Old 04-16-2013, 09:18 AM   #4141
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
Originally Posted by KTM Explorer View Post
Is this a proven necessity on a 2010 530 EXC?
http://www.dirttricks.com/tct.htm
Necessity, not really. I have only been involved with 4 XC4s, and two needed the CCTs changed out, both with the Dirt Tricks with excellent results. I expect there will be 5 posts after mine saying it is absolutely necessary, but I'm the 'if it ain't broke . . . ' kind of guy.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 04-16-2013, 05:35 PM   #4142
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 870
Proven unnecessary but it will quiet you timing chain when it is idling.
But I didn't believe in the doohickey either
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 04-18-2013, 08:44 AM   #4143
roastbeef82
roastbeef82's Avatar
Oddometer: 86
Balance out rim lock
I don't want to remove the rim locks, but I am starting to do an increased amount of roadwork on my 530 and it's just awfull on the road.
How much weight do I have to add opposite the rim lock to improove things?
(don't want to add another rimlock - PITA when changing tyres)
Thanks in advance for your replies
Phil
Life is what happens to you while you're busy making other plans........John Lennon
roastbeef82 is offline   Reply With Quote
Old 04-18-2013, 08:54 AM   #4144
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 418
^^ Depends on what brand/type rim lock you have.
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 04-18-2013, 09:08 AM   #4145
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 208
DT Tensioner:
I got one because Hodakaguy pretty much said 'do it' and he is the man for the big KTM dirt bikes. DirtTricks is out of them until Friday, the part number difference is only for a 350 or some such KTM. Get it, his OEM tens failed at 70 hrs
KTM Explorer is offline   Reply With Quote
Old 04-18-2013, 10:01 AM   #4146
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,113
Phil
I just removed the rim lock, weighed it, added that much weight directly opposite, and re-installed the rimlock. Worked great.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 04-18-2013, 10:34 AM   #4147
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,414
I just add a 2nd rimlock, but you might want to replace yours with one of those superlight ones Motion Pro makes? Would take less weight to balance out.
jesusgatos is offline   Reply With Quote
Old 04-18-2013, 11:10 AM   #4148
FlyingDutchman
Dirt Biker
Oddometer: 870
DT Tensioner:
I'm sure Hodakagod will allow his sheep to use
http://www.djhcyclesport.com/djh-ten...nsioner-2.html
Old 04-18-2013, 04:06 PM   #4149
FlyingDutchman
Dirt Biker
Oddometer: 870
Phil
What are you going to use for weight?
As I recall:
3oz front
4oz rear
I balanced my wheels and posted the rim lock weights here around May 2010. You can look them up for sure. They came off and I have not replaced them...ymmv
Old 04-19-2013, 12:49 PM   #4150
roastbeef82
Oddometer: 86
As I recall:
3oz front
4oz rear
I got hold of some stick on lead weights - but thinking about it - I don't know if they will stay on for long in the dirt.
Old 04-19-2013, 01:21 PM   #4151
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,462
I've had then on my front tire for over a year, through the high Colorado passes to the rocks of Utah and the backroads around here and still sticking! Just clean your rim good and wipe with rubbing alcohol.
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is online now   Reply With Quote
Old 04-19-2013, 01:27 PM   #4152
DaveRMS
DaveRMS's Avatar
Oddometer: 1,206
Here's what I've been doing for wheel weights lately...
Remove the tire and tube/mousse. Remove rim tape/strip. With rimlock installed, balance the wheel by placing normal stick-on wheel weights INSIDE the dish of the rim. When balanced, remove rimlock and cover the weights and the entire dish with duct tape (instead of rim strip). Install rimlock and mount tube/tire as usual.
This way you won't lose the weights, and you never have to worry about them again. It gets pretty close and I haven't noticed changes after tire changes.
Dave
DaveRMS is offline   Reply With Quote
Old 04-19-2013, 05:37 PM   #4153
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 2,462
Dave
Only problem is that duct tape holds moisture and everything will eventually corrode unless your in there lots and changing it often. The rim tape is rubber and dry's quickly.
Lappeman
Old 04-19-2013, 06:34 PM   #4154
JTOP
Tree Top Flyer
Oddometer: 15
Wheel Balance
I had a terrible wobble in the front wheel that had to be fixed. First, I got the Motion Pro lite lock. I think it weighs almost half what the stock lock weighs. Then I got the sticky weights and placed a few opposite of the rim lock in the drop center of the rim (the same amount as what the rim lock weighs). Covered it up with rim liner and installed the tire and tube. The pressure of the tube will keep them in place. Took care of the issue. Since then I've switched to Tubliss and you can't have weights under that, but I haven't noticed any wobble in the front.
JTOP is offline   Reply With Quote
Old 04-19-2013, 07:31 PM   #4155
jesusgatos
jesusgatos's Avatar
Oddometer: 2,414
Dave
That's a great idea. I just run two rimlocks on the rear wheel (dirt), one up front and have never even noticed any vibrations or anything. No rimlocks on my street wheels and no balancing issues either. Lucky or happy idiot, dunno, but have never had any issues.
Times are GMT -7.   It's 07:16 PM.
