Old 03-18-2012, 02:13 PM   #2896
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 891
In the last few weeks I've been a bit indecisive.
After 10,000+ miles of Enduros/HS's/DS rides/Commuting/SM trackdays, etc., I sold my WR250R
and bought a plated 250xcw. Great bike for enduros and HS's. But wasn't feeling the 2 stroke thing. So, I traded it for....
....this 530exc. I think I've found the bike for me! This thing is badass.
Anyway, I've got a bit of work to do as far as the wiring goes. All the lights have been disconnected, signals/wiring removed, ignition switch taped up with key in it and relocated, etc. But mechanically it's rock solid and runs great! Look forward to reading more of this thread and gaining more knowledge from you guys.
onetravdown is offline   Reply With Quote
Old 03-19-2012, 12:22 AM   #2897
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,390
Originally Posted by Yellow Pig View Post
What's going on with your front brake line?
jesusgatos is offline   Reply With Quote
Old 03-19-2012, 05:22 AM   #2898
guns_equal_freedom
Oddometer: 5,550
Aftermarket front fairing does not have the clip on it to route the front brake line, brake light and speed sensor wiring over it so he has to run it behind the fairing.
It looks like he wrapped it in black plastic spiral wire protector that you can buy at Home Depot or any automotive parts store.
I like the light idea, I hate that style of aftermarket fairing.
Why not make the light kit that fits into the stock fairing.
guns_equal_freedom is offline   Reply With Quote
Old 03-19-2012, 05:29 AM   #2899
haknslash
haknslash's Avatar
Oddometer: 333
That's my main issues with it, aside from the fact that in using the supplied mounting straps it is real close to the CDI box and some have commented that it doesn't allow for full lock to lock steering on the 530. But yea the fairing looks like standard wide ho-hum aftermarket with the squadron light bolted to it. It would look much better IMO if retrofitted into the stock housing or fairing. That being said I don't do enough night riding to justify the cost one way or the other but I am glad to see LED lighting options expand.
2012 Kawasaki Ninja 1000 ABS
2011 KTM 530 log report http://advrider.com/forums/showthread.php?t=717763
haknslash is offline   Reply With Quote
Old 03-19-2012, 07:51 AM   #2900
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
Thanks for the post, YP. That's the most promising light I've seen for what I'm looking for- I love the simplicity/ durability of LED, and like the form factor of that light.
Minor diversion:
I've had my first day on the new 500, and it's promising. The chassis is similar, the suspension seems slightly better, the motor is more polished but also less tractable than the XC4- a bit prone to flameout and definitely easier to light up.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 03-19-2012, 10:50 AM   #2901
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
I've got a Baja Designs 8" racelight on my bike that uses the same type of fork mounts and just ran the brakeline to the outside?
Old 03-19-2012, 12:47 PM   #2902
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
Rally routing so it does not interfere w/ the spedo and GPS or eventually the road book. It flexes between the caliper and the lower triple clamp.
In order to fit the tube bag closer and tighter to the forks I set the light up in a taller position than stock. Consequently I moved the speedo up to and protected it w/ a billet component.
Baja Designs now makes a Squadron that fits the OEM mask. When I got mine it was not available. I'll have to see if I can get retrofit.
Old 03-19-2012, 12:50 PM   #2903
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,508
Cleaned up my switch set-up.
Start/Stop now all on the right side.
Hi/Low on the left along w/ the grip heater switch and a spot to add one more switch in the future.
and BRP Hand-guard Mounts for a nice clean look.
You can see here where the brake line was before I switch its routing. Imagine a GPS on the ball mount, it constantly got caught-up.
Here is the whole shebang:
Yellow Pig screwed with this post 03-19-2012 at 12:59 PM
Old 03-19-2012, 12:54 PM   #2904
ian408
Oh?
ian408's Avatar
Oddometer: 14,475
Look what I picked up...
Nice new heat shield. Fits well on the aftermarket KTM/FMF pipe.
ian408 is offline   Reply With Quote
Old 03-19-2012, 01:02 PM   #2905
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,508
You can see the GPS setup and the Rally routing of the brake line here:
Old 03-19-2012, 02:03 PM   #2906
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,494
Common rally bike mode (and I think required by the ASO) to fix the brake line so it doesn't slide anywhere there is electronics. Lots of ways of doing this, here is an example from C.Vestal's excellent Rally Moto Kit thread. Brake line is fixed to the lower triple, flexes forwards and a bit outwards on compression. I'm sure 800 people will chime in on how it will hook a tree and put your eye out, but it works extremely well for many riders.
Looks like Dan has done something similar, though he routed the upper portion of his brake line down the other fork and crossed over at the top.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 03-19-2012, 05:18 PM   #2907
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,508
Nope, mine is the same way.
Old 03-19-2012, 06:06 PM   #2908
haknslash
haknslash's Avatar
Oddometer: 333
NOW we're talkin'!!
Stock plastic looks good with the squadron!
I looked on BD's website under KTM bike specific and didn't see it though http://www.bajadesigns.com/Products/...ECIFIC/KTM_EXC
Does anyone know if its available to order yet? Is a stator upgrade required?
YP, your switch and bar setup is nice! I hate the stock kill switch. I'm actually surprised nobody has killed themselves by accidentally hitting it . Oh the irony that would be. I've hit it climbing a nasty hill and it was no fun and full or cursing the bike
Old 03-19-2012, 06:16 PM   #2909
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 847
Hak,
Just rotate that switch forward so you can't accidentally kill it.
FlyingDutchman is offline   Reply With Quote
Old 03-19-2012, 07:05 PM   #2910
haknslash
haknslash's Avatar
Oddometer: 333
Originally Posted by FlyingDutchman View Post
Hak,
That's certainly a decent solution but I just dislike the design I guess. I like the idea of the push button better. A little cleaner but also harder to acdidentally flick or something. I like the euro switch for the running gear too
Times are GMT -7.   It's 06:49 PM.
