Old 05-05-2013, 04:21 PM   #4246
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Originally Posted by FlyingDutchman View Post
...considering these levers by ASV touted as unbreakable. Anyone have these installed?
Think those ASV levers are stupid. They only pivot away from the bars, but levers usually get bent up or down. When was the last time your lever got pulled away from your handlebars? Sunline's levers are a much better design.
...and if you guys want to make your outer handguard mounts bombproof, take a look at these little chingaderas that we made.
jesusgatos is offline   Reply With Quote
Old 05-05-2013, 04:23 PM   #4247
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 419
I installed my handguards into threaded inserts last winter. My handguards have not moved since. I used G2 nylon inserts in some new Twinwall bars with Bonz centermounts. I hoped it would be solid, and so far it has.
However, I did manage to snap my clutch lever off during Day 2 of the Corduroy Enduro. I rode the last three tests with a one finger shorty clutch lever...it could have been worse. If your drop your bike at just the right angle and your levers are adjusted down for standing comfort, they can still snap.
So, I'm considering these levers by ASV touted as unbreakable. Anyone have these installed?
No I don't have any experience with the ASV's, but I do have three of the Zeta version on my 450. Had a set on the old DRZ too. I like them. I ground off the ball end of the clutch lever just to ease getting my fingers in and out of the area. I love the spring loaded feature for the dual lever setup too. Mucho less chance of getting a hand stuck in the wrong place at the wrong time.
...guess I can't find a pic of the front brake setup. Oh, well, you get the idea.
I just wrap my perch mounts in a little teflon tape. They move in a get off, bang them back into place. Not to jinx myself, but I haven't broken a lever in an accident in a few decades.
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 05-06-2013, 09:13 PM   #4248
Bungholio
Bungholio's Avatar
Oddometer: 744
Wink 530EXC on the trail
I hit the trails on May 1 in Western WA, first day the trails were open in Capitol Forest. Used my GoPro Hero3 that I got for Xmas and put together a couple of videos that I uploaded to YouTube. Here are the links if any are interested.
http://www.youtube.com/watch?v=RVOhncDHSzQ
http://www.youtube.com/watch?v=3rsa161I71w
It was a nice day for me since this is the first trails I have ridden here in 2 years. Tried out some new boots too and they worked really well, Forma Adventure waterproof boots.
Bungholio is offline   Reply With Quote
Old 05-08-2013, 11:54 AM   #4249
GR0NK
Got some screws loose!
GR0NK's Avatar
Oddometer: 2,344
Originally Posted by WVa Dualsport View Post
... I love the spring loaded feature for the dual lever setup too. Mucho less chance of getting a hand stuck in the wrong place at the wrong time.
What is this setup?
Sean
Team Valley Bomb Squad
Nullus Vereor ex Terra Incognita
GR0NK is offline   Reply With Quote
Old 05-09-2013, 05:34 AM   #4250
Joe
Debaser
Joe's Avatar
Oddometer: 1,748
Anybody have opinions on cooling fans, Dirt Tricks or KTM hardparts?
Joe is offline   Reply With Quote
Old 05-09-2013, 09:59 AM   #4251
WVa Dualsport
Oddometer: 419
Originally Posted by GR0NK View Post
What is this setup?
Sean
Rekluse LHRB on top. OEM Clutch lever (controlling a Rekluse EXP 2.0) . No rear foot pedal.
2010 450 EXC
2012 DL1000 V-Strom
Old 05-09-2013, 01:37 PM   #4252
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Ive got the Dirttricks fan,it works fine unless I wash the bike,just that much water makes the switch no longer work until it decides to work again. Considering water is sometimes big part of riding these things,I gotta shoot DT a note and see what they think.
Its a manual switched fan.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-09-2013, 02:47 PM   #4253
jesusgatos
jesusgatos's Avatar
Oddometer: 2,394
If you're asking which is better, think the answer is the KTM fan, hands-down. Only reason to run the DT fan might be in applications where the KTM fan wouldn't clear a tank or something. But a Spal fan vs. a computer fan... no contest.
Old 05-09-2013, 03:43 PM   #4254
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,878
I run the hard parts fan....it doesn't come on very much unless you stop alot...I think the Engine Ice made things cooler...fits with the Clockwork tank.
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 05-09-2013, 04:03 PM   #4255
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
I'm on my second bike with the hard parts fan. Works when it needs to, and I haven't had to worry about switches. If my thermo switch fails, I'll be replacing it, as I don't want to run it all the time or be responsible for making sure I turn it on when it needs to be on. I have enough trouble staying on the bike as it is.
I put the slicks on for a few days, and found some snow in the hills. What a versatile bike! Dirt wheels, ice racing set, and super moto. I really can't see me using these too much though.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-09-2013, 04:06 PM   #4256
Foot dragger
singletracker
Oddometer: 12,863
The DT fan flows 100cfm and doesnt use much power at all,so there's a few reasons to run one.
People talk about running their battery down with the stock stator when the KTM fan runs alot.
Ive ran my 530 in 100 degree temps and its never spit water out yet so that's a good thing.
Old 05-09-2013, 04:11 PM   #4257
Foot dragger
singletracker
Oddometer: 12,863
Thats the trick,the trails around here involve barely moving or stopping,tight singletrack with switchbacks.
4 strokes get hot and blow their water out,fans run a long time sometimes.
I tend to just ride my 200.
Old 05-09-2013, 04:19 PM   #4258
Joe
Debaser
Joe's Avatar
Oddometer: 1,748
Thanks. I picked up the KTM fan, I had read some good reviews on the DT fan kit but I would prefer to stick with OEM for those type of accessories. Next up 14/48, this friggin off road habit is going to put me in the dog house.
Old 05-11-2013, 04:36 PM   #4259
resqd1
Oddometer: 236
Searched cant find, Am I an idiot? Ok so the dash unit. It turns on when the bike rolls forward, but I cant get it to turn on by pressing the buttons or anything. Also I cant get it to do anything with any of the buttons once it is on. Is there an internal battery? I would think something is broken if one or two of the buttons didnt work, but all three buttons wont do anything. Can someone help me out here, or is it an anomaly?
resqd1 is offline   Reply With Quote
Old 05-12-2013, 06:48 AM   #4260
WVa Dualsport
Oddometer: 419
Yep, there is a coin cell battery accessible from the bottom of the unit.
2010 450 EXC
2012 DL1000 V-Strom
Times are GMT -7.   It's 02:21 AM.
