11-16-2012, 07:02 PM
#3676 |
Allergic to Asphalt!
Oddometer: 6,084
I did the leak down test today and the rings are at 40%.
I have always been meticulous about my air filter and check the air boot between the filter and the carb everytime I clean it to make sure no dirt/dust has gotten through. I even run a filter skin 80% of the time. I'm pretty confident it was not dirt that did the rings in. Looking on line for piston & ring kits I cannot find anything for a 2010 KTM 530 XC-W. The only hits I get are for 530 EXCR. I'm assuming they are the same engine/piston, but want to double check. The Wossner pistons come in 3 sizes (94.96mm, 94.97mm & 94.98mm) depending on cylinder wear so I'll have to wait till I tear it down to order.
11-17-2012, 10:40 AM
#3677 |
Oddometer: 6,084
OK
Took the head off the bike and can't tell what is causing the oil consumption. Have a look at these pics and tell me if you see anything wrong. Cylinder looks great: ![]() Compression ring looks good: ![]() Oil ring looks good: ![]() Do these valve stem seals look properly seated? Not sure about this one? Intake side valves: ![]() Exhaust side valves: ![]() It's definitely burning oil, lots of buildup on the piston and the face of the valves. ![]() The back side of the intake valves looks pretty gunked up leading me to thing the intake side valve stem seals are leaking?
Yellow Pig screwed with this post 12-01-2012 at 09:29 PM |
11-17-2012, 11:48 AM
#3678 |
Oddometer: 6,084
Looks kind of like the valve seals to me. Now if it is the valve seals I'm I better off going a head and doing the wossner piston kit w/ the better oil rings and be done with it or just reuse the OEM piston and rings?
11-17-2012, 12:05 PM
#3679 |
There is no spoon.
Oddometer: 1,194
I'm not a good one to give you any advice - not the best mecahnic you'll find....
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
11-17-2012, 12:18 PM
#3680 | |
Mr. Motivated
Besides, valve stem seals shouldn't affect your leak-down numbers, so the pressure is either getting by the valves themselves or the rings. The rings on the stock piston are known to be problematic. I should point out that my previous comment, "especially at 100 hours" was not meant to imply that 100 hours is a lot. If you had said 200 hours, I probably would have said not to bother with the leak-down test, just go ahead and replace the piston if it's coming apart anyway.
Stobie Problems cannot be solved at the same level of awareness that created them. -Albert Einstein |
11-17-2012, 12:23 PM
#3681 |
Mr. Motivated
Oh yeah, I meant to way that my cylinder bore looked like that, too, at more than twice or maybe three times the hours. The out-of-roundness and taper were both less than 0.0005" (professionally measured by an engine machinist neighbor). I deglazed it with a dingleberry brush, and put it back together. Probably only 10 hours on the rebuild so far, but so far so good.
11-17-2012, 12:30 PM
#3682 |
Oddometer: 6,084
Did you go OEM or aftermarket piston kit?
11-17-2012, 12:52 PM
#3683 |
Mr. Motivated
I went with the Vertex. The Wossner is also supposed to be really good. The OEM piston lists at over $400, and has the questionable ring design. The Vertex was a little over $200, the Wossner about $175. The Wossner and Vertex are both forged, and the stocker is cast.
I don't think anyone has any criticism for the quality of manufacture of the stock piston, but most experienced engine guys find the oil ring design to be wacky.
11-17-2012, 01:10 PM
#3684 |
fishing with dynamite
Oddometer: 2,064
Wossner is still not burning any oil in my 450 after 7000+ miles.
11-18-2012, 08:14 AM
#3685 |
beat up ex flat tracker
Oddometer: 6,924
Its fun to ask for advice on ADV,if it was me I would search for a really good KTM mechanic and have him look at the whole top end,you've gone to all the trouble of taking it apart,might as well get it done right.
You dont want to guess at it. How much oil was it really going through? Were you measuring what came out at oil change or checking oil level through the window?Are you 100% sure the leakdown test was done right? People sometimes can mess that up if they dont do it all the time. From here the ring gaps look nice and tight,bore looks perfect. Replacing a (probably) good piston/rings may be just tossing money away. Internet hype may say you need an aftermarket piston,many get along for a very long time on OEM parts,some even finish the Dakar race on them.
Some bikes around at times Foot dragger screwed with this post 11-18-2012 at 08:23 AM |
11-18-2012, 08:19 AM
#3686 | |
Oddometer: 6,924
Anything more then 1 fast pass with a diamond hone will remove too much material. Luckily my 2011 530 uses no oil. I know KTM has changed ring/piston design since 08 and and the 2011 is supposed to hold up well. Im hoping so. Its a fun bike!
Some bikes around at times |
11-18-2012, 08:49 AM
#3687 | |
Oddometer: 7
My bore was basicly perfect, just select the right size Wosner piston, size the rings and assemble. Dave feels that touching the bore is pointless (unless their damaged or out opf spec) on these plated cylinders. Dave cleaned up and checked the head, installed new valve seals and opened up the oil pasage in the rocker arm. My bike now starts and pulls great with no oil consumpion. It was the best $600.00 bucks that I have spent on a bike! |
11-18-2012, 09:52 AM
#3688 | |
Mr. Motivated
I like my 530 a lot. It's a much better bike than I am a rider, but it's still not hard to ride. I had been out of the woods for 30 years, and was a little worried that the 530 might be too much; but I'm a big boy, and I also thought that something less powerful, although easier to ride, might get old as my "legs" came back. It turns out to be a really versatile, user-friendly bike that I'll never outgrow.
11-18-2012, 09:57 AM
#3689 | |
Oddometer: 6,924
11-24-2012, 01:58 PM
#3690 |
Oddometer: 957
Fantastic thread! I searched through and I see some of you have changed to the CEV multifunction switch. For the time being, I'm okay with the large factory headlight/turn signal switch on my new-to-me '08 450 EXC-R, but I'd like to install a combo start/kill switch. Right now, it has a single start button and I have to turn the key off to kill the engine.
A few years back, I did a full street legal conversion on an '06 EXC using the euro components. I'm fairly certain I used part# 59011074100. If I recall, there are few combo switches that look similar but have different part numbers (59411074000, 59411074100 and 59411074200). Can anyone verify which start/stop switch would be plug-n-play compatible with the '08? Thanks! Tipsy 59011074100
2008 Buell XB12X Ulysses 2008 KTM 450 EXC-R "There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy |
