Old 04-29-2013, 06:19 PM   #4216
Bora20
Oddometer: 854
Originally Posted by Honkey Cat View Post
2010 530 xc-w. I only has 8hrs on bike so I have never had the seat off yet until today. After I removed the 8mm bolt that holds seat on,the seat did not want to come off. Finally it popped off with some forearm persuasion. Went to install the seat back with the new seat cover and no way will it go on. The seat will not sit flush where the bolt and seat bolt aluminum collar sit.
Mine doesn't fit either, never quite has. I have a trick though.
Put seat in place, rest it on the collar, smack hard with hand and voila! it pops into place and I put in the bolt.
Might work for you, has for me for the past 120+ hours.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 04-29-2013, 06:25 PM   #4217
wsmc831
wsmc831's Avatar
Oddometer: 760
Stock tank? Mine didnt fit at all with clockwork tank. I eventually got rid of that large nut and used a washer. Won't buy another clockwork tank....
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 04-29-2013, 06:27 PM   #4218
Bora20
Oddometer: 854
Mine fits the same with the Clockwork tank too! Just give it a whack :)
Dan
Old 04-29-2013, 06:33 PM   #4219
Honkey Cat
Tailights Fade!
Oddometer: 1,114
yeah stock fuel tank, I've hit it with my hand, rubber mallet, the peoples elbow.
Nothing works. I'm going to probably remove subframe and re-weld it the way it is supposed to be. At least I'm not going crazy and I'm the only one.
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 04-29-2013, 06:34 PM   #4220
Bora20
Oddometer: 854
You could pull the tank, put the bolt in mounting upright it and tap it with the rubber mallet to move it forward just a little.
This might give you enough or just shave down the underside of the seat a little. It shouldn't take much.
Dan
Old 04-29-2013, 06:35 PM   #4221
NAVIGATOR
Wanderer
NAVIGATOR's Avatar
Oddometer: 1,705
+ 1---same method works fine for me
NAVIGATOR is offline   Reply With Quote
Old 04-29-2013, 06:38 PM   #4222
wsmc831
wsmc831's Avatar
Oddometer: 760
Tried that. Then I shaved the tank where the seat went, then i shaved the seat prong where it meets the tank, then I enlarged the rear hole. It never fit right, but did eventually bolt up. Bike died in baja a year ago when it lost a cam chain, gave the tank to a friend for his 08 450 exc, he had similar issues. Stock or EE seat pan made no difference.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
Old 04-29-2013, 07:29 PM   #4223
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
My seat it a tight fit with the 3.whatever Acerbis tank too. We've had to file the nut down on a few of our bikes to make the seats fit right, but most of them will slide into the right spot with a little persuasion (hit it - hard).
jesusgatos is offline   Reply With Quote
Old 04-29-2013, 07:59 PM   #4224
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Yup,gotta give the seat a solid push forward and it will pop over the locating bung (bung) I made a funny.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-29-2013, 08:02 PM   #4225
Honkey Cat
Tailights Fade!
Oddometer: 1,114
Ok im gonna drop the elbow and make it fit
Old 04-29-2013, 08:02 PM   #4226
Foot dragger
singletracker
Oddometer: 12,856
Make sure its located right on the front of the seat locater,then push the seat up onto the tank and hard forward.
It fit once when they built it,it will fit again.
Old 04-29-2013, 08:06 PM   #4227
resqd1
Oddometer: 236
yep 09 same thing yeserday just rap the seat with a little forward push
resqd1 is offline   Reply With Quote
Old 04-29-2013, 08:12 PM   #4228
Foot dragger
singletracker
Oddometer: 12,856
Originally Posted by FlyingDutchman View Post
http://www.youtube.com/watch?v=r7kSh1eAJQg
http://www.ebay.com/itm/2PCS-10W-CRE...3cb85e&vxp=mtr
I have two mounted on my bike...one on each handguard on the inner mount. Works great.
WOW! Those little lights flat put out the lumens!
Im not a big night time rider but better lights can be good in a clinch situation.
2 of those for 56.00 seems pretty fair.
Old 04-30-2013, 07:55 AM   #4229
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 858
2010 530 xc-w. I only has 8hrs on bike so I have never had the seat off yet until today. After I removed the 8mm bolt that holds seat on,the seat did not want to come off. Finally it popped off with some forearm persuasion. Went to install the seat back with the new seat cover and no way will it go on. The seat will not sit flush where the bolt and seat bolt aluminum collar sit. Bike has never been off road and never crashed or even laid down. I loosened up the subframe to see if there was some leeway but It will still not sit down so I can bolt seat down. Here is a picture of the bike with the ruler, anybody want to measure theres I would appreciate it. I have a feeling the cross brace on top of the subframe was welded in the wrong place.
Holy groundhog day! This thread should be locked... nobody reads it.
I like the pic with the text bubble and measuring tape! 9/10
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 04-30-2013, 07:59 AM   #4230
FlyingDutchman
Dirt Biker
Oddometer: 858
I'm going to probably remove subframe and re-weld it the way it is supposed to be. I'm crazy and I'm the only one.
Please post more of those pics when you do it.
Finally, a noob with the initiative to fix the problem.
Times are GMT -7.   It's 10:47 AM.
