Old 04-20-2013, 04:59 AM   #4156
davesupreme
grand poobah
Oddometer: 1,474
i'm into this balancing thing.... i tried w/mine, and couldn't get anything w/the right profile to fit on the curved dirtbike rims.... actually slotted some .45 lead bullets on my mill to crimp on the spokes... worked half-azzed, ones fallen off, took quite a few to make it work.....
anybody tried those 'dynabeads'?..... their video of balancing that bottle mounted to a drill looked interesting....
davesupreme is offline   Reply With Quote
Old 04-20-2013, 08:08 AM   #4157
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 04-20-2013, 12:53 PM   #4158
Country Doc
Wanderer
Oddometer: 2,729
I have found that the regular lead weights stick just fine and do not fall off despite the most thorough thrashing.
I put the strip of lead lengthways in a bench vice and crease it down the middle so it has a 30deg angle or so. This allows it to sit reasonably well on the rim.
dc
Country Doc is offline   Reply With Quote
Old 04-20-2013, 07:02 PM   #4159
Weldit
Weldit's Avatar
Oddometer: 336
wheel weights
these are awesome - never fall off or move
not cheap - but well made !
actually they are a deal compared to other stuff I have bought for bike.
Reusable Wheel Weights - ADVrider
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 04-20-2013, 07:16 PM   #4160
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,862
+1
Well made, reusable, and they make for a really easy balancing job.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 04-21-2013, 05:05 AM   #4161
davesupreme
grand poobah
Oddometer: 1,474
i've been trying to find some 'lead' wheelweights, so i could bend/form them to sit on dirtbike rims.... not having much luck... seems lead is a bad word nowadays, and they're all made of steel now, which isn't gonna form too easy.... anybody got a source for real lead wheelweights?....
Old 04-21-2013, 07:48 AM   #4162
resqd1
Oddometer: 236
If you are just trying to make something to work, are you wanting them on your spokes? You could try bullet weights for fishing, the fishing industry still uses lead a lot.
resqd1 is offline   Reply With Quote
Old 04-21-2013, 08:30 AM   #4163
APBlack
nOOb on a fly
APBlack's Avatar
Oddometer: 204
NoMar carries spoke weights the work great.. Just stick them over the spoke and tighten the set screw. Have them on my Husaberg for the last couple of years with no problems..
But I do have to say I kinda like that idea of the weights inside the rim.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
13 KTM 990 Adv Baja
11 Husaberg FE570S Swedish hotness
08 Husky SM610.. gone
06 KTM 950 Adv (orange one).. gone.. damit
05 Honda 650L.. gone
APBlack is offline   Reply With Quote
Old 04-21-2013, 11:07 AM   #4164
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 456
I just ordered up a set of these for my wheels. I've got Michelin T63's and on the front it's out 3.5 oz's, and on the rear it's out 5.25 oz's.
mflora98ss is offline   Reply With Quote
Old 04-21-2013, 11:22 AM   #4165
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 843
My concern with these weights is that the spokes can't be tightened easily? What happens when the spoke breaks or comes loose?
I tried the lead fish weights...they didn'last 15 hours.
It's good to hear the stick-ons hold but that's a lot of weights...Doc, can you post a pic of your wheel weights?
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 04-21-2013, 02:44 PM   #4166
roastbeef82
roastbeef82's Avatar
Oddometer: 86
The weights I had were steel and took a bit of bashing to get them to conform to the wheel profile. The rear wheel worked out OK but the front ended up a bit of a mess. The problem is that the weights bent in the middle as they were held in the vice, they did not end up with a nice curve.
The weights were 110g for the front and 135g rear.
Took her out for a spin after - the ride was very civilised, no bouncing handlebars or slapping chain, just the steady drone of knobblies on tarmac
Anyone know where I can remove 245g (over half a pound) of weight from the bike!
Life is what happens to you while you're busy making other plans........John Lennon
roastbeef82 is offline   Reply With Quote
Old 04-21-2013, 03:41 PM   #4167
Scott G
Oddometer: 49
Originally Posted by Foot dragger View Post
8800 miles,that's a good long run for one of these.
If it runs good,doesnt burn oil,starts good,Id do a compression check and see how that goes.
Thanks,
Uses a little oil not bad and runs great.
Scott G is offline   Reply With Quote
Old 04-21-2013, 05:15 PM   #4168
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 456
The best way to lose a half a pound on your bike is to get a lighter universal joint between the bars and the pegs.
Old 04-21-2013, 05:49 PM   #4169
Honkey Cat
Tailights Fade!
Oddometer: 1,104
New battery keeps going dead??
Installed some adv monster led 3300 lumen lights. 3 amps each. Wired it directly to the battery with 1 switch that turns both on and off. With a new battery fully charged it goes dead after riding bike around for an hournwith the led's on. Turn bike off and then try to immediatly try to start it nothing battery drained????
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 04-21-2013, 05:54 PM   #4170
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 366
^^ have you done the DC stator conversion?
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Times are GMT -7.   It's 10:23 AM.
