Old 03-16-2013, 10:54 PM   #3991
hvman
Oddometer: 184
heated grip power supply
is there an available, switched power supply for heated grips? 09 530 exc thanks
hvman is offline   Reply With Quote
Old 03-17-2013, 06:19 PM   #3992
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
After riding some nice single track today my XCRW 450 got a little hot headed and spewed some coolant, I have the powerflow impeller and coolant recovery on it to help, so far it's been amazing and no spills until today. I'm not concerned about it but would like to know if the radiator fans fit on the radiators with moose racing braces on as well? I know I need a new stator as it is so I'm not worried with it any time soon but would like a piece of mind knowing for the really slow 1st gear stuff I can switch some fans on but unsure if the fans will fit with the moose braces on because their a little thick, also I need a new radiator for the left so should I get a stocker again to be sure they fit since the aftermarket ones I've seen are thicker?
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 03-17-2013, 10:03 PM   #3993
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,398
Spent the day pre-running a roadbook ride that I'm setting up here in Colorado.
Still a bit of snow in many areas.
Old 03-18-2013, 04:11 AM   #3994
Bungholio
Bungholio's Avatar
Oddometer: 627
HDB has orange deflectors? The black ones got a little scuffed up so I just swapped to the white ones. Have to check their website again.
Bungholio is online now   Reply With Quote
Old 03-18-2013, 10:35 AM   #3995
AB13
Oddometer: 944
ACERBIS X-Seat?
anyone have one of these and if so what do you think. thanks AB
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 03-18-2013, 10:37 AM   #3996
trailjammer
trailjammer's Avatar
Oddometer: 366
I haven't personally used one of those acerbis. I love my Seat Concepts seat though.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 03-18-2013, 10:41 AM   #3997
trailjammer
Oddometer: 366
I run the stock radiator, aftermarket radiator guards (not moose, but contact moose directly to check fit for fans) and clockworks tank. My fans clear no problem on my '08 530. Depends on tank and guards you run. Definitely run the fan though.
Old 03-18-2013, 10:41 AM   #3998
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,823
From what Ive heard,and this makes it hearsay,
Those seats are skinny hard and good for moto-x,not so great for off road and or distance riding. They are light though.
Enduro Engineering seats have always been my go-to seat for KTM's.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-18-2013, 11:11 AM   #3999
AB13
Oddometer: 944
Moose Gaurds
I have the Moose guards they work with the fan and a ACERBIS 3.5 gal tank.
Old 03-18-2013, 04:56 PM   #4000
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
HORRIBLE. The worst. Maybe okay for racing and riding gnarly singletrack where you're not sitting down much, but, ugh. Got rid of mine and replaced it with a Renazco. Can do 500-600 miles/day in relative comfort now.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 03-18-2013, 07:05 PM   #4001
J.Johnson
J.Johnson's Avatar
Oddometer: 85
This came out of my engine drain plug hole. Crap!!! Houston, I got a problem. 7800 miles 378 hours.
Sent with mind control...
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 03-18-2013, 07:20 PM   #4002
KrustyKustom
Lets Go....
KrustyKustom's Avatar
Oddometer: 633
wow..
I agree...crap, but 378 hours? I'd say you got your moneys worth....
Krusty Kustom,
Houston Texas
2013 KTM 500exc
KrustyKustom is online now   Reply With Quote
Old 03-18-2013, 09:05 PM   #4003
Foot dragger
singletracker
Oddometer: 12,823
Yikes,that's a lucky find,better pull that pup apart now!
Bearings falling out the bottom side isnt a good sign.
Sad kinda,My DR650 was just starting to run good at that mileage and continues to at nearly 30,000 and will maybe go to 60,000 with luck,or more.
I hope my 530 goes awhile.
Old 03-18-2013, 09:51 PM   #4004
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Ok. Motors out. Now to find some one in Orange County CA. To rebuild this sucka.
Z racing ??
Old 03-19-2013, 02:50 AM   #4005
windyhill
Oddometer: 64
Possibly the drive pin from the oil pump shaft? Looks very similar to the one in Hodakaguy's pictorial.
windyhill is offline   Reply With Quote
Times are GMT -7.   It's 08:18 AM.
