Old 04-17-2012, 09:51 AM   #3121
Country Doc
Wanderer
Oddometer: 2,758
Originally Posted by KTM Explorer View Post
4 or 5 carb related open ended rubber tubes hang in back of the engine, neatly draped. That ok?
Probably been desmogged, and those are the carb vent tubes and float bowl drain tube, exiting the bottom of the bike.
I have mine running through a carb vent filter before they're open to the atmosphere, FWIW.
dc
Country Doc is online now   Reply With Quote
Old 04-17-2012, 11:03 AM   #3122
neduro OP
Addict
neduro's Avatar
Oddometer: 12,021
7602 racing makes a nice setup for that.
Just opened up my 11 450 xcw after 95 hours, and the carb is still clean inside, which is a first. Usually there's all kinds of backwash above the slide, the carb vent filter seems to have sorted that.
Valves still haven't moved one bit, impressive!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 04-17-2012, 11:20 AM   #3123
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 208
Seafoam ?
Thanks for the vent tube advice. What filter for tube - link?
Fuel issue - back story:
BIke last was ridden Nov 5th 2011, added a bit of StaBil to the tank which was nearly full - Chevron Supreme. Now she runs - but only on full choke. Pop & sputter while rolling on throttle. Not ridden yet due to this. It was suggested to buy SeaFoam - just bought a bottle.
Question: Add direct to tank or direct to carb (both methods are on bottle) by some method?
KTM Explorer is offline   Reply With Quote
Old 04-17-2012, 02:13 PM   #3124
KTM Explorer
Dirt Whore
Oddometer: 208
Reply from guy who set up my suspension - really knows these bikes :
Carb needs to be cleaned, pilot jets clogged. Sea foam or other additives wont help now, too late
Old 04-17-2012, 02:25 PM   #3125
ian408
Oh?
ian408's Avatar
Oddometer: 14,566
He's right. Gas these days sucks. It's happened to me a couple of times and I feel like sending the state a bill each time.
ian408 is offline   Reply With Quote
Old 04-17-2012, 02:37 PM   #3126
KTM Explorer
Dirt Whore
Oddometer: 208
Oh crap. Is this something I can do myself? Quite mechanically inclined, but have never worked on a bike carb.
Old 04-17-2012, 07:32 PM   #3127
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
IS this on THE bike?
Old 04-17-2012, 07:37 PM   #3128
Krazyjohnny
Oddometer: 449
KTM Explorer,
There are several videos here to walk you through it. It is not that difficult and you will be surprised at what you find in there and how much smoother the bike runs.
On another note I just checked the valves after 65 hours. The .17mm gage had to be forced under the exhaust valves and the .15mm gage went under with some drag. The intake valves seemed a little loose, but just at the outer limit of the spec. Another 20 hrs and there will need to be a shim replacement done.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 04-17-2012, 08:33 PM   #3129
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,668
Originally Posted by windyhill View Post
All cleaned up ready for Hatfield & McCoy this weekend. I would have liked to have had 13/52 and an MT43 rear tire, but I'm sure it will be a blast.
Is that a Seat Concepts seat?
How much you got in it? StreetBikeMike
bigborefan is online now   Reply With Quote
Old 04-17-2012, 11:19 PM   #3130
jp4evr
I'm a dad, have a ceegar
Oddometer: 345
KTM 530 market in NorCal
Originally Posted by jesusgatos View Post
What kind of prices? I've been watchin this market pretty closely and am in the same area.
I am seeing things from $5000 - $7800. Huge range for 2008s mostly. Rarely an '09 will show up. LA seems to have more, but that is just too far to drive. Just got laid off on Friday so I'm not sure I'll be picking one up. Geez - Pains me to look at that cash just sitting there. Gotta do what's right though.
jp4evr is offline   Reply With Quote
Old 04-18-2012, 07:53 AM   #3131
KTM Explorer
Dirt Whore
Oddometer: 208
VIDEOS on carb cleanin'
Please plop a post regarding a video referenced above for carb cleaning - pilot / main jet.
Damn gas now made it so the bike won't run at all now - grrrr
Old 04-18-2012, 08:27 AM   #3132
windyhill
Oddometer: 64
Yes it is. Improvement over stock, but it might be a little too soft if you are 200+ like me. I'm not sure yet.
windyhill is offline   Reply With Quote
Old 04-18-2012, 08:32 AM   #3133
Country Doc
Wanderer
Oddometer: 2,758
Yep, that's the one I use also. I like it.
The only thing I don't like is that the allen key bolts that they use to secure the filter are a tiny, SAE size, which drives me crazy, so I have to keep a specially labelled allen key in the tool kit for JUST that carb vent filter holder.
dc
Old 04-18-2012, 09:09 AM   #3134
KTM Explorer
Dirt Whore
Oddometer: 208
Hmm looks pretty easy. Can the jet removal be reasonably (fairly easily) done with the carb on the 530 EXC?
Old 04-18-2012, 09:24 AM   #3135
windyhill
Oddometer: 64
I prefer to rotate the subframe up for more room, but it's not necessary. I liked this video.
http://www.youtube.com/watch?v=7y-1NRdqzxs
Times are GMT -7.   It's 07:10 PM.
