Old 05-28-2013, 11:08 PM   #4366
dirtdiver
Oddometer: 2,039
A plug is cheap. Ill give it a try, thanks.
Originally Posted by Weldit View Post
just a thought here :
my pressure washer gas powered Honda motor was the same thing
it would run for a few minutes then die just like the kill switch was hit
after pulling carb apart and fuel pump -- nothing
the strange part was you could give it one pull and it would start up
changed spark plug and it has been perfect for 3 years now
the old plug looked clean - must have been grounding out when warm ?
a friend had similar thing with his generator
wort a try - plug is cheap !!
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 05-29-2013, 03:37 AM   #4367
roastbeef82
roastbeef82's Avatar
Oddometer: 86
Also change the spark plug cap - I had a similar thing after about 10,000 miles on my 06 400 exc and it was the plug cap, it looked fine, but must have been tracking to ground.
Life is what happens to you while you're busy making other plans........John Lennon
roastbeef82 is offline   Reply With Quote
Old 05-29-2013, 09:53 AM   #4368
darkstarmoto
Am I evil? Yes I am
darkstarmoto's Avatar
Oddometer: 372
Been lurking around here for a bit, figured I could finally post a pic. Thanks for all the great info in this thread. Helped me get my 08 sorted and reliable on all fronts.
05 KTM 950ADV - 08 KTM 690 SMR - 07 Ducati MTS1100S - Redneck Engineering Mutant
darkstarmoto is offline   Reply With Quote
Old 05-29-2013, 08:41 PM   #4369
Bungholio
Bungholio's Avatar
Oddometer: 706
Anyone have any advice for installing silicone coolant hoses? Fought with the water pump end for a while then took it off to get the hose on it. I dont see any way i can get the hose on the tube going thru frame to top of radiators.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 05-29-2013, 09:44 PM   #4370
resqd1
Oddometer: 236
Update on the dash unit.
So apparently none of the other things will come up after the computer resets itself. So if you dig into the manual and follow the procedure you can turn on the other items in the dash unit like trip meters and such. Hope that this help someone if need be.
resqd1 is offline   Reply With Quote
Old 06-01-2013, 04:41 AM   #4371
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 492
I just installed the Highway Dirt Bikes top clamp and handguards. I got the switch relocator for the key, but it doesn't tighten down inside the new mount. Anybody else had this issue? Also the bikes previous owner cut down the bars a little too short so the handguards don't fit so I'm looking for some stock bars so they'll fit. I love the new look of the top clamp and the computer relocate!
mflora98ss is offline   Reply With Quote
Old 06-02-2013, 11:10 AM   #4372
fast4ward
Oddometer: 86
Hi All - I bought a used 2011 530XCW Six Days a couple of months ago, and it doesn't seem to be as powerful as I was expecting. It has a little over 120 hours on it. It might be me, but I'd like to check the compression on the bike. I can't find any reference to what it should be ? I see it mentioned as a test, but no value range given. Nothing in the maintenance manual for it either apart from a ratio.
fast4ward screwed with this post 06-02-2013 at 11:21 AM
fast4ward is offline   Reply With Quote
Old 06-02-2013, 05:12 PM   #4373
Bungholio
Bungholio's Avatar
Oddometer: 706
When you say it wont tighten down, is the hole too small? I bought the same type mount for mine but it was for powerlet socket and it was slightly undersize. Sanded out with dremel and it fit fine.
Old 06-02-2013, 07:11 PM   #4374
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 492
The hole for the key is the right size, it is just too thin of material like there needs to be a spacer in between the stock spacer and the collar on the top.
Old 06-02-2013, 08:04 PM   #4375
Bungholio
Bungholio's Avatar
Oddometer: 706
Now I have to ask, "Why move it"?
Old 06-02-2013, 08:48 PM   #4376
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
So you can snap the key off in the first ten minutes of riding and never have to think about it again. I have never turned my key off. I'm more afraid of someone stealing my key and immobilizing my it than stealing the entire bike
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Old 06-02-2013, 10:20 PM   #4377
Bungholio
Bungholio's Avatar
Oddometer: 706
Hahaha. You CAN get a new ignition and key, unless you did it on purpose
Old 06-02-2013, 11:08 PM   #4378
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,390
padlock + sprocket > ignition key
jesusgatos is offline   Reply With Quote
Old 06-03-2013, 06:52 AM   #4379
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
I look at that neato alu speedo mount and key relocater,and I see another thing to get jabbed with in one of my awkward unplanned dismounts.
Anything sticking out the backside of the handlebar area could be bad for body parts.
A friend did have his entire 2012 500EXCR stolen,he had removed the key switch and did the jumper wire thing,it was only about 3 grand out of pocket for a 2013 500 by the time ins covered it. He had it parked behind his house with 0 precautionary measures.
Not a month before he had assured me his upscale neighborhood never had problems.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 06-03-2013, 06:53 AM   #4380
Foot dragger
singletracker
Oddometer: 12,856
Disc lock/Big Cable/steering lock/theft Ins/key out.
Times are GMT -7.   It's 12:38 PM.
