Old 04-12-2013, 05:54 PM   #4111
resqd1
Oddometer: 236
Originally Posted by mookymoo View Post
Highway dirtbikes. Strongest there are...
(and nice options like integrated mirrors, indicators, etc)
Hmm never heard of them I will have to check them out, got a pic of a pair on a 530 at all?
resqd1 is offline   Reply With Quote
Old 04-12-2013, 06:03 PM   #4112
mookymoo
Mookish Mook
Oddometer: 4,396
Their website has a decent gallery
http://www.highwaydirtbikes.com/HDB_...ay&ref=gallery
mookymoo is offline   Reply With Quote
Old 04-12-2013, 11:44 PM   #4113
Bungholio
Bungholio's Avatar
Oddometer: 787
See post #4084. Not the best picture but you can see the bar clamp, deflectors, and mirrors.
Bungholio is online now   Reply With Quote
Old 04-13-2013, 12:45 AM   #4114
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 1,025
Originally Posted by Bungholio View Post
See post #4084.
Direct link to Post #4084.
Tipsy
2008 Buell XB12X Ulysses
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Old 04-13-2013, 04:20 AM   #4115
barkbuster67
barkbuster67's Avatar
Oddometer: 68
Valve clearance ?
Recently picked up an 08 530 EXCR. Checking the valves and have one exhaust valve that is loose at .20 (could even be a .21). I thought the valves tighten up with use?!? I'll be tearing the top end off to replace the valve stem seals. Is there anything I should be looking for as far as the loose valve? All the other valves are within spec. The left side tank mount has not been cut, so I would have to assume that no shims were ever replaced? THANKS BIG TIME to all those that provide the wealth of knowledge here!!!
barkbuster67 is offline   Reply With Quote
Old 04-13-2013, 06:25 AM   #4116
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,874
If you're actually burning some oil, I wouldn't be surprised to see some carbon buildup on the valve. If no carbon, it's prolly just a case of it not having been checked yet. Most folks have said they need a shim or two swapped at the first check, then don't move after that.
I put new stem seals and piston in mine a few months ago. Nice bike to work on, even better to ride.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 04-13-2013, 04:22 PM   #4117
Joe
Debaser
Joe's Avatar
Oddometer: 1,779
Originally Posted by NWBoarder View Post
I have the same issues on my '08 530 EXC-R, and will be doing Hak's Torque limiter mod. Supposedly the cam was fixed by the previous owner, but I will check.
I think its time for a new battery 530.
Have there been improvements in the Shorai products? Or should I stick with conventional?
I bought a Turntech 5A and its been great so far.
Joe is online now   Reply With Quote
Old 04-13-2013, 07:45 PM   #4118
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
I have an 08 450 XCRW that I'm doing the oil gears upgrade and etc. to tomorrow, I went ahead and tore the cover off today after work......I got the bike in trade so the Z-start was on and the hodakaguy's picture thread I'm following does not show how to to undo the clutch for a Rekluse......help? Is it the same way? what should I look for or be careful off? I noticed there is no locking nut so do the star nuts all around the center remove the clutch? Is it one piece or normal clutch and just keep them in the same order as they come off?
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 04-13-2013, 07:49 PM   #4119
resqd1
Oddometer: 236
Have you tried Rekluses website, they have all the install manuals on there site , it may help you out, or give them a call, they are really helpful.
Old 04-14-2013, 06:53 AM   #4120
Adios Pantalones
AdventureDeficitDisorder
Adios Pantalones's Avatar
Location: San Diego, not Mex, but I can smell it from here.
Oddometer: 2,331
+1 on the HDB guards. You can nearly hang the bike from them. Bomber strong and the optional mirrors actually work well. Nice options on the bar clamp piece if you want to customize.
Adios Pantalones is offline   Reply With Quote
Old 04-14-2013, 07:20 AM   #4121
resqd1
Oddometer: 236
k thanks guys I will def check them out
Old 04-14-2013, 07:21 AM   #4122
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,902
Originally Posted by mflora98ss View Post
I just got some new sneakers on my bike. I went with the Michelin T63's. Anybody else run these? Hopefully it quits raining sometime soon so I can so how they do.
I had a T-63 on a DRZe I had,when leaned over theres not much knob to grab with in loose dirt,they last a good while but kinda slidey.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-14-2013, 05:26 PM   #4123
Scott G
Oddometer: 51
Time to rebuild
I have 8800 miles on my 2010 XCW and wondering when is it time to rebuild the top end.
I do want to take something a part that is not broke, but I dont want to wait to long and cost me more and mess up a ride weekend or 2
Any advise?
Scott G is offline   Reply With Quote
Old 04-14-2013, 07:28 PM   #4124
Foot dragger
singletracker
Oddometer: 12,902
Any advise?
8800 miles,that's a good long run for one of these.
If it runs good,doesnt burn oil,starts good,Id do a compression check and see how that goes.
Old 04-15-2013, 06:19 AM   #4125
empedrado
Oddometer: 379
I just did my top end at 10,000 miles. Everything in excellent condition except the compression ring gap was considerably out of spec. Bike was using a little oil but not more than what KTM thinks is acceptable.
empedrado is offline   Reply With Quote
Times are GMT -7.   It's 01:25 PM.
