Old 07-23-2012, 12:08 PM   #3376
Krazyjohnny
Oddometer: 445
530 and FCR carb
As far as I know thye all came with that carb until the last year of the carb'd bikes. Should be an FCR39. Why are you wanting to go to the carb on a 96' DR?
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 07-23-2012, 12:48 PM   #3377
LukasM
Oddometer: 5,387
Originally Posted by Trinity_Session View Post
Just need to double check some info. Did all the 530's have the FCR MX Carb?
Looking to do a swap with a pre '96 DR650
All 2000-2011 400/450/520/525/530 EXC models came with a 39mm FCR-MX, all 400+ SX models with a 41mm.
The 00-07.5 and 07.5+ have a different size though.
Old 07-23-2012, 07:04 PM   #3378
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 194
Garmin Montana
Anyone use a Garmin Montana on their KTM? Non-KTM specific question:
I have a RAM bar mount unit with the cradle. Works great. Want to change to the Garmin Rugged Mount to provide power at all time to the unit - bought one.
Bought a 4-hole RAM ball mount to (theoretically) bolt on to the 4 hole rugged mount....................bzzzzzzt no go.
What do I need to purchase to hook the Gar rugged mount to?
THX!
KTM Explorer is offline   Reply With Quote
Old 07-23-2012, 07:11 PM   #3379
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
...because they RULE.
jesusgatos is offline   Reply With Quote
Old 07-23-2012, 07:28 PM   #3380
Navin
Navin's Avatar
Oddometer: 7,658
The DRs???
He is looking at buying my FCR and yes T-S, it is a 39mm for sure off a 09 530EXC.
More to the interests of the subscribers here, my 530 is now wearing a 41mm FCR off my parted out SXf450/505 with JD jetting kit installed and refined for the 505. I expected to have some jetting to test & tune to get it right but out of the box it already runs better than it ever did with the JD tuned 39mm.
Navin is offline   Reply With Quote
Old 07-23-2012, 08:43 PM   #3381
empedrado
Oddometer: 365
You need the Ram B-347U A Ram AMPS Connection plate
THX!
empedrado is offline   Reply With Quote
Old 07-23-2012, 08:58 PM   #3382
Trinity_Session
Trinity_Session's Avatar
Oddometer: 533
Originally Posted by Navin View Post
The DRs???
HEY! Leave my $500 won't start DR alone! It has had a hard life!
Trinity_Session is offline   Reply With Quote
Old 07-24-2012, 12:19 AM   #3383
jesusgatos
jesusgatos's Avatar
Oddometer: 2,374
The DRs???
Interesting. Tell me more. Have an extra 41mm FCR off an SX that I was going to put on one of these bikes. But it runs pretty damn good with the stock carb now that it's all jetted and tuned.
Old 07-24-2012, 02:27 AM   #3384
LukasM
Oddometer: 5,387
A guy called MX-Rob did a bunch of dyno testing comparing 39mm vs. 41mm FCR-MXs on a DR650 over on Thumpertalk if you want to do a search. For slow fat pigs like the DR and XRL I'd stick with a 39mm, you will enjoy the better bottom-mid torque more than you will 1 or 2 HP on top.
The bigger KTM RFS and XC4 engines have enough bottom end as it is and they don't weigh much, so they benefit more from the bigger carbs.
Old 07-24-2012, 10:20 AM   #3385
Navin
Navin's Avatar
Oddometer: 7,658
Slap it on! It gave the bike a better snap for sure and top end seems to be more agressive, more MXish. Lost nothing as far as grunt, all positives IMO, no downside. Still very managable just not as dull.
Old 07-24-2012, 11:31 AM   #3386
jesusgatos
jesusgatos's Avatar
Oddometer: 2,374
Yeah, why not. Jetting? MPG? Bike runs really clean and averages just under 50mpg right now.
Old 07-24-2012, 11:38 AM   #3387
Navin
Navin's Avatar
Oddometer: 7,658
Try the jetting you have in the 39. I was lucky my setting off my 505 were spot on, it even idled smoother. The great thing about having it right there is you can always go back to your starting point.
What do you have to lose if you can simply bolt it back together the way it is now???
Old 07-24-2012, 01:09 PM   #3388
jesusgatos
jesusgatos's Avatar
Oddometer: 2,374
Sounds good. Thanks, I'll give it a try.
Old 07-26-2012, 06:07 AM   #3389
Krazyjohnny
Oddometer: 445
Can't wait to hear the report back on this.
Old 07-29-2012, 03:51 PM   #3390
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,217
For those of you that run the KTM 6.3 gal tank. I am having issues when the tank runs down to about the 4" mark or so. The bike starts to back fire and then dies, like it's starving for gas. Then starts up like nothing happened. Then 15 minutes down the road, does the same thing. It only happens when the fuel level reaches this level. Wondering what is causing it? Fuel hoses are all below petcocks. I thought it might be a heat issue at first and rerouted hoses and lined the underside of tank but still happens and only once fuel reaches that lower area. Still obviously looks of gas left. Vapour lock? Any suggestions? Thanks!
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Times are GMT -7.   It's 03:31 AM.
