Old 04-23-2012, 07:17 AM   #3166
silverboy
Bunny
silverboy's Avatar
Oddometer: 544
Originally Posted by trav72 View Post
No, I'm talking about the one underneath for the engine oil.
Something is wrong with the KTM microfiche. It shows a sideways plug for my 09 as well. I just ordered a new one that was stripped from cylclehutt, it took 2 months. I talked to them on the phone and they had part number.
Good luck
Racing is life. Anything before or after is just waiting.
Steve Mcqueen
silverboy is offline   Reply With Quote
Old 04-23-2012, 10:55 AM   #3167
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 208
Just ordered up Hodakaguy's TAP (twist a plate) - will prevent plate cookage from muffler AND kidking the damn plate when getting on. SUPER SLICK!
KTM Explorer is offline   Reply With Quote
Old 04-23-2012, 11:08 AM   #3168
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 921
Good luck
OK, well I ordered that bolt with the part number bigborefan mentioned in the earlier post. Hope it gets here in a decent time and fits. If not, I'll have to order that after market aluminum magnetic $30+ dollar bolt. Which must be one of the most expensive bolts I've ever see on a bike.
onetravdown is offline   Reply With Quote
Old 04-24-2012, 09:52 AM   #3169
trailjammer
trailjammer's Avatar
Oddometer: 381
Originally Posted by Michhub View Post
Looked good while they lasted...about one season....
Yeh, the OEM tank pad stickers are 'cheaper' and will work on the Clockworks tanks fine, but I'm currently using Tech-Spec. It's more expensive, but you can buy a sheet and make any size you want. I have over 2K dirt miles on mine and they still look great, no peeling off or tears. heavy duty stuff. techspec-usa dot com
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 04-24-2012, 02:59 PM   #3170
onetravdown
I can't ride where?
Oddometer: 921
I had a bit of an oil leaking problem during my last hare scramble. I went down a couple of times and the bike was on its side while running. I'm guessing the oil you see in these pics came out of this hose highlighted in red and sprayed all over the place. Is that possible? I can't find anywhere else that is leaking. What is this hose supposed to be plugged into? It was already like this when I bought it from the previous owner. It just doesn't seem right to me. All of the other emissions stuff is gone.
highlighted in red
down through the swing arm
Out next to the catch tank. Which is disconnected while I try to clean up this mess
Old 04-24-2012, 05:04 PM   #3171
1 lunger
1 lunger's Avatar
Oddometer: 1,343
Just picked up my brothers bike from the dealer after 7-8 months. It's popping like crazy! I'm sure they never put an gas treatment in it over the winter. It was stolen and flipped before it went to dealer, but before that it ran great! I hope some sea foam will fix it. The insert in the FMF is missing, would that make it run lean! The skid plate is missing too. How much will that cost? 2011 exc 530...
Life is good!
1 lunger is offline   Reply With Quote
Old 04-24-2012, 05:09 PM   #3172
1 lunger
1 lunger's Avatar
Oddometer: 1,343
is this normal or missing a hose? It's next to the battery.
Life is good!
Old 04-24-2012, 07:04 PM   #3173
JTOP
Tree Top Flyer
Oddometer: 15
Life is good!
That canister is part of your smog equipment. Most people remove the canister when they desmog the bike. I'm guessing someone desmogged the bike (your brother or who ever stole it?). The skid plate will run $80 to $200 depending on what you're looking for. Search this thread for skid plates- there are plenty of options. Glad your bike was found.
JTOP is offline   Reply With Quote
Old 04-26-2012, 06:42 AM   #3174
1 lunger
1 lunger's Avatar
Oddometer: 1,343
Thanks, whoever stole it got hurt on it and took it out on the bike. It took over $3000 to fix it. Kinda wish they didn't find it, but it's fixed and running great. I hope my brother gets his act together and can come get it soon!
Life is good!
Old 04-28-2012, 09:06 AM   #3175
windyhill
Oddometer: 64
Any updates from Wossner piston users? Hours? Oil use? Power? Thanks.
windyhill is offline   Reply With Quote
Old 04-28-2012, 12:07 PM   #3176
Enecosse
Oddometer: 13
highlighted in red
The hose that goes overboard by your swinging arm should be plugged in upstream of your carb. From the photo showing your throttle cables it looks like the carb has been plugged with a 10-13mm bolt.
Enecosse is offline   Reply With Quote
Old 04-28-2012, 03:22 PM   #3177
Fulano
Scooter Trash
Fulano's Avatar
Oddometer: 424
Mines the same but I cannot find a metric threaded hose bib to plug the hose into so I just bought a one way filter and stuck it on the end. Keeps the dust out.
Been to Spain, Maine and Spokane. Jumped rope, smoked dope, farted, fucked and fought round the world, twice. Hell, I've even seen goats fuck in the market place, but I've never seen shit like this!
All I need are loose shoes, tight pussy and a warm place to shit.
Fulano is offline   Reply With Quote
Old 04-28-2012, 07:45 PM   #3178
guns_equal_freedom
Oddometer: 5,609
Originally Posted by VOLdog View Post
How do you stop?
On the 530 I turned the clutch lever/reservoir into the left hand rear brake.
I removed the rear brake pedal and I don't run a clutch lever.
For my 300 I bought the entire LHRB assembly from Rekluse, I should have just bought the brake line and used the clutch lever/reservoir for the brake.
I did the 300 first, then I did the 530.
guns_equal_freedom is offline   Reply With Quote
Old 04-29-2012, 11:40 AM   #3179
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,414
Have put a few thousand miles on my 450 with a Wossner piston and it doesn't seem to burn any oil between oil changes.
jesusgatos is offline   Reply With Quote
Old 04-29-2012, 02:38 PM   #3180
neduro OP
Addict
neduro's Avatar
Oddometer: 12,054
Also, check that hose hasn't burned where it goes by the exhaust pipe, easy to have them burn a hole there and then you'll get the oily mess pictured.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Times are GMT -7.   It's 09:40 AM.
