11-04-2012, 01:52 PM
#3646 |
///SAFETY THIRD///
Oddometer: 41,628
A quick question from a 530 newbie: will the HT cooler fit with a 6.3 Acerbis tank?
11-04-2012, 03:06 PM
#3647 | |
RubberNecker
Oddometer: 1,698
This is from the 3 x KTM go east thread. They had it on their 400s. . . . so it should. The last guy in this thread has it on his 450 as well.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI |
11-04-2012, 03:24 PM
#3648 | |
Oddometer: 31
00
11-04-2012, 06:57 PM
#3649 | |
beat up ex flat tracker
Oddometer: 6,766
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
11-04-2012, 09:14 PM
#3650 |
The Riding Dutchman
Oddometer: 25
11-04-2012, 09:46 PM
#3651 |
Oddometer: 189
Mine went right in on my '10. No need to pull head or anything. So it'll only go halfway in to the ridge?"
I didn't measure exactly but leaves maybe 5/8 inch or so sticking out of the housing I'll get ahold of Dirt Tricks tomorrow and see what they say. thanks! |
11-05-2012, 06:42 AM
#3652 | ||
Random Hooligan
Oddometer: 6,188
![]() Quote:
-Scott- Semper Fi '04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC "A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
11-05-2012, 03:06 PM
#3653 | |
There is no spoon.
Oddometer: 726
I went through the whole bike, desmogged her, jetted it, balanced the wheels, put on better suspension, big tank, changed the gearing, etc....all based of his build (with some tips gained from a few other guys too! ) and seriously, from day ONE, mine has just been a beast of a ride...I absolutely love it. I do need to get into better shape so I can really take weekends with it though! ![]() Ned, I said it before, but you rock man! Thanks again!
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
11-06-2012, 06:18 AM
#3654 |
Wanderer
Oddometer: 2,442
The HT cooler fits fine with the clockwork tank (Flanny has one on his bike).
Quick question for y'all here - I am finally replacing my handlebars due to a slight tweak after a summer get-off. I ordered the factory KTM bars as I was happy with the bend, but I received a set that does not have the drillings for the ignition switch/blinker switch on the right. What is the best solution here? Just clip off the plastic knob on the ignition switch and put it back on (it would "spin" more, maybe not a bad thing)? Electrical tape underneath for more grip? Drill the new handlebar? (yech). thanks dc |
11-06-2012, 06:23 AM
#3655 |
Oddometer: 4,923
Just shave off the knob IMO. You can easily tighten any switches enough so they won't spin from normal use, and in case of a crash they are then more likely to move out of the way instead of breaking.
I've even put teflon tape under my perches before to help with the that. Now I have HDB guards and it's not needed any more.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
11-06-2012, 06:45 AM
#3656 |
Random Hooligan
Oddometer: 6,188
I use the Flexx bars, so I just shaved the nubbin off. No issues.
I'll have to look for pictures of Flanny's bike. It looks, to me, like the HT cooler would hit the petcock.
11-06-2012, 06:55 AM
#3657 |
Tuareg 2013
Oddometer: 11,344
+1
And realized I hadn't posted a recent update on my Dakar 450 motor... At about 125 hours, it suddenly started consuming oil. Sure enough, I lifted the valve inspection cover, shined in with a flashlight while turning the motor over, and could see an intake valve guide seal going up and down. My mechanic had a sneaky solution- we locked the motor at TDC, installed a compression tester and turned on the compressor, and then took off the valve spring retainer/ spring, replaced the guide seal, and reinstalled, all using air to hold the valve up. Worked like a charm- about a 10 minute job. Back to consuming no oil. Leakdown was around 7%, which isn't bad for how that motor has been used! We did have to go 1 size thinner on both intake shims, first valve adjustment after half the Dakar, and a whole bunch of absolute flogging that has no internationally recognized name. I'm so impressed with durability on those motors.
For Sale: FJ60, or Defender 90, Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
11-06-2012, 07:31 AM
#3658 | |
Oddometer: 240
Switch rotation
If you have trouble with spinning -- like all the sicass ones I have ever had do. What works great is to cut a strip off a adhesive backed sanding disk and install that under the switch.
11-06-2012, 07:35 AM
#3659 | |
Oddometer: 6,766
You have a oil reservoir on that 450? __________________________________________________ ____________________________________________ We were out on a ride the other day,thrashing around in the woods,there were two Honda dealers along on the ride,after some bullshitting for a while,one of the guys (smartass) asked........So Honda is still making bikes? It got a laugh,almost all orange bikes on these rides,only Hondas are oldies or MX'ers. I guess the numbers just arent there for Honda to mess with it anymore.
11-06-2012, 11:16 AM
#3660 |
Unwounding
Oddometer: 4,321
Didn't someone just bring up the oil pump gears?
![]() I managed to cut the parts list a bit to about $28 for the gears, one o-ring, the gasket and the e clips. I'm leaving the shaft and not even opening the far side scavenger pump. I could have skipped the big cover gasket and the E clips too so no reason top avoid this job if you are a lil tight on $. My O ring was smaller for sure, though I have not had the oil transfer this should just be further bullet proofing. 09 530EXC. Thanks to Hodakaguy for writing up the guide on this. |
