Old 03-03-2012, 08:55 AM   #2806
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 208
His unit: http://www.ebay.com/itm/200697280488...fvi%3D1&_rdc=1
KTM Explorer is offline   Reply With Quote
Old 03-03-2012, 09:17 AM   #2807
zenjen
Go Outside
zenjen's Avatar
Oddometer: 2,662
Originally Posted by Hodakaguy View Post
I've read good review from people using the HT cooler but for my type of riding the risk looks to great.
Hodakaguy
I believe this is the unit Ned used.
http://www.cpwmotoparts.com.au/16-kt...ooler-kit.html
zenjen is offline   Reply With Quote
Old 03-03-2012, 11:43 AM   #2808
D1EHARD
Got the Fever
D1EHARD's Avatar
Oddometer: 88
Quick question...I'm doing the JD Jetting kit on my 2011 450 exc...I got to the diaphragm spacer step and dropped the diaphragm from the carb. I have the spacer installed but am unsure on which way to put the diaphragm back in.
This way:
Or this way:
Thanks for the help.
D1EHARD is offline   Reply With Quote
Old 03-03-2012, 12:19 PM   #2809
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
This way:
This looks like the correct orientation. The lip sticking up on the edge of the diaphragm should fit into the recess on the carb, and the "label" imprinted on the diaphragm (opposite side as shown above) should be visible once it's installed in the carb body.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 03-03-2012, 12:29 PM   #2810
xcflyn
xcflyn's Avatar
Oddometer: 1,152
Great looking setup
Hodakaguy
I agree. Supa-Sweeeeeet !!!
xcflyn is offline   Reply With Quote
Old 03-03-2012, 12:54 PM   #2811
D1EHARD
Got the Fever
D1EHARD's Avatar
Oddometer: 88
Hodakaguy
Thanks bud.
Old 03-03-2012, 02:40 PM   #2812
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 869
Originally Posted by scottmctag View Post
I would just like to say a BIG Thank You to all the contributors and pioneers of this thread.......... You know who you are and two in particular Neduro & HG ..... for making it easy for me to build this, My WEAPON OF GAS CONSUMPTION is a 2011 model KTM 530 Exc Factory edition...... jD Jetting (starts with ease)/fan kit/ Thermostat bypass/Samco hoses/wetter water/ Scott's/ Akra/Sump guard/13 l tank/ Moose SS filter/brake snake/ Horn relocation, Only one thing left to do is the water pump enlargement (Now on order) Oh and perhaps some BLING (I think a crack or meth amphetamine habit would be cheaper sometimes) The 530 is an awesome piece of equipment my decision to buy was also due to this thread.
28hrs = 6 oil changes (engine and gearbox)
= 1 valve check (in spec)
= 1 rear tyre (Pirelli MT 21):c lap:c lap:c lap:c lap
That sure is a purdy one there scotty...what about the kickstand and chainguide? Those are some nice rear blinkers. At 28 hours, you sem to have about 2000 worth of bling... when you part it out at 50hrs or so, I might be interested in the some of that bling if my stock stuff is worn out...
or are you gonna ride it?
FlyingDutchman is offline   Reply With Quote
Old 03-03-2012, 04:17 PM   #2813
D1EHARD
Got the Fever
D1EHARD's Avatar
Oddometer: 88
Originally Posted by KTM Explorer View Post
Got the 530 back from Konflict Motorsports: Lowered a bit, entire bike gone through and optimzed for me at 205 lbs which included spring to replace both F&R units the previous huge rider had on it. It fits sooo well now.
Paul provided his propritary LED rear taillight and turn setup - WOW talk about a high quality unit and fantastic workmanship - and amazingly fast shipment...just THE BEST. Now I've gotten rid of the OEM crap unit and about to get rid of the honkin' rear turns which are broken now anyway
Will the OEM rear blinkers fit this taillight setup? The flush-mounts look so small to me.
Old 03-03-2012, 05:33 PM   #2814
neduro OP
Addict
neduro's Avatar
Oddometer: 12,021
Correct.
I think it's a fine piece of gear.
For me, it is much superior to the HT racing one in that it picks up and returns in the oil filter cavity... but I'm not in love.
1) Oil changes are messy, both draining and filling are impossible to do clean.
2) It's very easy to warp the oil filter cover (the stock oil filter cover relocates to the rear edge) when replacing the filter, causing a seep.
3) I'm not convinced that part of my vapor locking issue in the race didn't come from the way the fuel line has no choice but to run above the oil cooler, next to the cylinder.
In any event, more oil = better, and it was very hot at times in the race, indicating that it was getting heat out of the motor that could otherwise have been detrimental.
I wouldn't bother with one for normal use. I don't consider the Dakar normal use.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 03-03-2012, 06:02 PM   #2815
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,403
Nice looking bike. What kind of handguards are those?
jesusgatos is offline   Reply With Quote
Old 03-03-2012, 10:09 PM   #2816
Bungholio
Bungholio's Avatar
Oddometer: 756
[IMG][/IMG]
Looks really sharp.
Looks like something is amiss with the RR turn signal. Kind of close to the exhaust outlet and may melt. I know mine did.
Bungholio is offline   Reply With Quote
Old 03-03-2012, 10:36 PM   #2817
Bungholio
Bungholio's Avatar
Oddometer: 756
Thumbs down
WOW! Cha-ching! Gotta be a better solution than this and the HT model.
Old 03-04-2012, 06:16 AM   #2818
neduro OP
Addict
neduro's Avatar
Oddometer: 12,021
I think someone should start making oil pickups that drop into the filter cavity (like the CPW unit uses) and them run them to either the Fluidyne radiators with an integrated oil cooler, or to a Setrab or similar separate oil cooler.
But I couldn't find anything like that in existence, so the CPW is what I used.
Old 03-05-2012, 05:25 AM   #2819
Krazyjohnny
Oddometer: 449
I will spend some time tonight looking at where I could add another radiator to the 530. My thinking is that since these bikes cost so much I better make it last as best I can. So for now I will be doing the HG method.
I may have to get into the case anyway because I am noticing that when in nuetral and pushing the "easy button" the bike wants to lurch. So my guess is that the clutch thingy that is mentioned way earlier in this thread is dragging and needs an adjustment. Time for some research into the archives. I know HG did an incredible write up on this and I have it somewhere to review.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 03-05-2012, 09:17 AM   #2820
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,095
Honsetly I wouldn't worry to much about the oil capacity, you'll get just as many hrs out of the bike if you change it often and run a quality oil.
If your torque limiter is slipping it would cause the engine to turn over slower than normal and cause hard starting issues, it can also make it hard to start in gear with the e-starter.
My guess on your issue is your just experiencing cold oil dragging on the clutch basket, is it better once the bike is warmed up?
Hodakaguy
Times are GMT -7.   It's 02:57 PM.
