Old 05-12-2013, 07:55 AM   #4261
resqd1
Oddometer: 236
Originally Posted by WVa Dualsport View Post
Yep, there is a coin cell battery accessible from the bottom of the unit.
Oh ok very cool, take the headlight off to get to it? or can it come out without doing that? Thanks for the help
resqd1 is offline   Reply With Quote
Old 05-12-2013, 08:41 AM   #4262
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Take off the headlight. I had to replace the battery when mine was doing the same as yours. It's a common watch battery.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-12-2013, 08:43 AM   #4263
resqd1
Oddometer: 236
Ok cool, got the headlight off, what is the easiest path of getting to the battery, which screws? The ones on the bottom? Dont want to start unplugging all sorts of things. Or do I need to mark and picture everything thing and unplug everything and pull it?
Old 05-12-2013, 09:25 AM   #4264
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
There is a round battery cover that you can use a coin or a screw driver to remove, and removing anything on the front is easy. There are two bolts that attach the computer and sandwich the signals to the triple. Removing this may give you more access.
Old 05-12-2013, 09:54 AM   #4265
resqd1
Oddometer: 236
Ok got it off, tested the battery shows 3.06 on the multimeter, it is a 3V battery, just down enough to not run anymore? Or still good?
Old 05-12-2013, 12:39 PM   #4266
resqd1
Oddometer: 236
New battery in and no change. Anyone have any other idea of why the buttons dont do anything on the dash unit?
Old 05-12-2013, 08:35 PM   #4267
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
today my ktm has kicked out. haven't been in the engine yet but looking for ideas of why or what to look for. there was a rattle noise then white smoke, shut it off then it wouldn't start again. any ideas?
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 05-12-2013, 09:49 PM   #4268
Bungholio
Bungholio's Avatar
Oddometer: 705
White smoke(steam?) sounds like coolant.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 05-13-2013, 06:33 AM   #4269
J.Johnson
J.Johnson's Avatar
Oddometer: 85
My comp. started to fail 2 years ago. It started by not letting you scroll through the data options. I replaced it with the Voyager.
Sent with this high tech chingadera!
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 05-13-2013, 07:48 AM   #4270
antpatterson
XR650L_High_Runner
Oddometer: 378
That's what my dad believes is it was steam, but there must be more because I heard a rattling noise like a rock was in the engine getting tossed like a salad. I am about to get my college refund check so instead of getting a new truck I guess I'll rebuild my KTM while fixing whatever the problem is.
While working at my local motorcycle shop I looked up kits for my 450 XCRW and there was only ONE listed for this model, the rest are different in some way like some are higher or lower ratios would this matter? Will the EXC or XCW piston kits work for the XCRW? I thinking of boring it out some is why I'm asking as well. I don't know why or where to begin to look for the steam problem, water pump seal maybe? I did all the seal replacements that came from factory wrong except for the oil seal that keeps the tranny and engine oil separate, I guess I'll do that while I'm at it. My riding season just began and there's a enduro race next weekend and then this happened, o well.
XR80r
2008 XCRW450
Old 05-13-2013, 08:40 AM   #4271
Rickfenn1
Voltron
Oddometer: 26
Mine is the same way. Recently the cirlce button stopped as well. They have crappy buttons soldered in I found this semi expensive option: http://www.ktm-parts.com/54814073000.html#.UU-15ldv7vg
The computers don't seem to hold up too well. This was another one that I had. screen failure.
Rickfenn1 is offline   Reply With Quote
Old 05-13-2013, 09:19 AM   #4272
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
These bikes come with instructions,even on how to change a battery,just in case your interested.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-13-2013, 09:25 AM   #4273
Foot dragger
singletracker
Oddometer: 12,856
Steam would come from where water goes,radiator has a vent line that pukes steam,its not usually a catastrophic event as these bikes over heat easily on a tight trail.
A sound like a rock being digested by the engine might mean more then a piston is needed. They dont usually explode internally from blowing some steam out.
Old 05-13-2013, 02:42 PM   #4274
antpatterson
XR650L_High_Runner
Oddometer: 378
so I may end up having a full rebuild.....great. and it was white smoke from exhaust.
XR80r
2008 XCRW450
Old 05-13-2013, 03:17 PM   #4275
Bungholio
Bungholio's Avatar
Oddometer: 705
Head gasket blown? Coolant leaks into cylinder and burns with fuel. Does rattling still happen when cranking engine? Is there compression? Maybe the water pump failed?
Times are GMT -7.   It's 10:30 PM.
