Old 03-03-2013, 10:13 AM   #3931
trailjammer
trailjammer's Avatar
Oddometer: 368
Originally Posted by WHYNOWTHEN View Post
Looking at buying an 08 530. What kind of mpg could I be looking at if I was just riding along?
I'd have to agree. I usually get between 40-50mpg depending on terrain on my '08 530 EXC-R.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 03-03-2013, 10:21 AM   #3932
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,314
Wow, are you guys turning it off on the downhills I can't seem to get that mileage...although, I'm pretty hard on the throtle...a lot!
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 03-03-2013, 02:15 PM   #3933
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,390
Installing a new piston right now and lost the sharpie marks on the timing chain. Had already installed the piston/cylinder/head, so used the kickstarter to turn the engine over but there's no trace of any marks left anywhere on the timing chain. KTM service manual just says 'make sure the crank is at top dead center' but can't find anything in the manual about how to set the crank to TDC. Probably need to remove the stator cover and am guessing there will be some timing marks on the flywheel or something?
EDIT: nevermind. Found the answer on KTMtalk.
Originally Posted by DJH
With piston at the top there is a notch in the crank, not a hole.
Best way to locate it, ignition cover off, turn the crank until the clockwise edge of the raised block on the flywheel matches the counter clockwise edge of the black box (pulse coil). That is approximate TDC, now screw in the indexing bolt (without washer) until lightly snug, then back out one turn, try turning the crank, IF your in the notch it will rattle forward or back just a couple degrees. once confirmed that your in snug the bolt & check your cams
jesusgatos screwed with this post 03-03-2013 at 02:48 PM
jesusgatos is offline   Reply With Quote
Old 03-03-2013, 02:35 PM   #3934
GearedUp
GearedUp's Avatar
Oddometer: 841
There is a bolt on the right side cover below the water pump with a copper washer/spacer. Remove it and turn the crank till you find the slot. You should be able to put the bolt back in without the washer and lock the crank at TDC.
08 KLR 650
10 KTM 530 EXC
14 KTM Adventure 1190R
GearedUp is offline   Reply With Quote
Old 03-04-2013, 03:49 AM   #3935
wheelan
wheelan's Avatar
Oddometer: 42
Originally Posted by B-Rod View Post
Lots of info out there. Riceless950 has on on his Beta 450, and seems to love it, that said, mxbundy is a riding buddy of his.
site:advrider.com seatconcepts 530
Here's Bora20's seat.
I have that exact seat. Soreness never even enters my mind, yes that good.
wheelan is offline   Reply With Quote
Old 03-07-2013, 08:01 PM   #3936
hvman
Oddometer: 184
valve clearance
I just got a low hr 530 exc, just checked the valves for the first time. Its time to confess my ignorance, will the clearance tend to increase or tighten? thanks!
hvman is offline   Reply With Quote
Old 03-07-2013, 08:54 PM   #3937
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
tighten
Old 03-07-2013, 10:07 PM   #3938
hvman
Oddometer: 184
Originally Posted by jesusgatos View Post
tighten
thank-you
Old 03-08-2013, 07:56 AM   #3939
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
50mpg on a 530? Mine never spends enough time on both wheels to get much over 40mpg. The ft wheel is for ever clawing at the sky while the back tire shoots huge gouts of earth out the back.
Is there another way to ride these things?
Signed,perplexed.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-08-2013, 08:07 AM   #3940
woodzrider
Oddometer: 585
Signed,perplexed.
At least you won't be buying many front tires!!!!!!!
Woodzrider AKA vetracer1
"If it can't kill ya-it's not a sport"......It ALMOST killed me tho.....
Check out my crash report:
http://www.advrider.com/forums/showthread.php?t=500314
Baja report http://www.advrider.com/forums/showthread.php?t=641219
woodzrider is offline   Reply With Quote
Old 03-08-2013, 12:45 PM   #3941
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 196
Leaking water pump seal, gonna install a seal + the high flow pump impeller!
KTM Explorer is offline   Reply With Quote
Old 03-08-2013, 01:26 PM   #3942
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
Same here. Have you looked-up Hodaka's posts and parts lists yet? Need to figure out exactly what parts to order and haven't had time to dig up that info. Know it's in here somewhere...
EDIT: here it is
jesusgatos screwed with this post 03-08-2013 at 01:39 PM
Old 03-08-2013, 01:31 PM   #3943
WHYNOWTHEN
where are the pedals?
WHYNOWTHEN's Avatar
Oddometer: 590
Picking up a well used '08 530 on saturday. HOORAY!
where does that road go?
WHYNOWTHEN is offline   Reply With Quote
Old 03-08-2013, 01:36 PM   #3944
jesusgatos
jesusgatos's Avatar
Oddometer: 2,390
Signed,perplexed.
Yeah, and that's with a 41mm FCR on it. Otherwise all stock except for a full FMF exhaust. But am just putting around most of the time. As much as I know you hate it, using this thing primarily as transportation right now.
Old 03-08-2013, 04:00 PM   #3945
KTM Explorer
Dirt Whore
Oddometer: 196
WATER PUMP - Hodakaguy's writeup ...... is THE bible on how to do it:
http://www.pnwds.com/t1786-08-11-ktm...acement-how-to
FREAKING AMAZINGLY WELL DONE!
Times are GMT -7.   It's 02:47 AM.
