Old 12-07-2011, 09:10 AM   #2416
jconyer
jconyer's Avatar
Oddometer: 31
Thanks Michhub, good to hear!
'13 KTM 690 Enduro
'13 KTM 250 XC
jconyer is offline   Reply With Quote
Old 12-07-2011, 01:25 PM   #2417
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 831
I broke the shroud mount tab on my right radiatior! I run the Clockwork tank with the stock shrouds.
Rather than buying a new rad or getting a weld job done, I am contemplating EE Rad Braces that have a new tab built in.
Except, I am also thinking about a 6 gal Acerbis or Hard Parts tank.
Will these work together?
FlyingDutchman is offline   Reply With Quote
Old 12-07-2011, 01:29 PM   #2418
FlyingDutchman
Dirt Biker
Oddometer: 831
Oil Burner
I'm at 180hrs. My bike burns oil.
So, I ordered new rings, Cylinder Base & Head gaskets, and valve seals to attempt to stop the oil burning problem on my bike.
Anybody done a ring job on theirs? Any tips before I dive in?
Stock piston should be good for another 200 hrs, eh?
Old 12-07-2011, 02:40 PM   #2419
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,935
Start with posts 637, 662 and 663. Good pics and description.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 12-07-2011, 04:00 PM   #2420
FlyingDutchman
Dirt Biker
Oddometer: 831
Excellent work B-Rod.
One more question: Would the piston benefit from removing and cleaning?
Old 12-07-2011, 04:17 PM   #2421
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,935
I would (make sure you order piston pin cir clips). Clean up the piston, once you get in there and see how gross it is, you will want to. You will also be installing new rings, and there is no way you are going to get rings over the crown of a carboned up installed piston without getting crap in the grooves or the case, and even if cleanliness wasn't a factor, you will find it much easier to install and less likely to break rings with the piston in your hands.
Old 12-07-2011, 06:52 PM   #2422
Weldit
Weldit's Avatar
Oddometer: 336
KTM High Seat, Model # 773 07 040 100.
anyone have any comments on this seat - the ktm stuff just says it's 20 mm taller or 3/4"
no mention on hardness - same as stock ?
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 12-07-2011, 07:25 PM   #2423
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,836
If I were to guess its a 2x4 with a high price
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub screwed with this post 12-07-2011 at 07:29 PM Reason: pic & link
Michhub is offline   Reply With Quote
Old 12-07-2011, 07:40 PM   #2424
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,935
I have one kicking around. I found a KTM low seat for a friend to replace the tall seat. He never once complained about it, so I guess it was fine. Oddly enough, he likes the low seat, which is brutally hard to compensate for the 1/2" of foam ( not sure you could even call it foam) between the cover and the pan. No standard seat to compare it to other than my '07 and the low one, and it is waaaaaayyyy softer than the low seat, but probably about the same as my stock '07 EXC seat.
Soft is necessarily the answer anyhow, since my old 640 had a very soft seat, and it was a torturous thing. I bought a Renazco, and while very firm, was very comfortable due to its shape. Again, the low seat, while extra hard, is much wider and flatter than the high seat.
I'll leave the sales pitch out, and let others comment, but should you be interested in working something out, drop me a PM.
B-Rod screwed with this post 12-07-2011 at 07:49 PM
Old 12-07-2011, 07:42 PM   #2425
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
My brother put a Wossner high-compression piston in my 450 for me and it rips! Still runs great on pump gas too. Just something to consider if you're doing a top-end anyway...
jesusgatos is offline   Reply With Quote
Old 12-07-2011, 09:17 PM   #2426
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Yes. They will work with the Aerbis 6 gal. I have one in Natural that I'm selling. pm me if you want it.
Sent from my iPad using Tapatalk
Flanny is offline   Reply With Quote
Old 12-07-2011, 10:16 PM   #2427
guns_equal_freedom
Oddometer: 5,514
Originally Posted by Clrblu22 View Post
Which pipe guard is that? the P3? Just curious, I've been looking for one but can't decide which one I want.
It's the KTM Power Parts guard, the one that's shown on the web site is the Eline, mine didn't have a manufacturers name on it.
Probably the same part.
http://www.ktmcyclehutt.com/ktm-part...t=bigbikes-all
guns_equal_freedom is offline   Reply With Quote
Old 12-08-2011, 09:43 AM   #2428
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,349
Whats the trick to unscrewing the front right valve cover bolt. The tank tab gets in the way of a socket and the recess in the cover makes it hard to use a box end wrench?
Old 12-08-2011, 10:12 AM   #2429
retired motoman
LifeIsShort,EnjoyTheRide!
retired motoman's Avatar
Oddometer: 495
Replace the valve guide seals.
I have over 400 hours on my stock piston. (Will replace with Wossner as recommended from DJH next top end rebuild.) I also change my valve guide seals for good measure.
Pay close attention to the cam chain adjuster.
The bike is easy to service and straight forward.
retired motoman is online now   Reply With Quote
Old 12-08-2011, 10:14 AM   #2430
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,147
So what are you trying to say here Dan, it was just delivered and you're already pulling it apart?
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Times are GMT -7.   It's 09:23 PM.
