02-06-2012, 12:44 PM
#2686 |
Dodgin' the Ditches
Oddometer: 1,158
I'm looking at an 08' 530. I'm glad I found this thread.
![]() I'm going to look at it on Wednesday. Don't know if I'll have time to read through the entire thread before then. ![]() Any advice about thinngs to check for? I know about the rings, and the oil leaking from the engine into the tranny. Owner said it got new rings recently. Hopefully, I will be "the new guy" on this thread in a few days. |
02-06-2012, 01:37 PM
#2687 | |
Oddometer: 164
Replaced my fan switch with a 95/90C Altrom Imports one for a BMW car. The part number is ATM 1435033, available at NAPA. The fan comes on now when the temp gauge reads 203F for the water coming off the head. The fan runs more of course, but the bike stays much cooler in the technical stuff and on hot days as a result. My bike is a 2010 'Berg 450, the stock stator puts out 211 watts, which is plenty. The new FI KTM models are like this as well. Not sure if running the fan more would be an issue for the 530's charging system though.
2010 Husaberg FE450 (plated) 2006 Yamaha FZ1 |
02-06-2012, 10:05 PM
#2688 |
Oddometer: 644
Handlebar Wear??
Eh guys,
I've been doing a bit of winter maintenance. I've got an 09 with 180hrs, maybe 10 xc/enduro/trailride events. I'm 270 and probably bottom my forks every ride. While pracrastinating from checking the rings and valves, I decided to rip my grips off and clean my throttle assembly. I found the throttle tube had worn a groove around the bar about 1/32" (1mm) depth. Are my bars worn out? |
02-06-2012, 10:57 PM
#2689 |
fishing with dynamite
Oddometer: 2,030
Would say it all depends on where that groove is.
02-07-2012, 06:14 AM
#2690 |
Oddometer: 644
02-07-2012, 09:05 AM
#2691 |
Oddometer: 2,030
That's far enough in that there's going to be a fair bit of leverage on the bars at that point. Time for a new pair of bars.
02-07-2012, 07:10 PM
#2692 |
Oddometer: 188
Regarding that protrusion that prevents the rocker arm bolt removal.
On the '08 530 the rocker arm bolt on the left side won't come out. Someone was asking about that recently. There have been several solutions proposed---all of them will work. I thought I'd share the way I handled it---maybe not the best way but maybe the quickest and it IS effective. I simply used a dremel tool with a very small, very thin, diamond blade and I cut off only exactly enough of that protrusion to allow the bolt to come out. There is still thread left inside the protrusion --and I simply used the cut off piece as a spacer when I put it back together. Yes. that protrusion will be shorter than it was before---shorter by the width of the blade that cut it----but I found that the tank still is held very securely by the rubber buffers---and the missing length isn't a problem. I'm not advocating this method for anyone else----just noting that it works for me
PS----very very thin cutting blade----with diamond dust cutting surface ----think I got it as part of a harbor freight tool set for the dremel.
02-07-2012, 07:24 PM
#2693 | |
NorthWest Adventure Rider
Oddometer: 1,685
![]() Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE |
02-08-2012, 04:55 AM
#2694 | |
RubberNecker
Oddometer: 1,698
Now I need to have a look at mine.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI |
02-08-2012, 06:24 AM
#2695 |
Oddometer: 644
Anybody have Renthal Twinwall bars installed?
http://www.renthal.com/File/sproduct...&bikedate=&z=1 They make a claim to have a harder surface at the controls; "Inner tube is ultra high strength 7010 T6 Aluminium and is hard anodised to resist wear from twist grip and controls" but I read somewhere that they don't accept all handguard mounts. |
02-08-2012, 06:38 AM
#2696 |
Oddometer: 344
Going nuts! And it is all my fault.
I am literally going crazy having to walk be both the KTM and the Yamaha everyday as I go to work and come home from work and knowing I cannot get on either of them.
Yep! There they sleep, on the tenders just waiting. The Aerostitch is hung in the closet, the helmets in their bags, and my dumbass hobbling by in this stinkin' brace. GRRRRRRR! It sucks getting hurt. All I need is about 60 degrees of flexion in my knee brace and I can ride one of them. Only a few more days.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
02-08-2012, 07:42 AM
#2697 | |
RubberNecker
Oddometer: 1,698
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI B-Rod screwed with this post 02-08-2012 at 07:47 AM |
02-08-2012, 08:52 AM
#2698 | |
Oddometer: 644
02-08-2012, 09:49 AM
#2699 |
RubberNecker
Oddometer: 1,698
Oh, wasn't sure. Another option that does fit hand guards easily is conventional bars, and maybe a ProTaper throttle tube, which uses a bearing to reduce friction on the bars.
02-08-2012, 10:49 AM
#2700 | |
Oddometer: 2,030
Nobody has the aluminum design/manufacturing capabilities that Easton does, and the engineering and test data that I've seen shows that their bars are measurably better than anything else out there. Chuck Teixeira at Easton designed the original 1 1/8" bars for Pro Taper, and Easton manufactured them for a number of years. By most accounts, quality/performance went down when that relationship ended. So I would highly recommend Easton's EXP bars. Pretty sure the 1 3/8" bars have been discontinued, as they're on blowout at motosport and other places for something like $70 (including new handlebar perches). Problem with the 1 3/8" bars is that they really never launched the accessories that I designed for them, so mounting a steering stabilizer and handguards might be a hassle (that's why I'm running their 1 1/8" bars on my KTM).
...unless you drill before tapping? Shouldn't be a problem as long as you only drill as deep as you need to tap, right? Quote:
