Old 05-08-2012, 09:04 PM   #3226
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
Originally Posted by LukasM View Post
I don't know of a single person that has swapped an RFS into a XC4 chassis, the engine mounting points are too different. People are using 07-11 SX-F and XC-F donors, the DOHC engines of those years are definitely problematic and they wear out very quickly. Lots of those bikes being parted out so you can often build a hydrid cheaper than buying a newer EXC-R. The SX-F/XC-F are also reported to handle a bit better, even if only few people will be good enough to really benefit from this - I am certainly not.
That being said I personally do not want an engine that burns oil, which a lot of XC4 owners - even post 08 - seem to have accepted as normal operating procedure. Just glad that I don't have that problem in the XC4 derivative in my FE570, and I also prefer the single sump...
Oh, that makes a lot more sense. Thanks for essplaining.
jesusgatos is offline   Reply With Quote
Old 05-08-2012, 09:12 PM   #3227
guns_equal_freedom
Oddometer: 5,573
Single sump 530 motor?
Contact Dave at DJH Cycle Sport - http://www.djhcyclesport.com/.
guns_equal_freedom is offline   Reply With Quote
Old 05-09-2012, 11:46 AM   #3228
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 897
Thanks.
Anyone know of a write up anywhere explaining what is done to convert to a single sump?
onetravdown is offline   Reply With Quote
Old 05-09-2012, 01:24 PM   #3229
guns_equal_freedom
Oddometer: 5,573
Originally Posted by trav72 View Post
Thanks.
Single Sump 08-11 450-530exc
http://ktmtalk.com/index.php?showtopic=441716&hl=sump
You might need to be a member to view it.
Old 05-09-2012, 03:45 PM   #3230
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,620
That's the thing with KTMTalk, thousands of answers and opinions for every one question. I just get confused over there.
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is online now   Reply With Quote
Old 05-09-2012, 08:51 PM   #3231
guns_equal_freedom
Oddometer: 5,573
It's like anything else in life, you have to read and make decisions.
If Travis37or DJH post their opinion on a subject you should take note.
Old 05-10-2012, 12:59 AM   #3232
DRjoe
DRjoe's Avatar
Oddometer: 5,149
thanks for the link mate
joe
Old 05-10-2012, 11:35 AM   #3233
Krazyjohnny
Oddometer: 450
strumming lips with fingers...
After reading all of this stuff about single sump vs. dual sump and how much better this motor is than that....I feel the need to get rid of my 08' 530 EXCr and get into an air cooled, under suspended, underpowered "hondama" 250 or something.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 05-10-2012, 12:45 PM   #3234
roastbeef82
roastbeef82's Avatar
Oddometer: 86
Originally Posted by neduro View Post
I studied this alot before Dakar, as you can imagine.
Every catastrophic failure I could find was a result of low oil.
The problem is that an engine can change oil level very quickly, when the rings hit a critical gap, or the valve guide seals lift. The latter failure can take an engine that has never burned a drop, and run it just about out of oil in a tank of gas.
I've come to the conclusion that if you overfill relative to the window, and check it religiously every single time you add fuel, you don't have much to worry about.
I haven't found any credible stories of engine oil going to the tranny on 09-newer bikes, which isn't to say it couldn't happen, but I did a lot of research.
I overfill relative to the window ( just tilt the bike the other way to check its not way over) not noticed any problems --- yet
Life is what happens to you while you're busy making other plans........John Lennon
roastbeef82 is offline   Reply With Quote
Old 05-10-2012, 12:51 PM   #3235
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,620
How bout a smoking deal on an 08 690E. Those are junk as well.....
Old 05-10-2012, 12:52 PM   #3236
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,620
Same here, I drain the oil, change the filter and slap in 600CC of premium oil. My window is always full. No problems yet, but mine is still low hours, 40 so far.
Old 05-10-2012, 05:36 PM   #3237
Johnktm
Cannuks
Oddometer: 5
Sup fella's
just bought a 09 Ktm 530exc
Plaining on de-smog and adding the JD jet kit. Was wondering what fuel screw to use?
Its a blast to ride. No regrets thats for sure.
Anything else I should do?!
Cheers and Ill sure try to snap more pics.
Johnktm is offline   Reply With Quote
Old 05-10-2012, 06:18 PM   #3238
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 205
Took off the R&D flex adjust fuel screw.
IMO NOT a good design: threads are too short, and being pushed at an angle by virtue of the design,... well, mine was honked up. Get the JD with the large thumb wheel - mine runs a LOT better now!
KTM Explorer is offline   Reply With Quote
Old 05-10-2012, 06:55 PM   #3239
jesusgatos
jesusgatos's Avatar
Oddometer: 2,393
You're the 2nd person to post something like that about the R&D setup recently, and makes me wonder. Mine works great, and it's been installed on at least three different bikes. Maybe they changed the design or something? But this is an old one, and things usually get better...
Old 05-10-2012, 08:57 PM   #3240
Johnktm
Cannuks
Oddometer: 5
Ill look at the JD fuel screw thanks. What rear tires are you guys running, I'm changing mine soon.
Times are GMT -7.   It's 12:26 AM.
