Old 05-24-2013, 05:26 PM   #4351
KTM Explorer
Dirt Whore
KTM Explorer's Avatar
Oddometer: 208
Man I am STUCK! Need some help. I have the below setup
and I need a banjo bolt to replace the looong threaded black piece (it goes all the way through the banjo fitting and down the middle of the orange reservoir and into the caliper.
Problem> This long black fitting is bent, the threads tweaked so it holds no pressure at the caliper junction. I'd want to get a banjo bolt that could replaceall of this, and a setup that has the bleed screw would be even better.
HELP! What banjo could I get on a Saturday - size?
KTM Explorer is offline   Reply With Quote
Old 05-24-2013, 05:44 PM   #4352
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,883
Can't be positive because mines an '08 but it says M10x1 for Item 11...did you get the parts book with your bike, in the suitcase?
I looked up your bike on Munnracing.com and it did not give the size.........
***Edit*** I see my parts book is out dated and the one above has been superceeded
"54813020000 BLEEDER SCREW CPL. 05 superceeded by 62513020000" which is the same as your 2010...so M10x1
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub screwed with this post 05-24-2013 at 05:51 PM
Michhub is offline   Reply With Quote
Old 05-24-2013, 06:08 PM   #4353
KTM Explorer
Dirt Whore
Oddometer: 208
Great - thanks! So would an M10x1 any ol banjo work?
Old 05-24-2013, 06:37 PM   #4354
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,883
I suspect so....the trick with any 'ol banjo is you won't have the bleed screw...that being said,
bleeding the system is gonna be messy and you may still be left with a spongy rear brake....
the other thing to consider is the length of the banjo bolt.
The M10 size is easy enough and the 1.0 is the thread pitch...I don't know how much the bolt
can go into the caliper without interference and still make a tight seal with the washers and line....
I'd try Autozone or similar....this one has the right size & thread pitch...
LINK
Mike
Reinheitsgebot
Bonsai Elephant - "
Old 05-25-2013, 06:43 AM   #4355
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
Originally Posted by KTM Explorer View Post
Thumbs DOWN for this:
http://www.cyclebuy.com/shopping/str...r_radiator.htm
NOT the company selling it, but the actual 'brake radiator'. Dumped the bike lightly and the entire body of the radiator slightly bent, thread body bent, complete loss of fluid for rear brakes on a ride.
Ah,you've discovered the "bling" factor,shiny pieces of anodized aluminum that usually detract from function but seem like a good idea at the time.
Weve mostly all fell prey to this but it sucks to have bling end a ride.
I would think the stock banjo bolt is what you need.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 05-25-2013, 09:46 AM   #4356
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,394
Can you mount that little radiator chingadera on the other side of the banjo? Wouldn't conduct heat away from the caliper quite as well, but wouldn't be as likely to fail if it were installed that way either.
GatosBros · Crux Studio · Trails Less Traveled
jesusgatos is offline   Reply With Quote
Old 05-25-2013, 02:34 PM   #4357
thomspins
Oddometer: 39
Could anyone offer any advice on why my '08 530 excr is not wanting to idle? Idle will race then drop and stall, I'll adjust idle screw, blip throttle, idle will hang then drop off; and repeat. Below I've attached a link to a youtube video of how it is acting. I'm stumped..
Bought the bike about 3 months back and desmogged and put the JD kit (175 main, 42 pilot, red needle 4th clip) in it. JD Fuel screw (1 1/2 turns out). It ran great for a while then it sat for a few weeks while I was traveling for work. I installed the BD Squadron headlight, floated the ground on the stator and installed their regulator (all in a kit). I've changed the plug, new airfilter, removed the carb and put all parts in ultrasonic cleaner.
Any suggestions before I take it somewhere?
http://www.youtube.com/watch?v=Mqhjo...ature=youtu.be
thomspins is offline   Reply With Quote
Old 05-25-2013, 03:46 PM   #4358
Honkey Cat
Tailights Fade!
Oddometer: 1,116
Overflow problem
Installed the samco thermo bypass kit, installed the samco t hose to radiators. Refilled the system up and after a 5 min ride and then 5-6 min idle in garage the overflow was puking coolant. Im thinking there is prob air in system not sure, whats best way to burp it?
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 05-25-2013, 04:25 PM   #4359
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,980
Vacuum leak? if you had the carb off, maybe the boot between the carb and head isn't seated, or loose. Look for air leaks. That's where I'd start.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-25-2013, 05:02 PM   #4360
J.Johnson
J.Johnson's Avatar
Oddometer: 85
Just thought I would ask the stupid question. Did you plug the vacuum line on the intake when you desmogged? I have seen a few bikes that desmogged and let that line line vent to atmosphere. Not a good thing.
Sent with this high tech chingadera!
“This is your life, and it’s ending one minute at a time.”
J.Johnson is offline   Reply With Quote
Old 05-25-2013, 05:56 PM   #4361
thomspins
Oddometer: 39
Yep, plugged both fittings with bolts and ran a hose from the t where it was going in the carb down to a fitting I installed on the catchcan. Screw removed from the bottom of catchcan too.
Old 05-25-2013, 07:50 PM   #4362
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,883
KTM Explorer...did you find the KTM banjo or Macguyver it....
Mike
Reinheitsgebot
Bonsai Elephant - "
Old 05-25-2013, 07:56 PM   #4363
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,883
[INDENT]Could anyone offer any advice on why my '08 530 excr is not wanting to idle? Idle will race then drop and stall, I'll adjust idle screw, blip throttle, idle will hang then drop off; and repeat. Below I've attached a link to a youtube video of how it is acting. I'm stumped..
Mine was doing something like that....I would inspect the mixture screw....
Mike
Reinheitsgebot
Bonsai Elephant - "
Old 05-28-2013, 03:32 PM   #4364
Weldit
Weldit's Avatar
Oddometer: 336
Laugh
Originally Posted by dirtdiver View Post
I had a weird thing today. I have almost 10,000 miles on my engine of the 2009 530. I was riding on a 2 day Baja jaunt of about 400 miles. The weather was warm but not hot. The bike was running great. I had about 3/4 of a tank of gas. I was doing 40-55 miles per hour on a graded dirt road. I was pretty much bombing along.
All of a sudden the bike just died. Like I had activated the kill switch. No choking or gasping, it just quit running.
We messed with it for 15 minutes, verified we had gas flowing, verified I had oil, I took apart the kill switch, still no joy.
My buddy towed me 30 miles to the border. Along the way I was hitting the starter periodically with no start. We got to the border, while waiting in line for our turn the bike fired right up. I rode it 20 miles home and it ran as good as it ever did.
Ideas on what to check? It makes me nervous to take it back out without finding something wrong.
DD
just a thought here :
my pressure washer gas powered Honda motor was the same thing
it would run for a few minutes then die just like the kill switch was hit
after pulling carb apart and fuel pump -- nothing
the strange part was you could give it one pull and it would start up
changed spark plug and it has been perfect for 3 years now
the old plug looked clean - must have been grounding out when warm ?
a friend had similar thing with his generator
wort a try - plug is cheap !!
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 05-28-2013, 09:13 PM   #4365
Bungholio
Bungholio's Avatar
Oddometer: 753
I had same problem and solution with a lawn mower(honda) and a new dr650. New plugs fixed problem. DR only had about 1k miles with factory plugs. It would stutter when going down road and die sometimes at stop signs. Emptied tank of fuel and float bowl checking for water in gas. Still did it after cleaning. Put new ngk plugs in it and it ran perfect. The ND plugs i took out looked fine but they must have been bad.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio screwed with this post 05-31-2013 at 04:49 PM
Bungholio is offline   Reply With Quote
Times are GMT -7.   It's 03:42 AM.
