Old 05-22-2012, 09:10 AM   #3271
Krazyjohnny
Oddometer: 449
Thank you
Parts inbound
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 05-23-2012, 11:18 AM   #3272
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 869
Originally Posted by KTM Explorer View Post
The PW Garfiled is THE setup to use - The turns are BRIGHT, the fit is immaculate, the running/brake light is lo-profile.
But I had 2 already and now I'm using the XC-W brake light...YMMV (Paul had is a good guy and replaced them for free)
FlyingDutchman is offline   Reply With Quote
Old 05-24-2012, 10:50 AM   #3273
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,401
Received my new Renazco seat a few days ago. The Acerbis X-Seat that I was running was killing me. The Acerbis seat is OK for aggressive trailriding because it's really tough/durable, waterproof, and has decent traction. But if you actually want to sit on it, whew. It's rock-fucking-hard. Anyway, had the idea stuck in my head that I might like a supermoto-style step-seat. Mostly because it seems like I exert a lot of energy just trying not to get blown off the bike when riding at higher speeds on-road. So we put the step in the seat pretty far forward, but the transition area in the step is more gradual than a hard break, so it's not in the way when trying to shift my weight further back. The raised portion of the step-seat is also really nice on longer rides, when I want to move around a little bit, stretch my legs, etc. It's almost like having two seats in one (stock-height and a tall seat). Have to sit a little bit further back on the bike to get up on top of the step, but it's makes for pretty comfy cruising. Know that not many people are riding 2-up on these bikes, but I do, and the step-seat is great for that too. After putting about 400 miles on this seat over the last couple days, just wanted to let everyone know that I think this seat might make an even bigger difference in high-speed comfort than a fairing. It's amazing. The wind-blast doesn't even phase me anymore. The shape of this step-seat, in combination with the suede cover, keeps me glued to the bike without any of the pinching (legs) and pulling (arms). Really helps with the fatigue that would usually set in after a few hours in the saddle. Thanks James!
jesusgatos is online now   Reply With Quote
Old 05-25-2012, 04:40 PM   #3274
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Who makes those clutch levers that have a much better leverage point and reduce pull by like 30-40%?
Old 05-25-2012, 05:53 PM   #3275
jesusgatos
jesusgatos's Avatar
Oddometer: 2,401
http://www.midwestme.com/
Old 05-25-2012, 08:44 PM   #3276
Hypermofo
Oddometer: 297
fork question
I'm swapping the fork springs (or planning to once I locate a pin wrench) and I'm wondering if a regular open end wrench will work in place of special tool T14032 (the open end wrench looking tool) to remove the pre-load adjusters? Does anyone know what size it is?
Since I'm swapping springs and the bike's got about 25hours on it (and it's about a year old) I figured I would go ahead and change the oil. Is it necessary to fully disassemble the forks and remove the cartridge? Or can I just pour the oil out and replace once I remove the springs?
Thanks for helping out a fancy fork noob
HM
__________________________________________
Hey, is my collar bone supposed to look like that?
Hypermofo is offline   Reply With Quote
Old 05-25-2012, 09:16 PM   #3277
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,597
Originally Posted by jesusgatos View Post
Perfect!
That's the one.
Old 05-28-2012, 04:51 AM   #3278
Enecosse
Oddometer: 13
HM
http://www.youtube.com/watch?v=glG3gUjxjEU
http://www.youtube.com/watch?v=uo5NSJI3M60
Enecosse is offline   Reply With Quote
Old 05-28-2012, 08:16 AM   #3279
KevinColorado
Oddometer: 271
HM
No need to fully disassemble the whole lot... if all you are doing is springs. Look up Slavens Racing... he has some videos that will help. You can also look up some videos on youtube... none specific to the KTM but it will help.
The main thing is having that special tool to get the cap off... too bad you don't live in the Springs... Slavens has just about everything you could need and want for your bike. He does ship though!
There is also a service shop manual online if you look hard... google it and it is in PDF format.
KevinColorado is offline   Reply With Quote
Old 05-28-2012, 08:44 AM   #3280
FlyingDutchman
Dirt Biker
Oddometer: 869
Light for KTM 530 and 950 Adventure??
Anybody using a light or know of one that can be put on a 530 for a night ride and then transferred, plug n' play to a 950 Adventure??
Pics and links appreciated.
Old 05-28-2012, 03:39 PM   #3281
dirtdiver
Oddometer: 2,039
Originally Posted by dirtdiver View Post
Gents,
I went to day to remove my back tire. I had to beat the axel out of the wheel after removing the axe nut. After I got the axel out I noticed that the bushings on each side were gritty to turn and a metallic coating from the inside diameter of the bushing was bubbling off. Like heat or corrosion.
What is going on here? I have not seen this before.
DD
I decided to replace the bearings with a Moose upgraded set. All I could figure is that I was getting a heat build up from bad bearings. I will replace the bushing parts too. The parts come in tomorrow I think.
As quick update on my 2009 530. I bought it new about 3 years ago. At 15 hours it was burning about 1cc of oil per mile. I tried a bunch of different things that the factory guy told me with no joy. I kept working with them and by 30 hours they had replaced the top end. I had the new engine and it worked perfect with no oil usage for about the first 50 hours. All of a sudden it was burning oil at 1cc per 2.2 miles. I was disappointed but decided to just live with it. I figured it would get worse and I would rebuild the top end.
The funny thing is that now I am at 270 hours and it has no change for the worse. It still burns a bit of oil but my typical rides are around 500-700 miles and I replenish the oil with a small 300cc jug I carry. It really has not been an issue.
DD
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 05-28-2012, 08:02 PM   #3282
Hypermofo
Oddometer: 297
...too bad indeed...
Thanks for the info - I'll check out Slaven's site!
HM
Old 05-30-2012, 11:01 AM   #3283
trailjammer
trailjammer's Avatar
Oddometer: 374
I don't know of a specific light, but if i was going to go that route, I'd probably get some nice LED's that you can easily mount to like the forks and plug in. Build a custom mount, etc. :)
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 05-31-2012, 01:46 PM   #3284
windyhill
Oddometer: 64
After updating to the 11' spec rings and continuing to burn oil, I gave up on the stock piston. Installed a Wossner piston, now 20 hours later, the bike uses no oil, like a proper 4-stroke. Leave that oil jug at home. Something to consider when you freshen it up next time.
windyhill screwed with this post 05-31-2012 at 02:32 PM
windyhill is offline   Reply With Quote
Old 06-01-2012, 05:35 AM   #3285
IN2DEEP530
Oddometer: 2
Whats the better buy
Which of these to you see as the better buy....
2009 KTM 530 EXC-R $7000
Bike is new with only 161 miles and 5.3 hrs on the meter. NEVER SEEN DIRT. I bought it new and never used it. I installed a JD Jet kit before the bike left the garage. I added a euro tail section, quick release skid plate, slave cylinder guard, sicass tail lights, tool bag, enduro mirror, FMF slip-on. I also have a brand new set of black Excel wheels that have never had tires on them. Two new Conti SM tire (120), (160) and two new michelin tubes. Two front fenders one is KTM and the other is UFO. Wheel sizes are 5.00 rear and 3.50 front. Both have Talon hubs abd stainless bulldog spokes
2011 KTM 530 EXC $6800
2011 Ktm 530 EXC
-Barely ridden (17hrs - 506 miles
-FMF slip on
-JD jet kit installed
-Rear fender eliminator installed
-LED turn signal
-Have new mirrors that fold down while riding in woods still in package, and also have buddy pegs still in package!!
-Road ready, will need a back tire soon
Appreciate your thoughts.
IN2DEEP530 is offline   Reply With Quote
Times are GMT -7.   It's 01:12 AM.
