Old 05-07-2012, 02:53 PM   #3211
header
Chris
header's Avatar
Oddometer: 1,746
Originally Posted by jesusgatos View Post
Cool deal. I've seen a lot of these bikes run-up similar hours without anything more than oil changes and valve-checks. Wonder why these got such a bad reputation as far as reliability is concerned. Maybe just the initial problems with the 08's? Can't imagine why anyone would want to swap an RFS into one of these chassis though, with reliability like we all seem to be experiencing.
I chalk it up to people being naturally hesitant toward something they don't know about then grabbing at everything they hear and letting that influence them over first hand experience and knowledge. I think its a natural process for people to be afraid of what we don't know.
Its also something to keep in mind when thinking about the new 500 (or any other bike that is new and unproven), don't cut it down yet. Keep an open mind toward it until its proven to be a significant drawback.
My 2 cents for the day
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 05-07-2012, 06:35 PM   #3212
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
I studied this alot before Dakar, as you can imagine.
Every catastrophic failure I could find was a result of low oil.
The problem is that an engine can change oil level very quickly, when the rings hit a critical gap, or the valve guide seals lift. The latter failure can take an engine that has never burned a drop, and run it just about out of oil in a tank of gas.
I've come to the conclusion that if you overfill relative to the window, and check it religiously every single time you add fuel, you don't have much to worry about.
I haven't found any credible stories of engine oil going to the tranny on 09-newer bikes, which isn't to say it couldn't happen, but I did a lot of research.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 05-07-2012, 07:47 PM   #3213
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,602
Yep, If I believed the internets, my 2008 690 would never leave the garage. So far it has been great. Never stranded me, never failed to start.
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is offline   Reply With Quote
Old 05-07-2012, 08:27 PM   #3214
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
Originally Posted by Krazyjohnny View Post
After watching the video with David Knight talking about the shortcomings of the 500, I am glad I am on the 08' 530 EXC. The issues I have read about here and other places would drive me nutty.
All good stuff nonetheless.
I haven't ridden a perfect FI bike yet. My dads Sherco 450 is pretty close and my rc51 isn't bad. I have a 530 exc 2010. It's ok, but its going to kill me.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 05-07-2012, 10:34 PM   #3215
offrdr1975
offrdr1975's Avatar
Oddometer: 113
On this particular issue a friend bought a brand new hold over 2010 530EXC 6 days last year. During his first major ride with the bike last summer in the Ouray area we started noticing considerable oil usage on it. After he got back from the trip he found his transmission oil to be overfilled. He took it to the dealer and they found that oil was transferring from the engine side to the transmission side. They fixed the issue under warranty, so I would say it is still definitely possible with the 09 bikes and the 10 Six Days
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 05-08-2012, 02:29 AM   #3216
DRjoe
DRjoe's Avatar
Oddometer: 5,115
thanks for the info guys.
Is there a thread about converting the engine to a single sump?
Old 05-08-2012, 07:06 AM   #3217
Krazyjohnny
Oddometer: 448
Single sump oil solution?????
Why couldn't you have a piece of stainless tubing bent and installed with the proper fittings into the lower screen locations, thus manifolding the two sumps together? I am thinking this would not help with flow, but just "axing" the "queshun".
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 05-08-2012, 07:19 AM   #3218
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
Quick question:
Will a 530 run w/out a battery or with a dead battery if kick started?
Old 05-08-2012, 07:46 AM   #3219
LukasM
Oddometer: 5,418
I don't know of a single person that has swapped an RFS into a XC4 chassis, the engine mounting points are too different. People are using 07-11 SX-F and XC-F donors, the DOHC engines of those years are definitely problematic and they wear out very quickly. Lots of those bikes being parted out so you can often build a hydrid cheaper than buying a newer EXC-R. The SX-F/XC-F are also reported to handle a bit better, even if only few people will be good enough to really benefit from this - I am certainly not.
That being said I personally do not want an engine that burns oil, which a lot of XC4 owners - even post 08 - seem to have accepted as normal operating procedure. Just glad that I don't have that problem in the XC4 derivative in my FE570, and I also prefer the single sump...
Old 05-08-2012, 07:51 AM   #3220
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,920
Here's one:
http://www.dirttricks.com/rfs_in_new_frame.htm
I've seen a few others. I know Cross Country did it. I don't know that it's worth it, though. RFS engines have their own issues, too.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 05-08-2012, 07:55 AM   #3221
LukasM
Oddometer: 5,418
Originally Posted by Hayduke View Post
Here's one:
Here is one what? That's not an XC4 chassis, neither is Jar's, Cross-Country's, Olzy's or anybody elses on the forums....
Here is mine, also a XC-F (DOHC engine) frame:
Old 05-08-2012, 07:58 AM   #3222
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,920
Ah... XC- F. I was thinking Tony's was an XC4 chassis.
Old 05-08-2012, 08:09 AM   #3223
cross-country
cross-country's Avatar
Oddometer: 1,661
[QUOTE=LukasM;18638552]I don't know of a single person that has swapped an RFS into a XC4 chassis, the engine mounting points are too different. People are using 07-11 SX-F and XC-F donors, the DOHC engines of those years are definitely problematic and they wear out very quickly. QUOTE]
Much like the 08 530's the 07 450's (twin cam) gave the design a bad name. They were actually a very tough engine. I put 150 very hard hours on my XC-f without even a valve adjustment. They also out handled a 530 or 450 XC4 by a large degree.
The Hybrid that I built did not handle anything like it did in it's previous life. I originally put a 540 in it (mistake), once I took that out and put a 450 in it, it handled as good or better than a 530. The only way I would do this again would be to use a short stroke 450 (SX) engine.
That would be a sweet bike.
The RFS has it's own problems but can be built in many various configs. It also had many great upgrades that made it bullit proof, if you spent the money.
Here is mine getting beat to death, as usual. I miss RicketyCricket!
edit; whoops, sorry for clogging the thread with these deets, when I was typing this I thought I was in the RFS thread.
cross-country screwed with this post 05-08-2012 at 01:39 PM
cross-country is offline   Reply With Quote
Old 05-08-2012, 07:37 PM   #3224
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 891
I would be interested in this as well. I've seen some people have had it done but can never find any info about doing it or having it converted. Anyone?
onetravdown is offline   Reply With Quote
Old 05-08-2012, 08:32 PM   #3225
Country Doc
Wanderer
Oddometer: 2,745
I had my 09 450 single sumped (and changed to a 520...) by Thumper Racing when it started to burn oil at the 50hour mark. I religiously checked and maintained the oil, valves, etc, but I did not overfill relative to the window as Ned suggested (I filled halfway when cold as indicated in the manual). It was very stable until about 40 hours when it started to smoke and burn oil.
After a new piston and rings and the single sump conversion, I now have 120 trouble free hours (ie 70 hours on the single sump with the new piston). I have no idea whether single sump is really any better or worse, but the small amount of engine oil always struck me as being strange, and the Bergs never incorporated that part of the design.
So, mine seems fine, but that isn't exactly a research study. It doesn't seem to run any different, any cooler, or anything else. But it doesn't burn oil, so I'm happy about that.
dc
Country Doc is online now   Reply With Quote
Times are GMT -7.   It's 12:51 PM.
