08-06-2012, 11:30 AM
#3421 |
Oddometer: 342
Wife and I have discussed jumping in on a pair of new injected enduros in about a year or so. This is good info to have. She was looking at the 350 EXC and Iwas too just because of how light it is. The 500 is what I would probably end up with.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
08-06-2012, 06:58 PM
#3422 |
Oddometer: 118
Hi Guys! New to the thread, I have owned my 530 since last year and she is finially taking shape.. Here she is currently, but im switch to the big wheel setup for a while to do some other stuff.... I am switching the tank out to a clockwork orange, I currently have the one in the Pic mounted, but I dont like how she wheelies with it lol.... Also strapping on some decent handguards and a GPS via ram mount..
The Bike has been pretty well dialed in, current mods are de-mog with a stock exhaust mod that works pretty well... Suspension dialed for my weight, but im still working with it. Also my local shop took care of most of this work, for a fee of course as all I would do if f it up somehow lol.. Also the shop owner said they figured out the problem with the FI right away, seems they shipped the US units with a 10 micron filter, and of course it clogs up right away causing the FI to act like poo and overheat and run like crap... Once they went to a 20 micron the issue went away... well here she is, I will post some pics of her transformation back to dirt mode here in the next week or so lol.. ![]() ![]() and these shots were nabbed after accidently hitting the Dusy Ershim trail and not knowing WTF it was! Big mistake lol.. I know what it is now of course ... |
08-07-2012, 06:30 AM
#3423 |
beat up ex flat tracker
Oddometer: 6,754
Thats a sharp looking bike,really slick looking super-moto wheels. On the stock muffler you just cut out the reducer towards the rear of it? Ive jetted mine but havent done anything with the exhaust yet. What kind of wheels are those?
I think theres more to the FI issues then changing out a filter,530's and most any single cylinder 4 stroke get hot on steep slow climbs,really hot in hot weather. Fuel can boil or nearly so. Fuel pumps dont work like that,carb's do. Fuel pumps and FI dont have to deal with that in most applications. If the bike never gets used in tough conditions/real trail riding the problem might never come up. Once a carb has a good median set up it can work in many altitudes with little to no jet work,especially on big 4 strokes. My 300 will need a little jetting work for wildly different altitudes but its easy to swap jets on it.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. Foot dragger screwed with this post 08-07-2012 at 06:41 AM |
08-07-2012, 08:49 PM
#3424 | |
Oddometer: 118
To keep running the Sumo setup I will need to upgrade to at least a big 4 or 6 piston setup, and im trying to figure out what will work best for both sumo and dirt, and I dont want to be swaping masters and calipers between the dirt/sumo setup.. So im wondering if a 4 piston w upgraded master would be ok, because I know a 6 would be complete overkill on the dirt, but im currently cooking off the brakes in just minutes at the moment, so I will be looking to upgrade it pretty soon.. |
08-07-2012, 09:20 PM
#3425 |
Oddometer: 584
I wanted to post up on the thread here to show the new dirt tricks fan. I'm very impressed with the quality of this fan. I run the acerbis 3.4 gal tank and was told they hadn't fit them to this tank yet so wasn't sure if the switch would be accessible. Well it is and it's absolutely perfect. Perhaps some Good info for you fellow 530 owners to know. Here's a couple pictures
bikepikespeak.com screwed with this post 08-07-2012 at 09:52 PM |
08-08-2012, 12:38 AM
#3426 | |
Oddometer: 4,900
That's a very bad idea for a dirt ridden bike that light, and it won't be easy to fit anyway. The front wheel will lock up very easily, the caliper won't clear the spokes on 21" properly and the large disc will hit stuff much more easily. Instead get a complete second 4/6 piston brake setup with a matching master cylinder and brake line, then you can swap it over in 2 minutes along with your wheels with 4 bolts without having to bleed anything.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
08-08-2012, 06:59 AM
#3427 | |
Oddometer: 118
a complete seperate setup would be the way to go... |
08-08-2012, 07:07 AM
#3428 | |
Oddometer: 6,754
Its odd but just having the smaller 19" or 17" ft wheel the brakes work better as they have more of a mechanical advantage over the smaller diameter. It seems like you would have to be riding it on the track to "cook" the brakes that quick,usually some cool off time on the street between corners. My 530 will only spend enough time on the street to get from one dirt spot to another.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
08-08-2012, 07:10 AM
#3429 | |
Oddometer: 6,754
Hmmmm.........
08-08-2012, 03:17 PM
#3430 | |
Oddometer: 584
They're pretty dang thin too! Fits perfect for me. |
08-08-2012, 04:59 PM
#3431 | |
Oddometer: 6,754
8 watts isnt much for the DTricks fan.
08-08-2012, 05:39 PM
#3432 | |
Oddometer: 118
This setup here would probably be perfect for some trackdays and sumo full time... http://www.motostrano.com/Moto-Maste...it-mm-race.htm or could go with a 6 piston and practice stoppies all day. Here is the road im talking about its toward the end of the video im the guy on the Blue R1 http://video.google.com/videoplay?do...86348944&hl=en |
08-08-2012, 06:12 PM
#3433 |
Unwounding
Oddometer: 4,326
Even with a 320mm rotor and relo bracket the stock caliper will overheat in short order. Better but not the real solution.
08-09-2012, 01:12 AM
#3434 | ||
Oddometer: 4,900
Motomaster is good, Beringer 4/6 P are both good, Magura radial (with QTM axial to radial adapter bracket) is good, FTE radial is shit, stock 2 P Brembo is shit, even with a 320mm bracket (and it only allows you to use a 4mm thick disc). I wouldn't advise those last 2 ones to anybody who doesn't ride like a grandma, at least not if it's up and down and not only flat riding. The Beringer cast iron rotors are awesome as they never overheat and wear your pads much less with their solid surface. Unfortunately they are very expensive and the center is made out of soft aluminum so it get's worn pretty quickly at the floaters and then needs a rebuild kit. You won't wear out a friction ring though! The Braking Wave sold through KTM Hard Parts and the Motomaster Flame are a good alternative. Just make sure that you get the right disc for your caliper, there are both 310 and 320mm variations.
08-09-2012, 05:11 AM
#3435 | |
Oddometer: 6,754
That sounds good to me,I would rather not change out stators as stock is often the best. We shall see.
