Old 03-05-2012, 09:26 AM   #2821
Bungholio
Bungholio's Avatar
Oddometer: 707
Originally Posted by neduro View Post
I think someone should start making oil pickups that drop into the filter cavity (like the CPW unit uses) and them run them to either the Fluidyne radiators with an integrated oil cooler, or to a Setrab or similar separate oil cooler.
But I couldn't find anything like that in existence, so the CPW is what I used.
That is the biggest problem; where to get the oil from and where to return it to the sump. I was thinking of 1/4-1/2 of the left radiator area used as an oil cooler and the remanning radiators with a thicker core. Or a Setrab behind the current left rad.
I had a DR350 back in the day with a nice oil cooler and my current DR650 has one. I remember Honda had one on their XR's around the steering head but it was pretty small.
Bungholio is offline   Reply With Quote
Old 03-05-2012, 10:12 AM   #2822
Krazyjohnny
Oddometer: 448
@HG,
Yes, it is much better when warm. Only takes a slight bump of the starter.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 03-05-2012, 11:13 AM   #2823
Double Moo
lookin' for adventure
Double Moo's Avatar
Oddometer: 1,175
My 530 tends to run hot... or so I think. The guys I ride with hardly ever seem to have their fans come on - mine is on just about every time we stop. Saturday we were riding in 38-40 degree weather and it was still coming on often. Runs awesome, just wondering if I should be concerned.
I have the following setup:
'08 530 - desmogged, JD Jetting kit installed, KTM fuel mixture screw - 1-1/2 out, hardparts fan set up, standard juice w/ water wetter, elevation 4,500' - 10,000' (come on often when riding desert at 1,500' also), occasional pop on decel - not bad, hardparts 13L tank (would this restrict airflow?)
I don't know that it is a real problem other than drain on the Battery. Any clues... or leave it alone?
"Rember... Wherever you go... there you are"
Buckaroo Banzai
Double Moo is offline   Reply With Quote
Old 03-05-2012, 11:21 AM   #2824
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,087
Check to see what deg thermo switch is installed on your setup. There are two different thermo switches that KTM supplied (can't remember right off hand what temp the two switches are), if you have the lower temp switch installed the fan will cycle a lot more often and run a lot longer than the higher deg switch. I run the hotter switch to keep the fan from cycling as much.
It's possible you have the lower temp switch installed and your friends are running the higher temp switch.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 03-05-2012, 11:22 AM   #2825
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,087
Originally Posted by Krazyjohnny View Post
@HG,
Sounds pretty normal. What weight oil are you running?
Hodakaguy
Old 03-05-2012, 11:23 AM   #2826
LukeDuke25
Oddometer: 33
The JD Jetting Jet Kit usually solved the heat issues from being too lean on the larger KTM's. It is a must-have if you are riding in the desert!
Luke
09 Husky WR250
LukeDuke25 is offline   Reply With Quote
Old 03-05-2012, 11:26 AM   #2827
Double Moo
Double Moo's Avatar
Oddometer: 1,175
Hodakaguy
Good idea... didn't know they had differing switches. How do I know which I have?
Just looked -side of the brass switch says 160.08 on one face and 85*80* on the other. 85C = 185F, 80C = 176F, (is this on at 85C and off at 80C?). Or 160.08 equates to 71C... or more likely a part number? What am I really looking for??
Buckaroo Banzai
Double Moo screwed with this post 03-05-2012 at 11:39 AM
Old 03-05-2012, 11:35 AM   #2828
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,087
It will be stamped on the side of the thermo switch in Deg C.
Hodakaguy.
Old 03-05-2012, 11:41 AM   #2829
Double Moo
Double Moo's Avatar
Oddometer: 1,175
found it and edited above - 85*80*. Is this the higher or lower temp?
looks like the low...
http://www.ktmcyclehutt.com/ktm-part...ber=7803504500
http://www.napaonline.com/Catalog/Ca...033_0257596936
Buckaroo Banzai
Double Moo screwed with this post 03-05-2012 at 12:07 PM
Old 03-05-2012, 01:44 PM   #2830
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,087
Yep sounds like you have the low thermo switch, replace it with the 95-100 switch and I bet the fan runs like your friends bikes. Napa has an equivalent switch that's a lot less $$, someone has posted the Napa part number in the past...I can't remember what it was though...I'd do a search but I'm posting from my phone :-).
Hodakaguy
Old 03-05-2012, 01:53 PM   #2831
Double Moo
Double Moo's Avatar
Oddometer: 1,175
Hodakaguy
It's in the above post... 1984 BMW 318i fan control switch.
Buckaroo Banzai
Old 03-05-2012, 01:56 PM   #2832
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,087
Great, I clicked on the link from my phone but it just took me to the NAPA home page with nothing showing, could just be the phone.
Hodakaguy
Old 03-05-2012, 05:51 PM   #2833
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
This iswould be the best solution if someone made an oil filter cover to connect to the radiator.
Old 03-05-2012, 06:33 PM   #2834
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,391
I can design whatever kind of adapter you guys want, just don't know enough about the oiling system in these engines to decide where the best place to tap in to pick-up and return oil might be. But if there's really a need for some kind of external oil filter adapter, let me know and am sure we can come up with something...
jesusgatos is offline   Reply With Quote
Old 03-05-2012, 10:36 PM   #2835
Bungholio
Bungholio's Avatar
Oddometer: 707
I connected my fan to a HDB waterproof on/off button mounted on the top bar clamp, SXDX. I'll just turn it on when needed. The thermo switch was hosed out of the gate.
Times are GMT -7.   It's 07:15 AM.
