Old 05-10-2012, 09:41 PM   #3241
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,982
Originally Posted by Johnktm View Post
Ill look at the JD fuel screw thanks. What rear tires are you guys running, I'm changing mine soon.
Pretty much any bike shop that sells dirt bikes will have fuel screws in stock, since (until this recent advent of FI), they pretty much all use an FCR carb. Mine is a Motion Pro, and since it was installed and set, I have only had to reach under and give it a 1/4 turn once. Set and forget in my case.
Your bike still has the smog stuff installed? I would be surprised since it already has an Akrapovic pipe, and that would cause such a lean situation over the barely running smog set-up, that it wouldn't run at all. I have a JD jet kit, and it has also been supplemented to do a second bike with FCR jets found at the local bike shop.
As far as tires go, get ready to hear a pile of choices, since they are dependent on riding conditions and preference. I have a Bridgestone 403 front/ Maxxis Desert IT rear, and a rear Bridgestone 404 rear waiting on the rack. Seem to be fine.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-11-2012, 02:14 PM   #3242
Johnktm
Cannuks
Oddometer: 5
Its running. but not really good. Ive ordered the JD jet kit and Works connection fuel screw. got these 4 parts ordered from ktm today
0603061001 CU-SEAL RING DIN7603-6X10X1
0025060086 HH COLLAR SCREW M6X8 TX30
0603100141 COPPER GASKET DIN7603-10X14X1
0910100003 PLUG DIN0910-M 10X1
That should cover the de-smog.
Should I look into other mods?
I'm thinking about a 50/50 tire because I will do lots of road riding. was thinking of this one
Pirelli MT 21 Rallycross
How are the ones you suggested for 50/50 usage?
Cheers!
Johnktm is offline   Reply With Quote
Old 05-11-2012, 02:59 PM   #3243
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,671
I like the Pirelli MT 21s myself. They are not gr8 in the mud, but they work pretty good IMO.
I also like the MAXXIS IT. I am running those right now and they are wearing pretty good. Again, not a gr8 mud tire.
I want to test the Michelin S12 and the MAXXIS ENs. The ENs are a little pricy though.
You might just have to experiment and see what works for you in your area.
The biggest change I made to mine was jetting. But mine is a XC-W so it was not all smogged up to begin with.
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Old 05-12-2012, 03:45 PM   #3244
Johnktm
Cannuks
Oddometer: 5
Did all the De-smog today, was wondering what you guys did with the hose you add that will run to the swingarm? Ive heard some dirt can get in or something?! Seen a vid on youtube of a guy drilling a hole in the catch can and running the hose to it. Just looking for some insight on this. Besides that still waiting on the jd jet kit and some oil & filter. Cant wait to frigging ride the thing Still not sure on the tire ill put on but no stress ill figure it out. cheers
Old 05-12-2012, 08:41 PM   #3245
VOLdog
Oddometer: 323
did u do this
i missed prev post regarding your exhaust, was going to suggest the factory exh mod.
http://www.youtube.com/watch?v=_1BxQIRC71k
VOLdog screwed with this post 05-12-2012 at 08:47 PM
VOLdog is offline   Reply With Quote
Old 05-12-2012, 08:44 PM   #3246
VOLdog
Oddometer: 323
ride it
i working and cant ride soo i feel your pain
Old 05-12-2012, 11:11 PM   #3247
Bob P
Bob P's Avatar
Oddometer: 11
Here's One I made Earlier.......
Still playing, but it's getting there....
KTM 530 exc 2011
ASC F3 Folding Levers
Force Radiator Guards
Force Case Saver
Twin Air Filter Skin
Akrapovic Silencer
Samco thermostat bypass silicone race hose kit with stainless steel clamps
Evans NPG+C Waterless High Performance Coolant
Enduro Engineering Billet Rear Disc Guard
Ultimate Add Ons iPhone Case and Charger
Kriega US 5 Tail Pack fixed to rear mudguard
Relocated rear indicators
Junked rear number plate holder/mudguard extension
Relocated horn behind headlight
Tyre Slime
One the Shortly to be Done List....
Jetting
Alloy Sump guard
Upgraded Clutch Cover
Thread won't let me upload a pic though...
Bob P is offline   Reply With Quote
Old 05-13-2012, 12:36 PM   #3248
Johnktm
Cannuks
Oddometer: 5
What you guys think about this setup? Still trying to figure out the best way to route this. To run a filter with it or not.
Old 05-13-2012, 10:06 PM   #3249
Deseret Rider
Deseret Rider's Avatar
Oddometer: 248
breather setup?
Johnktm------why not just run the end of that hose back hi into your airbox---with, or without, a filter. i'm trying to think of why that would not be a good idea---as I think that's the way I done mine.
Deseret Rider is offline   Reply With Quote
Old 05-14-2012, 01:04 AM   #3250
fencing5051
Oddometer: 40
530
? does any one know if the screan of a690r will fit the front of 530exc have also seen ignition key kit to fit will it plug into aus wiring loom
just about to by a clean 09 model to set up 4 adv riding ,down sizing from 990 any tips i needto know
ps great foram with lots of opinions
fencing5051 is offline   Reply With Quote
Old 05-14-2012, 06:58 AM   #3251
Krazyjohnny
Oddometer: 449
@JohnKTM,
I ran that hose into my airbox via the appropriate hose fitting. I removed the air filter and drilled a hole in the box about an inch above the lowest point in the box. Then inserted the brass hose fitting and used a washer and nut to tighten it down to the body og the airbox. Then connected the breather line using a hose clamp. Pretty simple mod really.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 05-14-2012, 07:00 AM   #3252
Krazyjohnny
Oddometer: 449
Floppy tail?
So I removed the stock tail section with the tail light assembly and plat holder and replaced it with the Sicass LED setup. It has made the tail section must more tidy and does not get caught in the rear tire. The problem is that it is really floppy. Any suggestions on making the rear fender more rigid? I've tried talking suggestively to it and rubbing on it with Plexus and nothing.
Old 05-14-2012, 07:43 AM   #3253
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,982
The Euro plate holder is really the best option. It has all the support the stock one has. Here is a post from Hacknslash's thread where he installs a very similar XC-W tail with an LED light. You could just buy the XC-W part and try and get the sicass light to work with it
The sicass is a very multi-fit pice. You think it is floppy on a KTM, you should see it on a Husaberg.
Old 05-14-2012, 01:43 PM   #3254
guns_equal_freedom
Oddometer: 5,594
I have a Wolfman Enduro tailpack on my rear fender.
I drilled through the KTM fender and the Sicass inner fender to mount the Wolfman.
No more floppy.
guns_equal_freedom is offline   Reply With Quote
Old 05-15-2012, 07:18 AM   #3255
Krazyjohnny
Oddometer: 449
I looked for the XC-W tail part and could not find it yesterday. Does anyone have a part number for just the tail? I have the lighting.
Times are GMT -7.   It's 07:26 PM.
