Old 04-30-2013, 09:10 AM   #4231
Honkey Cat
Tailights Fade!
Oddometer: 1,102
I will post pics when its fixed. Pulled it all apart last night
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 04-30-2013, 09:24 AM   #4232
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 841
If someone who has a photohosting site wants post up a pic of the Cree lights mounted, send me an email.
Twist your own throttle
FlyingDutchman is offline   Reply With Quote
Old 04-30-2013, 09:49 AM   #4233
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,948
Sent you a pm.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 04-30-2013, 01:15 PM   #4234
FlyingDutchman
Dirt Biker
Oddometer: 841
Seat Cover Change
I replaced my seat cover this winter. It turned out ok but I wouldn't recommend it.
I ordered the oem seat cover for $55 plus the gas to the dealer. I waited a couple of months picking out a staple gun. Then I pulled the old cover and discovered my foam was in rough shape....too late to return the cover and order a complete seat. Waited a couple more months and when I set a few staples in I realized that I had a 6 inch crack in my seat pan.
I finished the job.... it looks like new....and listed it on ebay.
Just kidding...should last another year or two if I don't sit down much
Old 04-30-2013, 01:37 PM   #4235
malcolmzilla
Oddometer: 57
130 hours on my 2010 530 EXC/Christini.
100% leak down, oil consumption has been an issue since day 1, intermittently a lot, sometimes a little, plug always oil wet. Dealer would not warranty, "All new 4 strokes use some oil". Water under the bridge, so...
Tore bike down, engine is out ready a reman or refresh, will have a mechanic do it - I get enough wrenching on the Christini bits LOL.
What is the consensus, assuming my cylinder will be NFG, and getting them plated here is a long wait so thinking order the SXS 540 kit, new water, oil pump, chain and dirt trick tensioner, new head if req'd... Also worried about the FCR 39 being large enough...
Save some $ with the 540 vs the full 570 stroker kit, since it has lower hours on the bottom end and cams? Altho KTM oil rings scare me now.
Thoughts on it? Thanks. Never found the 530 lacking for snap/grunt, but now that I have a Berg 570 in the fleet...
Bike is used primarily for winter single track snow riding on studs, backup to my WR450 for enduros, and some dualsporting.
10 EXCR530 with Christini AWD, street legal
11 Berg 570, dirt and sumo
14 TE250, single track tool
malcolmzilla screwed with this post 04-30-2013 at 01:51 PM
malcolmzilla is offline   Reply With Quote
Old 04-30-2013, 01:42 PM   #4236
malcolmzilla
Oddometer: 57
I ordered the Sicass comfort in for last winters season (way more sit down riding) and IIRC it was about $120 and came complete, assembled and is delicious on my bum, slightly more foam and generous contours.
malcolmzilla screwed with this post 04-30-2013 at 01:56 PM
Old 04-30-2013, 02:01 PM   #4237
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,850
You didnt call a real dealer or try something when it used oil right off the bat?
Kinda expensive bike to just take it and lump it.
The chrome bore may be just fine,they usually are.
Run a diamond hone through it quick like and new rings and piston should be good.
Unless a valve seal was puking oil all along ,hard to say.
My 2011 530 has yet to use enough oil to measure luckily enough.
The Christini bits have been an issue as well?"
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-30-2013, 02:09 PM   #4238
Foot dragger
singletracker
Oddometer: 12,850
Originally Posted by Honkey Cat View Post
Ok im gonna drop the elbow and make it fit
Lotta elbow talk,people's elbow,etc.
Im not sure what that means really.
Re-welding that subframe to make your seat fit could easily open up more problems then your trying to solve.
If you think about it,the seat was on the bike when you got it,wouldnt it stand to reason that it would fit back on again?
Somebody at the factory put that seat on.
Slight torquing of said seat and some snap forward pressure and it will go on.
I had trouble the first time I tried it but it can be done,yours is no different I bet. KTM's plan is to have the seat tight on the bike with the 1 bolt holding it on,that's why the tight fit.
Old 04-30-2013, 03:01 PM   #4239
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,948
Agree. Push it forward and give it a smack. I'd try ten other things before re-welding the subframe. Both the clockworks and stock tanks on my bike are snug. Buddies 530/ Clockworks was almost impossible at first, but it goes on and off easier than mine now.
Old 04-30-2013, 07:14 PM   #4240
Honkey Cat
Tailights Fade!
Oddometer: 1,102
Im with you, it was stuck on so hard i thought there has to be another bolt holding it on. I put a ls6 vette engine in my miata so trust me ive slaped it, hit it, pushed, shoved tried flexing it. Im going to just modify a small section. It will be correct when im done with it
Old 05-01-2013, 07:58 AM   #4241
FlyingDutchman
Dirt Biker
Oddometer: 841
Cree 10w LED Spot Beam Lights
I bought these Cree lights last spring for a 4am start time rally and they have worked very well. I haven't compared them to much but it certainly was a 300% upgraded over the halogen TT light alone. I could not out run the beam in the woods or on the road at 100km/h. They are mounted to the handguard mount. They are wired so that the 4" halogen is the low beam and all 4 bulbs come on on high beam. They have remained waterproof and have not bothered me one bit while riding single track trail riding or enduro competition. The price seems had to beat on ebay and are available in flood beam too but my TT light handles that function
Old 05-01-2013, 09:05 AM   #4242
FlyingDutchman
Dirt Biker
Oddometer: 841
Ned is going to post up thoughts on the OEM 570 kit soon which is the same parts as the Berg 570 IIRC.
Do you need more torque on the snowy singletrack?
I don't understand your leakdown %. But I would recommend removing the cylinder your self and having it inspected/measured with the rings. OEM rings and valve seals are the cheapest fix at about 200$ + little labour. The KTM manual is very methodical. My piston and cylinder were fine at 180 hrs with lots of oil loss.
But I would be curious to test out a 570 kit and all the other upgrades...maybe next winter...
Old 05-01-2013, 04:57 PM   #4243
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,948
Bent my clutch lever when the hand guard twisted, so I installed some B-Rod threaded inserts. Very similar to the BRP inserts, except I have lots of time to fashion stuff rather than buy it. This is the third set I've made, and really should have made them the moment I bought this bike. I probably would have save the lever.
Take a 5/8" tap, and tap the end of your bars, but not too deep. Note the tape on the BRP tap. Mine didn't really matter, since I had an ample length bolt and not the predetermined length like the BRP.
Centre drill a 5/8" bolt to accept an 8mm tap, and tap that sucker. I used a lettered drill, size G. Blob some red Loctite on the bolt, and crank it into the bars. It will bottom to the depth that you cut the threads. Cut the remainder of the bolt off, grind smooth'n flush, and reinstall your hand guard. Done!
Old 05-02-2013, 08:03 AM   #4244
FlyingDutchman
Dirt Biker
Oddometer: 841
Threaded Inserts-Unbreakable Levers?
I installed my handguards into threaded inserts last winter. My handguards have not moved since. I used G2 nylon inserts in some new Twinwall bars with Bonz centermounts. I hoped it would be solid, and so far it has.
However, I did manage to snap my clutch lever off during Day 2 of the Corduroy Enduro. I rode the last three tests with a one finger shorty clutch lever...it could have been worse. If your drop your bike at just the right angle and your levers are adjusted down for standing comfort, they can still snap.
So, I'm considering these levers by ASV touted as unbreakable. Anyone have these installed?
Old 05-05-2013, 02:58 PM   #4245
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,862
Nice! They are some neatass bikes,I found a 2011 530EXCR and raced 5 hours away and grabbed it paying too much in the process,it had 25 hours on it and I wanted it bad. It came with a JD jet kit which seems to work just great,I do need to put in 1 size leaner pilot as the fuel screw is set about full lean.
But it barks! At sea level or at 6600' out in the Nevada desert it runs real strong,40+ mpg and it was pulling 90mph uphill on a sandy 2 track and wanted to go faster. Snaps to like a big 2 stroke almost. A Q FMF is on it currently,stock EPA muffler is a major butt plug.
Stock suspension did great on sand whoops and is amazingly plush on local singletrack or choppy fireroad,Ive had about 14 KTM's and this one is the best by a ways so far.
After the desert trip with it Im thinking of trying it out more on local tight trail,Ive been riding my 200 but the 530 turns great and will climb anything as fast as you want to go.
The only niggling thing is the clutch not dis-engaging quite all the way,Ive read how many of these bikes do it and its no good for me,wont start in gear and it can stall with the clutch all the way pulled in.
Gotta get that fixed.
Have fun once the rain quits!
I had to travel about the same distance to get mine. I'm a half-hour west of Charlotte, and had to go to Savannah. I had set my radius to about 300 miles, and this was the first 530 to pop up in the six weeks after I decided to go for it. They're like hen's teeth around here. Gotta jump on them when they show up for sale.
Try a different oil in the tranny before you go to too much trouble trying to sort the clutch. Whatever synth was in mine was too slippery for the auto-clutch to work right, and Rotella made it grabby/draggy enough for it to work the way I want it to. You might want to try something more slippery than what you're using now, although it's hard to know what to try without wading through stupid oil threads.
When I had my 950SE, the clutch would drag when I used Motorex full-synth. If the bike were dead-cold, I couldn't push it around the garage in first with the clutch pulled in; and while riding, the clutch was grabby with a narrow engagement point. The next oil I tried was Motul 5100 (a blend). I could pull in the clutch and push the bike around in gear almost as easily as if it were in neutral, the engagement point was much broader, and the shifting much smoother; but it never slipped under power. I obviously have no idea what you use now, but it might be worth trying a quart of 5100 in the transmission.
Don't take this as an endorsement of Motul or slam of Motorex, I just noticed that the clutch behavior was completely different after switching. I don't really have preferences, but tend to try different stuff.
And yep, it's Sunday, and raining again. My driveway looks like a creek. Again.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie screwed with this post 05-05-2013 at 03:33 PM
Stobie is offline   Reply With Quote
Times are GMT -7.   It's 02:48 PM.
