Old 05-13-2013, 04:17 PM   #4276
resqd1
Oddometer: 236
Originally Posted by Foot dragger View Post
These bikes come with instructions,even on how to change a battery,just in case your interested.
Looked all through the manual and didnt see anything about the other battery at all, maybe I am just stupid.
resqd1 is offline   Reply With Quote
Old 05-13-2013, 06:37 PM   #4277
Scott G
Oddometer: 50
Bleeding the rear brake on 2010 530
I totally disassembled my rear caliber and now cannot get it to bleed. I pump it for an hour and nearly nothing comes out when I open the bleeder. I have bleed lots of cars brakes and know the process, however it seems like the master cylinder wont prime.
What I am missing.
I tried to back bleed them like you do for the clutch and there must be a oneway value that wont allow any fluid to go in
Scott G is offline   Reply With Quote
Old 05-14-2013, 07:32 AM   #4278
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Originally Posted by antpatterson View Post
so I may end up having a full rebuild.....great. and it was white smoke from exhaust.
How did that come about? Gradually lost power and died or ran fine and then blew white smoke out the pipe and died? No water in oil or oil in radiator?
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-14-2013, 08:27 AM   #4279
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
What I am missing.
There's no one way valve, you should be able to back bleed the front and rear brake systems. Are you sure that the piston isn't still engaged and blocking the flow of fluid?
What's the worst that could happen?
Junglerot is offline   Reply With Quote
Old 05-14-2013, 11:51 AM   #4280
Subaru297
Oddometer: 116
I just had to replace my odometer battery as well. My trip meter kept resetting to zero which is very annoying when that is my fuel gauge!
It is easy to pop off the unit and replace the battery. The battery I took out still read 3 volts though so I am hoping the unit itself is fine. The new battery was 3.27v. Not a huge difference!
Subaru297 is offline   Reply With Quote
Old 05-14-2013, 11:54 AM   #4281
resqd1
Oddometer: 236
yeah I changed the battery and it didnt make a difference at all
Old 05-14-2013, 12:15 PM   #4282
Subaru297
Oddometer: 116
Don't tell me that!
I guess that is a good excuse for a Trailtech Voyager though
Old 05-14-2013, 01:11 PM   #4283
resqd1
Oddometer: 236
teh guy who sold me the bike swears it works, said I need to try some rest code, havent found the sequence in the manual yet.
Old 05-15-2013, 06:00 AM   #4284
Krazyjohnny
Oddometer: 448
Headed to Buena Vista
Hey Gang,
Wife and I are headed to Buena Vista while the Chucklehead is at BSA Camp not far away. We are looking to do some riding while there and also want to know of any quality shops that can provide parts and service for the KTM and or the Yamaha in that area. Not expecting any problems just making sure we have a Plan B.
What Jetting do you guys run in your 09' 530s up there. Mine has been desmogged and has the JD Red needle in it with the lowlander jets. Wife is riding the 08' TTR 250 and I will probably leave it alone. It seems to be a little lean in the mid range right now so it may be just right.
Any ideas on trails or where to get good maps woul dbe nice too. I have some of my own ideas, but know there is still lots of snow. We are planning to be there the week of 6/10.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 05-15-2013, 06:41 AM   #4285
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,920
Originally Posted by Krazyjohnny View Post
Hey Gang,
Mountain Tech Yamaha in BV can help you out; Sean (the owner) is a good guy. Tons of riding right there; check out the trials in Fourmile OHV area, or even over Cottonwood pass in Taylor Park.
Mountain Tech should have maps, but here's one of Fourmile:
http://garna.org/friends-of-fourmile...%2015%2009.pdf
edit: just noticed your dates- Taylor will likely still have snow. Fourmile is completely clear right now, or come down to Salida; the Rainbow Trail is completely clear as of yesterday.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 05-15-2013, 08:23 AM   #4286
Foot dragger
singletracker
Oddometer: 12,856
Im still having a hard time getting the clutch to dis-engage all the way on my 2011 530,bled the clutch thouroughly,Im running T-6 Synthetic for trans oil currently,I cant see how it would work well on singletrack with a dragging clutch helping stall the engine in tight stuff.
Any other 530 riders dealt with this issue and fixed it?
Ive had a good collection of KTM's and all had a clutch that dis-engaged no problem.
Thanks for any help!
Old 05-15-2013, 09:01 AM   #4287
Bungholio
Bungholio's Avatar
Oddometer: 705
Mine only drags a little when it is cold. After a mile or so it's free. Does yours drag all the time?
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 05-15-2013, 09:11 AM   #4288
Foot dragger
singletracker
Oddometer: 12,856
It does drag all the time,enough to stall it when I put it in gear unless the idle is turned up pretty high. Seems odd to have a bike do this pretty much from new.
I havent ridden it on really tight trail but once and having it stall with the clutch in then not be able to start it till neutral is found just doesnt work for me.
Great bike otherwise though.
Old 05-15-2013, 09:45 AM   #4289
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,859
Could it be the torque limiter?
http://advrider.com/forums/showpost....58&postcount=6
**edit** probably not as that seems more starting issue....
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub screwed with this post 05-15-2013 at 09:55 AM
Michhub is offline   Reply With Quote
Old 05-15-2013, 10:51 AM   #4290
Foot dragger
singletracker
Oddometer: 12,856
Ive looked at that,I think that is more to do with it starting in gear with the clutch in.
Mine is more just a dragging clutch,seems the same hot or cold.
Ive heard rumors of a special washer that maybe goes behind the clutch to make it work normal.
Then another rumor of putting a small ball bearing in front of the clutch push rod to give more push on the clutch pack.
Then maybe a different oil in the trans can help,Im going to try that first off and see what happens.
Does seem like the guys who built the bike shoulda maybe figured this out.
Times are GMT -7.   It's 10:26 PM.
