar
Oddometer: 1,531
Not only does the Scotts outperform other brands as Ned and others note, but it is easy to move between bikes once the mounts are set up. I use UTB mounts for one damper shared between my three bikes.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-14-2011, 04:27 PM   #2367
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,902
I have both, and much prefer Scotts.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 11-14-2011, 05:49 PM   #2368
Country Doc
Wanderer
Oddometer: 2,732
+2. Happened to Flanny's bike, and mine. Bled it, and all has been good since. I think these bikes can boil the rear brake fluid fairly easily and need bleeding after a hard/fast ride or race.
dc
Country Doc is online now   Reply With Quote
Old 11-14-2011, 07:42 PM   #2369
Fulano
Scooter Trash
Fulano's Avatar
Oddometer: 424
I've owned both Scotts and GPR. Both are well made, competatively priced and offer helpfull service. Scott's has more adjustment but GPR will rebuild / service them for free if you are the original purchaser. I set mine and forget it. Usually after about 2 years I can tell the damping tolerances are slacking. Scott's charges $50 to $90 for servicing and recomends not going over 5 years.
Been to Spain, Maine and Spokane. Jumped rope, smoked dope, farted, fucked and fought round the world, twice. Hell, I've even seen goats fuck in the market place, but I've never seen shit like this!
All I need are loose shoes, tight pussy and a warm place to shit.
Fulano is offline   Reply With Quote
Old 11-14-2011, 08:28 PM   #2370
guns_equal_freedom
Oddometer: 5,536
I have the Scotts underbar mount on my 300 and 530.
I have crashed on both of them multiple times and have never had an issue with anything bending or breaking.
guns_equal_freedom is offline   Reply With Quote
Times are GMT -7.   It's 07:08 AM.
