02-29-2012, 10:37 AM
#2791 | |||
Reforming Neandertal
Oddometer: 867
02-29-2012, 10:42 AM
#2792 |
Baja Designs
Oddometer: 374
Awesome, sounds good!
02-29-2012, 05:29 PM
#2793 |
XR650L_High_Runner
Oddometer: 353
Alright so this is my rear fender on my 08 XCRW 450. As said I'm new with KTM and is it true this is the same fender as the EXCR model? Will the broken tab or whatever on the left of this picture be a problem with mounting the stock rear brakelight for a EXCR?
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles) 2006 CRF250r (traded) XR80r 2008 XCRW450 (260 hrs) |
02-29-2012, 06:26 PM
#2794 |
lookin' for adventure
Oddometer: 950
Mine broke off also... Though I did manage to keep it. I ended up drilling through the tab out the top of the fender and running a 1-1/2" machine bolt up through it (slotted head on top with a washer). Been on there for nearly 3 years. Try using a piece of pipe/tubing to make up the spacer for the tab.
"Rember... Wherever you go... there you are" Buckaroo Banzai |
02-29-2012, 07:06 PM
#2795 |
Dirt Whore
Oddometer: 189
Kickstand 2010 530exc
What is the most robust do-it-all-and-be-done-with-it solution for these crappy kickstands?
Small footprint, my spring a dongle dealie thing poinged off somewhere...floppy stand now.. Fix or bail to a new unit? |
02-29-2012, 07:09 PM
#2796 | |
fishing with dynamite
Oddometer: 2,037
03-02-2012, 09:30 PM
#2797 |
NorthWest Adventure Rider
Oddometer: 1,683
NV 2012 - In Memory of the Crewmen RR: CLICK HERE Adventure Is Out There - NV RR: CLICK HERE Riding Through History - NV RR: CLICK HERE And Then There Were Four - OR RR: CLICK HERE My VW Syncro Westy Build Thread: CLICK HERE |
03-02-2012, 09:32 PM
#2798 |
Oddometer: 1,683
Water Pump Seal Replacement
Just replaced the water pump seal on my new 530, it started weeping at 51 hrs. Took pictures this time and did up a How-To for people unfamiliar with changing the seal out. It's a little lengthy so I posted it in it's own thread and will link it here so it doesn't take up so much space.
Here's the link: CLICK HERE Hodakaguy
03-02-2012, 10:10 PM
#2799 |
Oddometer: 226
Wings Exhaust installed
I splurged and bought a Wings Exhaust. Installed tonight.
![]() Sounds good, looks good, and doesn't get hot after running for 5 minutes.
03-03-2012, 02:38 AM
#2800 |
Well travelled
Thank You Everyone
I would just like to say a BIG Thank You to all the contributors and pioneers of this thread.......... You know who you are and two in particular Neduro & HG ..... for making it easy for me to build this, My WEAPON OF GAS CONSUMPTION is a 2011 model KTM 530 Exc Factory edition...... jD Jetting (starts with ease)/fan kit/ Thermostat bypass/Samco hoses/wetter water/ Scott's/ Akra/Sump guard/13 l tank/ Moose SS filter/brake snake/ Horn relocation, Only one thing left to do is the water pump enlargement (Now on order) Oh and perhaps some BLING (I think a crack or meth amphetamine habit would be cheaper sometimes) The 530 is an awesome piece of equipment my decision to buy was also due to this thread.
28hrs = 6 oil changes (engine and gearbox) = 1 valve check (in spec) = 1 rear tyre (Pirelli MT 21) [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Orange Ones are more Juicy KTM was founded in 1934 by Hans Trunkenpolz and was initially known as Kraftfahrzeuge Trunkenpolz. later, in 1953, an Austrian businessman named Ernst Kronreif bought a large share of the company which was the renamed to Kronreif & Trunkenpolz Mattighofen (KTM). scottmctag screwed with this post 03-03-2012 at 02:47 AM |
03-03-2012, 05:08 AM
#2801 |
Oddometer: 348
Oil capacity/Life
Great looking bike!
Ned or any others what did you do for oil capacity and life for your Dakar Ride? Just curious as I will probably never ride as hard as you do so if your bike lasted then I should never have an issue with mine. I have seen both good and bad results with auxillary oil coolers.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
03-03-2012, 06:46 AM
#2802 |
Allergic to Asphalt!
Oddometer: 6,000
You'll be getting rid of the Acerbis Roadbook holder very fast, it's a piece of sh$#t. Mine lasted about one ride.
Very hard to advance the roadbook w/ that thing. Sweet looking bike!
03-03-2012, 07:13 AM
#2803 | |
Oddometer: 1,683
For me it's a balance of risk/benefit. I use the 530 to get me to very remote locations out in the middle of know where and reliability is king. To me the cooler ads a extra level of complexity and something else that can be damaged in a crash. I prefer to carry the qt of oil and change it mid trip so I don't have to worry about any cooler issues. I really like the design of the HT for the RFS bikes since it's one piece and replaces the stator cover. On our bikes the HT unit sits over top of the stock stator cover and is only held in place by two 6mm bolts....I have a fear that in a hard crash the cooler could be damaged and worse damage the engine cases where it bolts into. Then you still have the oil lines that are susceptible to damage. I've read good review from people using the HT cooler but for my type of riding the risk looks to great. Hodakaguy
03-03-2012, 07:17 AM
#2804 |
Oddometer: 1,683
